IP CCTV Lighting
Sidebar
IP CCTV Lighting
Network-connected infra-red and white LED CCTV lighting for use with power over ethernet switches and injectors.
Grid  List
  1. rayTEC VAR-DZ-w8-1 Medium Range Remotely Adaptive White-Light Illuminator
    £601.20 Incl VAT Excl VAT. £501.00
    Built to Order
    The rayTEC VAR-DZ-w8-1 is a white-light illuminator which can be remotely adjusted via a volt-free input. The angle can be changed anywhere between 10° and 80° allowing the user to precisely match the required field of view. This illuminator has a max distance of 90m and utilizes rayTEC's hot-spot reduction technology to deliver light to where it is most needed.
    raytec vario banner
    rayTEC Bracket GuiderayTEC Distance and Angle CalculatorrayTEC Product Overview Learn More
Grid  List
