IP CCTV Lighting
Sidebar
IP CCTV Lighting
Network-connected infra-red and white LED CCTV lighting for use with power over ethernet switches and injectors.
Grid  List
  1. rayTEC VAR2-IPPoE-w8-1 Long Range White-Light Network Illuminator
    £542.64 Incl VAT Excl VAT. £452.20
    Built to Order
    The rayTEC VAR2-IPPoE-w8-1 is designed to improve video surveillance at night with white-light LEDs that can reach distances of 180m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE++ input for easy integration with existing network structures. The VAR2-IPPOE-w8-1 provides the ultimate solution for smart, situation-dependent lighting and is perfect for use with IP cameras. The illuminator can be programmed to automatically deliver the exact amount of light where and when it is needed.
    raytec vario2 ip poe banner
    rayTEC Bracket GuiderayTEC VARIO2 IP Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure Learn More
  2. rayTEC VAR2-IPPoE-w4-1 Medium Range White-Light Network Illuminator
    £314.16 Incl VAT Excl VAT. £261.80
    Built to Order
    The rayTEC VAR2-IPPoE-w4-1 is designed to improve video surveillance at night with white-light LEDs that can reach distances of 110m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE+ input for easy integration with existing network structures. The VAR2-IPPOE-w4-1 provides the ultimate solution for smart, situation-dependent lighting and is perfect for use with IP cameras. The illuminator can be programmed to automatically deliver the exact amount of light where and when it is needed.
  3. rayTEC VAR2-w2-1 Short Range White-Light Illuminator
    £185.64 Incl VAT Excl VAT. £154.70
    Built to Order
    The rayTEC VAR2-i2-1 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 60m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    raytec vario2 banner
    rayTEC Bracket GuiderayTEC VARIO2 Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure
    Learn More
  4. rayTEC VAR2-VLK-i4-2 Fully Integrated Illumination & Camera Housing
    rayTEC VAR2-VLK-w4-2 Fully Integrated White-Light Illumination & Camera Housing
    £706.86 Incl VAT Excl VAT. £589.05
    Built to Order
    The VAR2-VLK-w4-2 is a fully integrated lighting, camera housing and bracket solution that offers a maximum distance of 155m. It includes two inbuilt white-light illuminators along with housing for 2 cameras. This solution uses rayTEC's adaptive illumination technology that allows the user to adjust the angle of light projection easily and includes 10° x 10°, 35° x 10° and 60° x 25° lenses.
    Learn More
  5. rayTEC VAR2-XTR-w16-1 Extreme Long Range White-Light Illuminator
    £785.40 Incl VAT Excl VAT. £654.50
    Built to Order
    The rayTEC VAR2-w16-XTR-1 is an illuminator from the VARIO2 range which is designed to provide extreme durability to video surveillance systems at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 250m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  6. rayTEC VAR2-XTR-w8-1 Extreme Long Range White Light Illuminator
    £539.78 Incl VAT Excl VAT. £449.82
    Built to Order
    The rayTEC VAR2-w8-XTR-1 is an illuminator from the VARIO2 range which is designed to provide extreme durability to video surveillance systems at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 180m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  7. rayTEC VAR-DZ-w8-1 Medium Range Remotely Adaptive White-Light Illuminator
    £601.20 Incl VAT Excl VAT. £501.00
    Built to Order
    The rayTEC VAR-DZ-w8-1 is a white-light illuminator which can be remotely adjusted via a volt-free input. The angle can be changed anywhere between 10° and 80° allowing the user to precisely match the required field of view. This illuminator has a max distance of 90m and utilizes rayTEC's hot-spot reduction technology to deliver light to where it is most needed.
    raytec vario banner
    rayTEC Bracket GuiderayTEC Distance and Angle CalculatorrayTEC Product Overview Learn More
  8. rayTEC RL300-AI-05/RL300-AI-10/RL300-AI-30/RL300-AI-50 Adaptive White-Light Illuminator
    rayTEC RL300-AI-05/RL300-AI-10/RL300-AI-30/RL300-AI-50 Long Range Adaptive White-Light Illuminator
    £1,249.50 Incl VAT Excl VAT. £1,041.25
    Built to Order
    The RL300 is a long range white-light illuminator with optional adaptive beam angles. These illuminators are designed to give even illumination and excellent images for night time surveillance. The RL300's flexibility allows the user to alter the angle to match the exact camera field of view with distances up to 320m.
    raylux banner
    rayTEC Bracket GuiderayLUX Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product Overview Learn More
  9. rayTEC RL200-AI-10/RL200-AI-30/RL200-AI-50/RL200-AI-120 Long Range Adaptive White-Light Illuminator
    £892.50 Incl VAT Excl VAT. £743.75
    Built to Order
    The RL200 is a long range white light illuminator with optional adaptive beam angles (10˚ ~ 20˚/30˚ ~ 60˚/50˚ ~ 100˚/ 120˚ ~ 180˚). These illuminators are designed to give even illumination and excellent images for night time surveillance. The RL200's flexibility allows the user to alter the angle to match the exact camera field of view with distances up to 200m.
    raymax banner
    rayTEC Bracket GuiderayMAX Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product Overview Learn More
  10. rayTEC RL150-AI-30/RL150-AI-50 Medium Range Adaptive White-Light Illuminator
    Built to Order
    The RL150 is a medium range white-light illuminator with optional adaptive beam angles. These illuminators are designed to give even illumination and excellent images for night time surveillance. The RL150's flexibility allows the user to alter the angle to match the exact camera field of view with distances up to 80m.
    raylux banner
  11. rayTEC RL100-AI-10/RL100-AI-30/RL100-AI-50/RL100-AI-120 Long Range Adaptive White-Light Illuminator
    rayTEC RL100-AI-10/RL100-AI-30/RL100-AI-50/RL100-AI-120 Medium Range Adaptive White-Light Illuminator
    £556.92 Incl VAT Excl VAT. £464.10
    Built to Order
    The RL100 is a medium range white-light illuminator with optional adaptive beam angles (10˚ ~ 20˚/30˚ ~ 60˚/50˚ ~ 100˚/ 120˚ ~ 180˚). These illuminators are designed to give even illumination and excellent images for night time surveillance. The RL100's flexibility allows the user to alter the angle to match the exact camera field of view with distances up to 120m.
    raymax banner
  12. rayTEC RL50-AI-10/RL50-AI-30/RL50-AI-50/RL50-AI-120 Short Range Adaptive White-Light Illuminator
    £349.86 Incl VAT Excl VAT. £291.55
    Built to Order
    The RL50 is a short range white-light illuminator with optional adaptive beam angles (10˚ ~ 20˚/30˚ ~ 60˚/50˚ ~ 100˚/ 120˚ ~ 180˚). These illuminators are designed to give even illumination and excellent images for night time surveillance. The RL50's flexibility allows the user to alter the angle to match the exact camera field of view with distances up to 60m.
    raymax banner
  13. rayTEC RL25-AI-10/RL25-AI-30/RL25-AI-50/RL25-AI-120 Short Range White-Light Illuminator
    £221.34 Incl VAT Excl VAT. £184.45
    Built to Order
    The RL25 is a short range white-light illuminator with optional angles (10˚/30˚/50˚/ 120˚). These illuminators are designed to give even illumination and excellent images for night time surveillance. The RL25 is supplied with a bracket and is designed for low light installations with working distances up to 35m.
    raymax banner
  14. rayTEC RL300-AI-PAN Long Range White-Light Panoramic Illuminator
    Built to Order
    The RL300-AI-PAN provides ultra-wide 180˚ illumination making it the perfect illuminator for PTZs, multi-sensor and wide angled cameras covering large areas. The holographic lenses produce excellent even illumination up to 83m and are adaptive allowing the angle of illumination to be quickly and easily adjusted.
    raylux banner
  15. rayTEC RL150-AI-PAN Long Range White-Light Panoramic Illuminator
    Built to Order
    The RL150-AI-PAN provides ultra-wide 180˚ illumination making it the perfect illuminator for PTZs, multi-sensor and wide angled cameras covering large areas. The holographic lenses produce excellent even illumination up to 83m and are adaptive allowing the angle of illumination to be quickly and easily adjusted.
    raylux banner
  16. rayTEC VAR2-IPPoE-hy4-1 Medium Range Hybrid Network Illuminator
    £335.58 Incl VAT Excl VAT. £279.65
    Built to Order
    The rayTEC VAR2-IPPoE-hy4-1 is designed to improve video surveillance at night with semi covert IR LEDs that can reach distances of 130m and white-lights that can reach up to 70m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE+ input for easy integration with existing network structures. The VAR2-IPPOE-hy4-1 provides the ultimate solution for smart, situation-dependent lighting and is perfect for use with IP cameras. The illuminator can be programmed to automatically deliver the exact amount of light where and when it is needed.
    raytec ippoe hybrid banner
    rayTEC Bracket GuiderayTEC VARIO2 IP Hybrid Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure Learn More
  17. rayTEC VAR2-IPPoE-hy6-1 Medium Range Hybrid Network Illuminator
    £442.68 Incl VAT Excl VAT. £368.90
    Built to Order
    The rayTEC VAR2-IPPoE-hy6-1 is designed to improve video surveillance at night with semi covert IR LEDs that can reach distances of 180m and white-lights that can reach up to 88m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE+ input for easy integration with existing network structures. The VAR2-IPPOE-hy6-1 provides the ultimate solution for smart, situation-dependent lighting and is perfect for use with IP cameras. The illuminator can be programmed to automatically deliver the exact amount of light where and when it is needed.
  18. rayTEC VAR2-IPPoE-hy8-1 Long Range Hybrid Network Illuminator
    £564.06 Incl VAT Excl VAT. £470.05
    Built to Order
    The rayTEC VAR2-IPPoE-hy8-1 is designed to improve video surveillance at night with semi covert IR LEDs that can reach distances of 290m and white-lights that can reach up to 144m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE++ input for easy integration with existing network structures. The VAR2-IPPOE-hy8-1 provides the ultimate solution for smart, situation-dependent lighting and is perfect for use with IP cameras. The illuminator can be programmed to automatically deliver the exact amount of light where and when it is needed.
  19. ayTEC VAR2-i16-1 Long Range Infra-Red Illuminator
    rayTEC VAR2-hy16-1 Long Range Hybrid Illuminator
    £735.42 Incl VAT Excl VAT. £612.85
    Built to Order
    The rayTEC VAR2-hy16-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 450m with IR and 195m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    raytec vario2 hybrid banner
    rayTEC Bracket GuiderayTEC VARIO2 Hybrid Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure Learn More
  20. rayTEC VAR2-hy4-1 Medium Range Hybrid Illuminator
    £285.60 Incl VAT Excl VAT. £238.00
    Built to Order
    The rayTEC VAR2-hy4-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 130m with IR and 70m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
  21. rayTEC VAR2-hy6-1 Medium Range Hybrid Illuminator
    £392.70 Incl VAT Excl VAT. £327.25
    Built to Order
    The rayTEC VAR2-hy6-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 180m with IR and 88m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
  22. rayTEC VAR2-hy8-1 Medium Range Hybrid Illuminator
    £512.65 Incl VAT Excl VAT. £427.21
    Built to Order
    The rayTEC VAR2-hy8-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 290m with IR and 144m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
  23. rayTEC VAR2-VLK-i4-2 Fully Integrated Illumination & Camera Housing
    rayTEC VAR2-VLK-hy6-2 Fully Integrated Infra-Red and White-Light Illumination & Camera Housing
    £778.26 Incl VAT Excl VAT. £648.55
    Built to Order
    The VAR2-VLK-hy6-2 is a fully integrated lighting, camera housing and bracket solution that offers a maximum distance of 54m. It includes two inbuilt IR LED and white-light illuminators along with housing for 2 cameras. This solution uses rayTEC's adaptive illumination technology that allows the user to adjust the angle of light projection easily and includes 10° x 10°, 35° x 10° and 60° x 25° lenses.
    Learn More
Grid  List
