Accessories
General accessories for a range of manufacturers and camera models.
£66.31 Incl VAT Excl VAT. £55.26
£30.00 Incl VAT Excl VAT. £25.00
Built to Order
£252.00 Incl VAT Excl VAT. £210.00
Built to Order
£194.40 Incl VAT Excl VAT. £162.00
Built to Order
£132.00 Incl VAT Excl VAT. £110.00
Built to Order
£108.00 Incl VAT Excl VAT. £90.00
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
Built to Order
£22.80 Incl VAT Excl VAT. £19.00
Built to Order
£42.00 Incl VAT Excl VAT. £35.00
Built to Order
£38.40 Incl VAT Excl VAT. £32.00
Built to Order
£36.00 Incl VAT Excl VAT. £30.00
Built to Order
Built to Order
Built to Order
£778.26 Incl VAT Excl VAT. £648.55
Built to Order
rayTEC Bracket GuiderayTEC VARIO2 Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure
Learn More£512.65 Incl VAT Excl VAT. £427.21
Built to Order
The rayTEC VAR2-hy8-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 290m with IR and 144m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
£392.70 Incl VAT Excl VAT. £327.25
Built to Order
The rayTEC VAR2-hy6-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 180m with IR and 88m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
£285.60 Incl VAT Excl VAT. £238.00
Built to Order
The rayTEC VAR2-hy4-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 130m with IR and 70m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
£735.42 Incl VAT Excl VAT. £612.85
Built to Order
The rayTEC VAR2-hy16-1 is a hybrid illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 450m with IR and 195m with WL. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
£564.06 Incl VAT Excl VAT. £470.05
Built to Order
The rayTEC VAR2-IPPoE-hy8-1 is designed to improve video surveillance at night with semi covert IR LEDs that can reach distances of 290m and white-lights that can reach up to 144m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE++ input for easy integration with existing network structures. The VAR2-IPPOE-hy8-1 provides the ultimate solution for smart, situation-dependent lighting and is perfect for use with IP cameras. The illuminator can be programmed to automatically deliver the exact amount of light where and when it is needed.
£442.68 Incl VAT Excl VAT. £368.90
Built to Order
The rayTEC VAR2-IPPoE-hy6-1 is designed to improve video surveillance at night with semi covert IR LEDs that can reach distances of 180m and white-lights that can reach up to 88m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE+ input for easy integration with existing network structures. The VAR2-IPPOE-hy6-1 provides the ultimate solution for smart, situation-dependent lighting and is perfect for use with IP cameras. The illuminator can be programmed to automatically deliver the exact amount of light where and when it is needed.
£335.58 Incl VAT Excl VAT. £279.65
Built to Order
The rayTEC VAR2-IPPoE-hy4-1 is designed to improve video surveillance at night with semi covert IR LEDs that can reach distances of 130m and white-lights that can reach up to 70m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE+ input for easy integration with existing network structures. The VAR2-IPPOE-hy4-1 provides the ultimate solution for smart, situation-dependent lighting and is perfect for use with IP cameras. The illuminator can be programmed to automatically deliver the exact amount of light where and when it is needed.
£892.50 Incl VAT Excl VAT. £743.75
Built to Order
£1,249.50 Incl VAT Excl VAT. £1,041.25
Built to Order
£221.34 Incl VAT Excl VAT. £184.45
Built to Order
£349.86 Incl VAT Excl VAT. £291.55
Built to Order
£556.92 Incl VAT Excl VAT. £464.10
Built to Order
Built to Order
Built to Order
Built to Order
£601.20 Incl VAT Excl VAT. £501.00
Built to Order
£539.78 Incl VAT Excl VAT. £449.82
Built to Order
Learn More£785.40 Incl VAT Excl VAT. £654.50
Built to Order
Learn More£706.86 Incl VAT Excl VAT. £589.05
Built to Order
Learn More
