IP CCTV Lighting
Sidebar
IP CCTV Lighting
Network-connected infra-red and white LED CCTV lighting for use with power over ethernet switches and injectors.
Grid  List
  1. rayTEC VAR2-VLK-i4-2 Fully Integrated Illumination & Camera Housing
    rayTEC VAR2-VLK-hy6-2 Fully Integrated Infra-Red and White-Light Illumination & Camera Housing
    £778.26 Incl VAT Excl VAT. £648.55
    Built to Order
    The VAR2-VLK-hy6-2 is a fully integrated lighting, camera housing and bracket solution that offers a maximum distance of 54m. It includes two inbuilt IR LED and white-light illuminators along with housing for 2 cameras. This solution uses rayTEC's adaptive illumination technology that allows the user to adjust the angle of light projection easily and includes 10° x 10°, 35° x 10° and 60° x 25° lenses.
    raytec vario2 banner
    rayTEC Bracket GuiderayTEC VARIO2 Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure
    Learn More
  2. rayTEC VAR2-hy8-1 Medium Range Hybrid Illuminator
    £512.65 Incl VAT Excl VAT. £427.21
    Built to Order
    The rayTEC VAR2-hy8-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 290m with IR and 144m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    raytec vario2 hybrid banner
    rayTEC Bracket GuiderayTEC VARIO2 Hybrid Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure Learn More
  3. rayTEC VAR2-hy6-1 Medium Range Hybrid Illuminator
    £392.70 Incl VAT Excl VAT. £327.25
    Built to Order
    The rayTEC VAR2-hy6-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 180m with IR and 88m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
  4. rayTEC VAR2-hy4-1 Medium Range Hybrid Illuminator
    £285.60 Incl VAT Excl VAT. £238.00
    Built to Order
    The rayTEC VAR2-hy4-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 130m with IR and 70m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
  5. ayTEC VAR2-i16-1 Long Range Infra-Red Illuminator
    rayTEC VAR2-hy16-1 Long Range Hybrid Illuminator
    £735.42 Incl VAT Excl VAT. £612.85
    Built to Order
    The rayTEC VAR2-hy16-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 450m with IR and 195m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
  6. rayTEC VAR2-XTR-w8-1 Extreme Long Range White Light Illuminator
    £539.78 Incl VAT Excl VAT. £449.82
    Built to Order
    The rayTEC VAR2-w8-XTR-1 is an illuminator from the VARIO2 range which is designed to provide extreme durability to video surveillance systems at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 180m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  7. rayTEC VAR2-XTR-w16-1 Extreme Long Range White-Light Illuminator
    £785.40 Incl VAT Excl VAT. £654.50
    Built to Order
    The rayTEC VAR2-w16-XTR-1 is an illuminator from the VARIO2 range which is designed to provide extreme durability to video surveillance systems at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 250m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  8. rayTEC VAR2-VLK-i4-2 Fully Integrated Illumination & Camera Housing
    rayTEC VAR2-VLK-w4-2 Fully Integrated White-Light Illumination & Camera Housing
    £706.86 Incl VAT Excl VAT. £589.05
    Built to Order
    The VAR2-VLK-w4-2 is a fully integrated lighting, camera housing and bracket solution that offers a maximum distance of 155m. It includes two inbuilt white-light illuminators along with housing for 2 cameras. This solution uses rayTEC's adaptive illumination technology that allows the user to adjust the angle of light projection easily and includes 10° x 10°, 35° x 10° and 60° x 25° lenses.
    Learn More
  9. rayTEC VAR2-w2-1 Short Range White-Light Illuminator
    £185.64 Incl VAT Excl VAT. £154.70
    Built to Order
    The rayTEC VAR2-i2-1 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 60m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  10. rayTEC VAR2-PoE-w2-1 Short Range White-Light PoE Illuminator
    £177.07 Incl VAT Excl VAT. £147.56
    Built to Order
    The rayTEC VAR2-PoE-w4-1 is designed to improve video surveillance at night for internal and external applications offering an easy plug-and-play solution. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included that will illuminate distances up to 42m and has a PoE input for easy integration with existing network structures.
    raytec vario2 poe banner
    rayTEC Bracket GuiderayTEC VARIO2 Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure Learn More
  11. rayTEC VAR2-PoE-w4-1 Medium Range White-Light PoE Illuminator
    £251.33 Incl VAT Excl VAT. £209.44
    Built to Order
    The rayTEC VAR2-PoE-w4-1 is designed to improve video surveillance at night for internal and external applications offering an easy plug-and-play solution. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included that will illuminate distances up to 110m and has a PoE+ input for easy integration with existing network structures.
  12. rayTEC VAR2-PoE-i8-1 Long Range Infra-Red PoE Illuminator
    rayTEC VAR2-PoE-w8-1 Long Range White-Light PoE Illuminator
    £465.53 Incl VAT Excl VAT. £387.94
    Built to Order
    The rayTEC VAR2-PoE-w8-1 is designed to improve video surveillance at night for internal and external applications offering an easy plug-and-play solution. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included that will illuminate distances up to 180m and has a PoE++ input for easy integration with existing network structures.
  13. rayTEC VAR2-i8-1 Long Range Infra-Red Illuminator
    rayTEC VAR2-XTR-i8-1 Extreme Long Range Infra-Red Illuminator
    Built to Order
    The rayTEC VAR2-i8-XTR-1 is an illuminator from the VARIO2 range which is designed to provide extreme durability to video surveillance systems at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 350m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  14. ayTEC VAR2-i16-1 Long Range Infra-Red Illuminator
    rayTEC VAR2-XTR-i16-1 Extreme Long Range Infra-Red Illuminator
    Built to Order
    The rayTEC VAR2-i16-XTR-1 is an illuminator from the VARIO2 range which is designed to provide extreme durability to video surveillance systems at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 500m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  15. rayTEC VAR2-VLK-i4-2 Fully Integrated Illumination & Camera Housing
    rayTEC VAR2-VLK-i6-2 Fully Integrated Infra-Red Illumination & Camera Housing
    £849.66 Incl VAT Excl VAT. £708.05
    Built to Order
    The VAR2-VLK-i6-2 is a fully integrated lighting, camera housing and bracket solution that offers a maximum distance of 282m. It includes two inbuilt IR LED illuminators along with housing for 2 cameras. This solution uses rayTEC's adaptive illumination technology that allows the user to adjust the angle of light projection easily and includes 10° x 10°, 35° x 10° and 60° x 25° lenses.
    Learn More
  16. rayTEC VAR2-VLK-i4-2 Fully Integrated Illumination & Camera Housing
    rayTEC VAR2-VLK-i4-2 Fully Integrated Infra-Red Illumination & Camera Housing
    Built to Order
    The VAR2-VLK-i4-2 is a fully integrated lighting, camera housing and bracket solution that offers a maximum distance of 220m. It includes two inbuilt IR LED illuminators along with housing for 2 cameras. This solution uses rayTEC's adaptive illumination technology that allows the user to adjust the angle of light projection easily and includes 10° x 10°, 35° x 10° and 60° x 25° lenses.
    Learn More
  17. rayTEC VAR2-i8-3 Long Range Adaptive Infra-Red Illuminator
    £1,392.30 Incl VAT Excl VAT. £1,160.25
    Built to Order
    The rayTEC VAR2-i8-3 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 606m. This model features adaptive lights that allows the user to adjust the angle of the light projection with ease. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  18. rayTEC VAR2-i8-2 Long Range Adaptive Infra-Red Illuminator
    £942.48 Incl VAT Excl VAT. £785.40
    Built to Order
    The rayTEC VAR2-i8-2 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 500m. This model features adaptive lights that allows the user to adjust the angle of the light projection with ease. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  19. rayTEC VAR2-i8-1 Long Range Infra-Red Illuminator
    £489.80 Incl VAT Excl VAT. £408.17
    Built to Order
    The rayTEC VAR2-i8-1 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 350m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  20. rayTEC VAR2-i6-3 Long Range Adaptive Infra-Red Illuminator
    £1,056.72 Incl VAT Excl VAT. £880.60
    Built to Order
    The rayTEC VAR2-i6-3 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 346m. This model features adaptive lights that allows the user to adjust the angle of the light projection with ease. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  21. rayTEC VAR2-i4-2 Long Range Adaptive Infra-Red Illuminator
    rayTEC VAR2-i6-2 Long Range Adaptive Infra-Red Illuminator
    £714.00 Incl VAT Excl VAT. £595.00
    Built to Order
    The rayTEC VAR2-i6-2 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 282m. This model features adaptive lights that allows the user to adjust the angle of the light projection with ease. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  22. rayTEC VAR2-i6-1 Long Range Infra-Red Illuminator
    £371.28 Incl VAT Excl VAT. £309.40
    Built to Order
    The rayTEC VAR2-i6-1 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 200m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  23. rayTEC VAR2-i4-3 Long Range Adaptive Infra-Red Illuminator
    £749.70 Incl VAT Excl VAT. £624.75
    Built to Order
    The rayTEC VAR2-i4-3 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 260m. This model features adaptive lights that allows the user to adjust the angle of the light projection with ease. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  24. rayTEC VAR2-i4-2 Long Range Adaptive Infra-Red Illuminator
    £506.94 Incl VAT Excl VAT. £422.45
    Built to Order
    The rayTEC VAR2-i4-2 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 220m. This model features adaptive lights that allows the user to adjust the angle of the light projection with ease. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  25. rayTEC VAR2-i4-1 Medium Range Infra-Red Illuminator
    £264.18 Incl VAT Excl VAT. £220.15
    Built to Order
    The rayTEC VAR2-i4-1 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 144m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  26. rayTEC VAR2-i2-2 Medium Range Adaptive Infra-Red Illuminator
    £357.00 Incl VAT Excl VAT. £297.50
    Built to Order
    The rayTEC VAR2-i2-2 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 120m. This model features adaptive lights that allows the user to adjust the angle of the light projection with ease. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  27. rayTEC VAR2-i2-1 Short Range Infra-Red Illuminator
    Built to Order
    The rayTEC VAR2-i2-1 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 78m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  28. ayTEC VAR2-i16-1 Long Range Infra-Red Illuminator
    rayTEC VAR2-i16-1 Long Range Infra-Red Illuminator
    Built to Order
    The rayTEC VAR2-i16-1 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 500m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    Learn More
  29. rayTEC VAR2-PoE-i8-1 Long Range Infra-Red PoE Illuminator
    Built to Order
    The rayTEC VAR2-PoE-i8-1 is designed to improve video surveillance at night with semi covert 850nm IR LEDs that can reach distances of 350m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE++ input for easy integration with existing network structures.
  30. rayTEC VAR2-PoE-i6-1 Long Range Infra-Red PoE Illuminator
    £352.72 Incl VAT Excl VAT. £293.93
    Built to Order
    The rayTEC VAR2-PoE-i6-1 is designed to improve video surveillance at night with semi covert 850nm IR LEDs that can reach distances of 200m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE+ input for easy integration with existing network structures.
  31. rayTEC VAR2-PoE-i4-1 Medium Range Infra-Red PoE Illuminator
    Built to Order
    The rayTEC VAR2-PoE-i4-1 is designed to improve video surveillance at night with semi covert 850nm IR LEDs that can reach distances of 144m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE+ input for easy integration with existing network structures.
  32. rayTEC VAR2-PoE-i2-1 Short Range Infra-Red PoE Illuminator
    £176.40 Incl VAT Excl VAT. £147.00
    Built to Order
    The rayTEC VAR2-PoE-i2-1 is designed to improve video surveillance at night with semi covert 850nm IR LEDs that can reach distances of 62m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE input for easy integration with existing network structures.
Grid  List
