POE Switches
A POE Switch shares network connection through multiple devices.
£454.80 Incl VAT Excl VAT. £379.00
£259.61 Incl VAT Excl VAT. £216.34
In Stock
£689.08 Incl VAT Excl VAT. £574.23
In Stock
£475.04 Incl VAT Excl VAT. £395.87
In Stock
£997.03 Incl VAT Excl VAT. £830.86
In Stock
£1,668.16 Incl VAT Excl VAT. £1,390.13
In Stock
£1,610.16 Incl VAT Excl VAT. £1,341.80
In Stock
£2,691.43 Incl VAT Excl VAT. £2,242.86
In Stock
Stock due late March
The DS-3E0318P-E is a 16 port PoE switch designed to help you expand your network by automatically detecting and supplying power with all PoE and PoE+ compliant powered devices. Up to eight ports can act as a 250m PoE extender when "Extend mode" is ON.£117.24 Incl VAT Excl VAT. £97.70
£133.20 Incl VAT Excl VAT. £111.00
£132.30 Incl VAT Excl VAT. £110.25
£318.24 Incl VAT Excl VAT. £265.20
£269.12 Incl VAT Excl VAT. £224.27
£507.59 Incl VAT Excl VAT. £422.99
£409.20 Incl VAT Excl VAT. £341.00
£646.58 Incl VAT Excl VAT. £538.82
£386.40 Incl VAT Excl VAT. £322.00
The T2600G-28MPS provides 24 10/100/1000Mbps ports that support 802.3at/af-compliant PoE, with a total PoE power supply of up to 384W, giving users the power and exibility to deploy wireless access points or IP-based network surveillance cameras. Learn More
£72.00 Incl VAT Excl VAT. £60.00
The Netgear GS305P provides easy, reliable and affordable network connectivity for home and small offices. This unmanaged plug and play switch enables users to expand their network connections to multiple devices instantly.
£238.80 Incl VAT Excl VAT. £199.00
The Netgear GS510TLP is an 8 port gigabit smart managed switch with PoE+ and 2 SFP ports. With a fanless design, the GS510TLP supports silent desktop operation or rack mounting.
£357.60 Incl VAT Excl VAT. £298.00
The Netgear GS510TPP gigabit PoE+ switch has a 190W PoE budget, 20gbps bandwidth, and temperature and load based fan speed control which combines accurate monitoring with minimised system acoustic noise.
£138.00 Incl VAT Excl VAT. £115.00
The Netgear GS110TP 10 port gigabit smart managed switch has been designed for customers who need a low port density solution with the combination of Gigabit speed and PoE capability.
£261.60 Incl VAT Excl VAT. £218.00
The Netgear GS516TP is a Smart Managed Switch with both PoE/PD features. It can work as a PD device that can get power power from other PSE devices through port 15/16 as well as delivering power to other PDs that are connected to its PoE ports (Ports 1-8).
£424.80 Incl VAT Excl VAT. £354.00
The Netgear GS728TP is a Gigabit PoE/PoE+ switch with PoE capabilities on all ports and supports PoE+ on ports 1-8.
£519.60 Incl VAT Excl VAT. £433.00
The Netgear GS728TPP Gigabit PoE+ Smart Managed Switch comes with 24 PoE+ ports and a total PoE power budget of 384W.
£735.60 Incl VAT Excl VAT. £613.00
The Netgear GS752TP is a Gigabit PoE/PoE+ Smart Managed Switch that comes with PoE capabilities on all ports and supports PoE+ up to a 30W budget on ports 1-8.
£164.40 Incl VAT Excl VAT. £137.00
The Netgear GSS108EPP wed managed gigabit ethernet click switches are uniquely designed with an industry first, bracket mounting system for easy installation.
£276.00 Incl VAT Excl VAT. £230.00
The Netgear ProSAFE GS408EPP is an 8 port gigabit ethernet PoE+ web managed switch. This switch features a Virtually Anywhere mounting system that allows you to put this easy mount switch up int the ceiling, strapped to a pole, or mounted under a desk or tabletop.
£218.40 Incl VAT Excl VAT. £182.00
The Netgear JGS516PE is a 16 port gigabit web managed plus switch providing its users with fundamental network features such as; VLANs, QOS and IGMP Snooping.
£302.40 Incl VAT Excl VAT. £252.00
The Netgear JGS524PE is a 24 port gigabit web managed plus switch with PoE and the ability to power devices such as IP phones, IP surveillance cameras and wireless access points with an ethernet cable.
£206.40 Incl VAT Excl VAT. £172.00
The Netgear FS728TLP is a 28 Port fast ethernet smart managed switch offers a comprehensive L2 features set and enhanced performance and usability.
£258.00 Incl VAT Excl VAT. £215.00
The Netgear FS728TP is a 28 Port fast ethernet smart managed switch offers a comprehensive L2 feature set and enhanced performance and usability.
£1,080.00 Incl VAT Excl VAT. £900.00
The Netgear S3300 series are a new generation of gigabit stackable smart managed switches inclusive of 4 10G ports, which can be used for uplinks and or stacking between other S3300 switches.
£1,778.40 Incl VAT Excl VAT. £1,482.00
£760.80 Incl VAT Excl VAT. £634.00
The Netgear Intelligent Edge M4100 series of switches that are ideal for all organisations considering reliable, affordable and simple access layer switching with CLI, advanced scripting and Layer 3 routing.
£504.00 Incl VAT Excl VAT. £420.00
£800.40 Incl VAT Excl VAT. £667.00
£1,179.60 Incl VAT Excl VAT. £983.00
£1,612.80 Incl VAT Excl VAT. £1,344.00
The Netgear M4300 stackable switch series delivers L2/L3/L4 and IPv4/IPv6 cost-effective services for mid-enterprise edge with full PoE+ and SMB core deployments with unrivalled ease of use.
£2,246.40 Incl VAT Excl VAT. £1,872.00
£427.20 Incl VAT Excl VAT. £356.00
The Axis T8508 PoE+ is an 8 port managed Gigabit switch with a compact, fan-less design for installation in noise sensitive environments or to be used as an edge switch. The high PoE power output allows for connection of up to 8 PoE cameras.
£963.60 Incl VAT Excl VAT. £803.00
The Axis T8524 is an easy to install 24 port managed gigabit switch. This switch comes with an integrated DHCP server for automatic assignment of IP addresses and discovery of connected Axis devices. The high PoE output allows for connection of up to 24 PoE cameras.
£1,285.20 Incl VAT Excl VAT. £1,071.00
The Axis T8504-E is an easy to install, compact outdoor switch enabling connection of four PoE powered devices. The SFP port enables fiber connectivity for long distance connections and remote management ensures easy maintenance, reducing support cost and customer down time.
£406.80 Incl VAT Excl VAT. £339.00
The Netgear GS728TPv2 Gigabit Ethernet Switch with 24 PoE+ and 4 SFP ports joins the Netgear Standalone Smart Managed Pro switches family. Cautious spender organisations can now deploy denser PoE+ devices connected to a cost-effective switch, with a reasonable PoE power budget of 190W over 24 port. Temperature and load based fan speed control combines accurate monitoring with minimised system acoustic noise. The GS728TPv2 supports quiet rack mounting operation with a maximum of 27.08dB even at full PoE power with traffic on all ports and 25°C ambient. Learn More
£855.60 Incl VAT Excl VAT. £713.00
The Netgear GS752TPP Gigabit Ethernet Switch with 48 PoE+ and 4 SFP ports join the Netgear Standalone Smart Managed Pro Switches family. Organisations who buy infrastructure for the long term and want future proofing for the unforeseeable can now select a switch with a POE budget of 760W over 48 ports proving more headroom. The Netgear PoE+ Gigabit Smart Managed Pro Switches provide great value, with configurable L2 network features like VLANs and PoE operation scheduling, allowing SMB customers to deploy PoE-based VoIP phones, IP cameras, video-over-IP endpoints and Wireless access points simply and securely. Learn More
£642.00 Incl VAT Excl VAT. £535.00
The Netgear GS752TPv2 Gigabit Ethernet Switch with 48 PoE+ and 4 SFP ports join the Netgear Standalone Smart Managed Pro Switches family. The Netgear PoE+ Gigabit Smart Managed Pro Switches provide great value, with configurable L2 network features like VLANs and PoE operation scheduling, allowing SMB customers to deploy PoE-based VoIP phones, IP cameras, video-over-IP endpoints and Wireless access points simply and securely. Learn More
The TP-Link TL-SG1016PE is a 16-port Gigabit Easy Smart Switch with 8 PoE ports. This switch has been designed with small businesses in mind, specifically ones that require simple network management and PoE function.
The TL-SG1016PE can connect and power up to 8 PoE devices, including IP cameras and IP phones.
Through the web-based user interface and management utility, the switch offers a variety of useful features including; network monitoring, traffic prioritisation and enhanced QoS.
