Sidebar
Axis IP Cameras
With more than two decades of experience in networking technologies, the largest installed base of network video products, as well as strong partnerships with leading players across all continents, Axis is the partner of choice in network video.
Discuss and learn more in our Axis IP camera Forum.
Grid  List
  1. Axis F1004 Bullet Sensor Unit 0935-001
    £126.00 Incl VAT Excl VAT. £105.00
    In Stock
    The Axis F1004 is a bullet sensor unit designed for discreet indoor installations on both ceilings and walls. The F1004 comes with a detachable 8m cable for connection to an Axis F main unit.
    This product requires an Axis F main unit for use.
    -Installation guide - Detachable 8m cable
    Axis F1004 Bullet Installation Guide Axis Product Comparison Table Learn More
  2. Axis F44 Dual Audio Input Main Unit 0936-001
    £549.26 Incl VAT Excl VAT. £457.72
    In Stock
    The Axis F44 dual input main unit can connect up to four sensor units streaming 1080p or HDTV 720p videos simultaneously through one Ethernet port. This product is ideal for the monitoring of four closely situated areas such as; shops, schools, banks and on public transport.
    - Axis stereo-to-mono adaptor - Installation guide - Windows decoder 1-user license - AVHS authentication key
    Axis F44 Installation Guide Axis F44 User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  3. Axis Q3505-SVE Mk II 1080p Outdoor Stainless Steel Vandal Resistant Fixed Dome Network Camera
    £1,443.60 Incl VAT Excl VAT. £1,203.00
    In Stock
    The Axis Q3505-SVE Mk II is an outdoor ready vandal resistant fixed dome with 1080p resolution at up to 60fps with WDR on (can record up to 120fps if set to 720p and with WDR off). This model is varifocal and comes in 2 different focal lengths (3~9mm / 9~22mm) this makes the camera very flexible to different set-up environments.
    As already mentioned this camera feature WDR, but it also feature Lightfinder technology which combined with the WDR makes it excellent in low light situations, its smart conduit design makes very easy to install and the inclusion of remote zoom and focus eliminates the need for hands-on fine tuning.
    This model features a stainless steel marine-grade casing and is rated IK10+ which means the camera can handle impact forces as high as 50 joules, it is also rate IP69 for weatherproofing, it is the ideal camera for identifying people and other movement in harsh environments like work sites, large factories and detention centre.
    - Installation Guide
    - Mounting bracket
    - Drill hole template
    - Cable gaskets
    - I/O connector
    - Connector guard
    - Axis U-shape conduit adapter
    - Stainless steel Resistorx® TR20 screw bit
    - AXIS T94U02S Mounting Bracket
    - Wall gasket
    Axis Q3505-SVE Mk II Installation Guide Axis Q3505-SVE Mk II User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  4. Axis M1045-LW 2MP Indoor Wireless Cube Camera with IR and Edge Storage 0812-003
    £235.48 Incl VAT Excl VAT. £196.23
    In Stock
    The Axis M1045-LW is a 1080p cube camera with built-in IR illumination for recording in dark conditions. The camera is non-PoE because it features Wireless communication & connection. The camera is designed with 110° horizontal field of view so you can cover a large space with minimal devices and it can also be discreetly installed with the included bracket. other features include DC power supply, WDR and support for micro SD & Edge storage.
    Included Accessories: - Power Supply - Installation Guide - Mount bracket - Table top stand - Windows decoder 1-user license
    Axis M1045-LW User Manual Axis M1045-LW Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  5. Axis M1065-LW 2MP Indoor Wireless Cube Camera with IR and Built-in Microphone 0810-003
    £308.44 Incl VAT Excl VAT. £257.03
    In Stock
    The Axis M1065-LW is a 1080p cube camera with built-in IR illumination for recording in dark conditions. The camera is non-PoE because it features Wireless communication & remote viewing. The camera is designed with 110° horizontal field of view so you can cover a large space with minimal devices and it can also be discreetly installed with the included bracket. other features include DC power supply, WDR and support for micro SD & Edge storage.
    Axis M1065-LW User Manual Axis M1065-LW Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  6. Axis M2025-LE 2MP Outdoor Mini Bullet Camera with Built-in IR - Black 0988-001
    £351.60 Incl VAT Excl VAT. £293.00
    The Axis M2025-LE is a small outdoor-ready mini bullet with 2MP resolution, it features built-in IR illumination that allows you to see up to 15m in the dark. Even with its small size it still has a 115° field of view and can be rotated into Axis' Corridor format allowing for excellent recording of alleyways and corridors, it also features WDR, Zipstream technology and a spacious back box for easy installation.
    Included Accessories: - Installation Guide - Windows decoder 1-user license - Torx L-key - Connector guard
    Axis M2025-LE User Manual Axis M2025-LE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Autumn 2016 Learn More
  7. AXIS T91B21 Wall and Ceiling Bracket - White 5506-611
    Axis T91B21 Wall and Ceiling Bracket - White 5506-611
    £31.20 Incl VAT Excl VAT. £26.00
    In Stock
    The Axis T91B21 is small, discreet and well-designed wall & ceiling bracket that allows for a whole range of cameras to be placed and positioned in almost unlimited number of ways, it is designed with a discreet hole in the base which when combined with a hole drilled in the wall or ceiling (as seen in the video below) you will be able to hide the Ethernet cable away and remove the problem of cables being draped across the floor and walls
    Learn More
  8. AXIS M1065-L 2MP Indoor Cube Camera with IR and Built-in Microphone 0811-001
    Axis M1065-L 2MP Indoor Cube Camera with IR and Built-in Microphone 0811-001
    £282.48 Incl VAT Excl VAT. £235.40
    The Axis M1065-L is a 1080p cube camera with built-in microphone for recording audio, a mini speaker for playing pre-recorded messages and a PIR motion sensor for detecting movement even in dark conditions. The camera can perform well day or night because of its IR cut filter and built-in IR illumination that allow it to see up to 10m in complete darkness, with its 110° horizontal field of view you can cover a large space with minimal devices and it can also be discreetly installed with the included bracket. other features include PoE, WDR and support for micro SD & Edge storage.
    Included Accessories: - Installation Guide - Mount bracket - Table top stand - Windows decoder 1-user license
    Axis M1065-L User Manual Axis M1065-L Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  9. AXIS M2025-LE 2MP Outdoor Mini Bullet Camera with Built-in IR - White 0911-001
    Axis M2025-LE 2MP Outdoor Mini Bullet Camera with Built-in IR - White 0911-001
    In Stock
    Learn More
  10. Axis Camera Station S1048 Mk II 48-Channel 24TB Recorder Rack Server 0202-840
    £10,284.00 Incl VAT Excl VAT. £8,570.00
    In Stock
    The Axis Camera Station S1048 Mk II recorder is an out of the box ready workstation optimized for reliable surveillance up to 4K resolution. Axis S1048 Mk II is preloaded with AXIS Camera Station software with licenses for 32 channels and other necessary system software, all preconfigured to minimize installation time. This product includes 3-year hardware warranty and on-site replacement service.
    Included Accessories: - Installation guide - Power cable for mounting
    Axis S1048 Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  11. Axis Camera Station S1032 Mk II 32-Channel 16TB Recorder Rack Server 0202-830
    £6,943.00 Incl VAT Excl VAT. £5,785.83
    In Stock
    The Axis Camera Station S1032 Mk II recorder is an out of the box ready workstation optimized for reliable surveillance up to 4K resolution. Axis S1032 Mk II is preloaded with AXIS Camera Station software with licenses for 32 channels and other necessary system software, all preconfigured to minimize installation time. This product includes 3-year hardware warranty and on-site replacement service.
    Included Accessories: - Installation guide - Power cable for rack mounting
    Axis S1032 Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  12. AXIS Companion Eye LVE 0880-001
    Axis Companion Eye LVE 0880-001
    £314.50 Incl VAT Excl VAT. £262.08
    In Stock
    The Axis Companion Eye LVE is an outdoor, vandal resistant & weather-proof fixed turret camera that gives high-quality video in HDTV 1080p / 2 MP resolution. The plug & go design of the Companion series combined with the turrets WDR and IR makes it the perfect starting point for any IP camera novice looking to expand their Companion system to cover dark outdoor spaces. It is important to know that Companion products are ONLY compatible with Companion Video Management Software & mobile app.
    Included Accessories: - L-Key Tools - Installation Guide - Windows Decoder 1-user Licence - Connector Guard
    Axis Companion Eye LVE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  13. AXIS P3225-LVE Mk II Outdoor 2MP Fixed Dome Camera with Built-in IR 0955-001
    Axis P3225-LVE Mk II Outdoor 2MP Fixed Dome Camera with Built-in IR 0955-001
    £709.78 Incl VAT Excl VAT. £591.48
    In Stock
    The Axis P3225-LVE Mk II is a 2MP fixed outdoor dome that can achieve up to 1080p resolution video. It comes with a built-in varifocal lens that features remote focus and zoom, eliminating the need for hands-on fine tuning. The camera comes equipped with WDR & Lightfinder technology allowing for excellent video quality in a wide variety of lighting conditions, It also supports Axis' Zipstream technology that greatly reduces storage requirements and bandwidth usage. The P3225-LVE Mk II is a weatherproof & vandal-resistant model with IK10 rating and features built-in IR for recording in almost complete darkness
    Included Accessories: - Installation Guide - Windows decoder 1-user license - Mounting bracket - Cable gasket - Resistorx T20 L-key - Drill template - Connector guard
    Axis P3225-LVE Mk II User Manual Axis P3225-LVE Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  14. AXIS P3225-LV Mk II Indoor 2MP Fixed Dome Camera with Built-in IR 0954-001
    Axis P3225-LV Mk II Indoor 2MP Fixed Dome Camera with Built-in IR 0954-001
    £586.54 Incl VAT Excl VAT. £488.78
    In Stock
    The Axis P3225-LV is a 2MP fixed indoor dome that can achieve up to 1080p resolution video. It comes with a built-in varifocal lens that features remote focus and zoom, eliminating the need for hands-on fine tuning. The camera comes equipped with WDR & Lightfinder technology allowing for excellent video quality in a wide variety of lighting conditions, It also supports Axis' Zipstream technology that greatly reduces storage requirements and bandwidth usage. This model also features built-in IR for recording in almost complete darkness
    Included Accessories: - Installation Guide - Windows decoder 1-user license - Mounting bracket - Cable gasket - Resistor T20 L-key - Drill template - Connector guard
    Axis P3225-LV Mk II User Manual Axis P3225-LV Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  15. AXIS P3225-VE Mk II Outdoor 2MP Fixed Dome Camera 0953-001
    Axis P3225-VE Mk II Outdoor 2MP Fixed Dome Camera 0953-001
    £660.49 Incl VAT Excl VAT. £550.41
    The Axis P3225-VE Mk II is a 2MP fixed outdoor dome that can achieve up to 1080p resolution video. It comes with a built-in varifocal lens that features remote focus and zoom, eliminating the need for hands-on fine tuning. The camera comes equipped with WDR & Lightfinder technology allowing for excellent video quality in a wide variety of lighting conditions, It also supports Axis' Zipstream technology that greatly reduces storage requirements and bandwidth usage. The P3225-VE Mk II is a weatherproof & vandal-resistant model with IK10 rating
    Included Accessories: - Installation Guide - Windows decoder 1-user license - Mounting bracket - Cable gasket - Resistor T20 L-key - Drill template - Connector guard - Weather Shield
    Axis P3225-VE Mk II User Manual Axis P3225-VE Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  16. AXIS P3225-V Mk II Indoor 2MP Fixed Dome Camera 0952-001
    Axis P3225-V Mk II Indoor 2MP Fixed Dome Camera 0952-001
    £534.00 Incl VAT Excl VAT. £445.00
    In Stock
    The Axis P3225-V Mk II is a 2MP fixed indoor dome that can achieve up to 1080p resolution video. It comes with a built-in varifocal lens that features remote focus and zoom, eliminating the need for hands-on fine tuning. The camera comes equipped with WDR & Lightfinder technology allowing for excellent video quality in a wide variety of lighting conditions, It also supports Axis' Zipstream technology that greatly reduces storage requirements and bandwidth usage.
    Axis P3225-V Mk II User Manual Axis P3225-V Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  17. AXIS P3224-LV Mk II Indoor 1MP Fixed Dome Camera with Built-in IR 0990-001
    Axis P3224-LV Mk II Indoor 1MP Fixed Dome Camera with Built-in IR 0990-001
    In Stock
    The Axis P3224-LV is a 1MP fixed indoor dome that can achieve up to 720p resolution video. It comes with a built-in varifocal lens that features remote focus and zoom, eliminating the need for hands-on fine tuning. The camera comes equipped with WDR & Lightfinder technology allowing for excellent video quality in a wide variety of lighting conditions, It also supports Axis' Zipstream technology that greatly reduces storage requirements and bandwidth usage. This model also features built-in IR for recording in almost complete darkness
    Axis P3224-LV Mk II User Manual Axis P3224-LV Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  18. AXIS P3224-V Mk II Indoor 1MP Fixed Dome Camera 0950-001
    Axis P3224-V Mk II Indoor 1MP Fixed Dome Camera 0950-001
    £444.80 Incl VAT Excl VAT. £370.67
    The Axis P3224-V is a 1MP fixed indoor dome that can achieve up to 720p resolution video. It comes with a built-in varifocal lens that features remote focus and zoom, eliminating the need for hands-on fine tuning. The camera comes equipped with WDR & Lightfinder technology allowing for excellent video quality in a wide variety of lighting conditions, It also supports Axis' Zipstream technology that greatly reduces storage requirements and bandwidth usage.
    Axis P3224-V Mk II User Manual Axis P3224-V Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  19. AXIS T91G61 Wall Mount 5506-951
    Axis T91G61 Wall Mount 5506-951
    £187.20 Incl VAT Excl VAT. £156.00
    The Axis T91G61 is wall bracket designed for PTZ and multi-sensor cameras, The bracket has space built-in to accommodate and safely protect any accessory that will fit such as a midspan or service loop. The bracket comes with a pre-installed RJ45 Ethernet cable with IP66 protection to make the installation quick, easy and durable. Thes design and build of the T91G61 makes it the perfect for all conditions, indoors or outdoors.
    Included Accessories: - Installation Guide - Ethernet cable with IP66 RJ45 connector (with gasket) - Foam gaskets and Silicone strap (pre-mounted)
    Axis T91G61 Installation Guide
    Learn More
  20. AXIS Q6155-E 2MP Outdoor PTZ Dome with Laser Focus 0933-003
    Axis Q6155-E 2MP Outdoor PTZ Dome with Laser Focus 0933-003
    £3,426.00 Incl VAT Excl VAT. £2,855.00
    The Axis Q6155-E is an outdoor-ready PTZ dome with built-in laser that allows for instant focus in up to complete darkness. it also produces top level visuals at 1080p / 2MP resolution at 30 fps, with 30x optical zoom, This model features the new Axis Sharpdome technology & Lightfinder technology that give you perfect image quality in all directions, even in low-light conditions. It also comes with speed dry function that easily clears water drops and condensation from the dome glass, providing sharp images in rainy weather.
    Included Accessories: - IP66-rated RJ45 connector kit - High PoE Midspan 1-port - Installation Guide - Windows decoder 1-user license
    Axis Q6155-E User Manual Axis Q6155-E Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  21. AXIS Companion Eye L 0881-001
    Axis Companion Eye L 0881-001
    £289.14 Incl VAT Excl VAT. £240.95
    In Stock
    The Axis Companion Eye L is an indoor, vandal resistant fixed turret camera that gives high-quality video in HDTV 1080p / 2 MP resolution. The plug & go design of the Companion series combined with the turrets WDR and IR makes it the perfect starting point for any IP camera novice looking to expand their Companion system to cover dark indoor spaces. It is important to know that Companion products are ONLY compatible with Companion Video Management Software & mobile app.
    Axis Companion Eye L Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  22. Axis Q6000-E Mk II 8MP 360° PTZ Dome Camera 01005-001
    Axis Q6000-E Mk II 8MP 360° PTZ Multi-sensor Camera 01005-001
    £1,712.40 Incl VAT Excl VAT. £1,427.00
    The Axis Q6000-E Mk II features 4 x 2MP sensors, providing a complete 360° field of view over large areas. Integrated with an Axis Q60-E camera it is an ideal solution for capturing details of interest without missing the big picture. The Q6000-E is an ideal solution for city surveillance in market squares, car parks, and large open areas such as food courts in shopping centres. Please note the Axis Q60-E, mounting bracket & M12 Lenses are sold separately
    Included Accessories: - Ethernet adaptor - Bayonet screws - Installation guide - Installation and management software CD - Windows decoder 1-user license
    Axis Q6000-E Mk II User Manual Axis Q6000-E Mk II Installation Guide Axis M12 Lens Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  23. Axis P5635-E Mk II PTZ Dome Network Camera 0930-001
    Axis P5635-E Mk II Outdoor PTZ Dome Network Camera 0930-001
    £2,001.80 Incl VAT Excl VAT. £1,668.17
    In Stock
    The Axis P5635-E is a cost-effective, high-performance pan tilt zoom dome network camera with 30x optical zoom. The camera allows high definition video surveillance of large indoor and outdoor areas and provides great detail when zooming in, making the P5635-E ideal for use for city surveillance. The Mk II model can now handle up to 50fps at 720p resolution.
    - RJ45 push-pull connector (IP66) - Hard ceiling mount - Spring pipe adaptor - U-profile pipe adaptor - Installation guide - Windows decoder 1-user license - AVHS authentication key
    Please Note: Axis do not include a wall-mount bracket with this camera (as detailed in their datasheet), you can find a selection of appropriate accessories in the FBT section below.
    Axis P5635-E Mk II User Manual Axis P5635-E Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  24. AXIS T8516 PoE+ 16 Channel Network Switch 5801-693
    Axis T8516 16-Channel PoE+ Network Switch 5801-693
    £748.80 Incl VAT Excl VAT. £624.00
    In Stock
    The Axis T8516 is a 16 channel PoE+ network switch that is easy to install with its automated Axis device discovery and automatic IP address assignment, the switch offers clear and simplistic graphic topology for easy overview of your entire system and the devices that are part of it. The high PoE power output makes it possible to connect up to 16 PoE devices.
    - Installation Guide - Power cord - 19” ear rack kit - Rubber feet (4x) - SFP dust cover (2x)
    This camera is currently not stocked by our distributors and so has a 10-14 day lead time for delivery.
    AXIS T8516 Installation Guide Axis Product Comparison Table
    Learn More
  25. AXIS M3044–WV Dome Network Camera
    Axis M3044-WV 1MP Wireless Dome Network Camera 0803-003
    £243.60 Incl VAT Excl VAT. £203.00
    The palm-sized Axis M3044-WV is one of the best vandal & dust-resistant indoor cameras in this price bracket, it offers HDTV 720p resolution and a Wide dynamic range(WDR) that ensures that both the dark and bright areas of the scene are visible. This model also allows for remote connection via wireless LAN.
    Included Accessories: - Power supply - Installation Guide - Windows decoder 1-user license - Torx L-key
    AXIS M3044-WV User Manual AXIS M3044-WV Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  26. AXIS M3045–WV Dome Network Camera
    Axis M3045-WV 2MP Wireless Dome Network Camera 0805-003
    £319.20 Incl VAT Excl VAT. £266.00
    The palm-sized Axis M3045-WV is one of the best vandal & dust-resistant indoor cameras in this price bracket, it offers HDTV 1080p resolution and a Wide-dynamic range(WDR) that ensures that both the dark and bright areas of the scene are visible. This model also allows for remote connection via wireless LAN.
    AXIS M3045-WV User Manual AXIS M3045-WV Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Learn More
  27. AXIS T8331-E Outdoor PIR Motion Detector - 5506-941
    Axis T8331-E Outdoor PIR Motion Detector - 5506-941
    £138.00 Incl VAT Excl VAT. £115.00
    In Stock
    The Axis T8331-E is an outdoor PIR motion detector which allows your camera set-up to react to motion within its visible range, this is an advantage to smaller systems as you can set your system only record when motion is detected which saves on storage space and bandwidth, as well as extending the period of time you can keep stored on your NVR or NAS.
    The passive infrared technology used in this motion detector makes it much more accurate with less false alarms than any older models. The T8331-E is simple and quick to set-up with its single cable design and the included tripod mount makes it easy to mount to any standard wall bracket.
    - Installation Guide - Tripod Thread Bracket - Mounting Bracket
    Axis T8331-E User Manual Axis T8331-E Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  28. AXIS T8331 Indoor PIR Motion Detector - 5506-931
    Axis T8331 Indoor PIR Motion Detector - 5506-931
    £42.00 Incl VAT Excl VAT. £35.00
    In Stock
    The Axis T8331 is an indoor PIR motion detector which allows your camera set-up to react to motion within its visible range, this is an advantage to smaller systems as you can set your system only record when motion is detected which saves on storage space and bandwidth, as well as extending the period of time you can keep stored on your NVR or NAS. The passive infrared technology used in this motion detector makes it much more accurate with less false alarms than any older models. The T8331 is simple and quick to set-up with its single cable design and the included tripod mount makes it easy to mount to any standard wall bracket.
    Included Accessories: - Installation Guide - Tripod Thread Bracket - Mounting Bracket
    Axis T8331 User Manual Axis T8331 Installation Guide Axis Product Comparison Table
    Learn More
  29. Axis P5624-E Mk II Outdoor PTZ Dome Network Camera 0931-001
    £1,698.00 Incl VAT Excl VAT. £1,415.00
    In Stock
    The Axis P5624-E is a cost effective outdoor-ready pan tilt zoom dome network camera with 23x optical zoom. It enables video surveillance of large indoor and outdoor areas with its continuous 360° pan and provides great details when zooming in, this camera is ideal for use in retail surveillance. It also features focus recall allowing for instant focus in predefined area, WDR for goo low light performance and Axis' Zipstream technology that reduces your storage requirements.
    - RJ45 push-pull connector (IP66) - Hard ceiling mount - Axis P5624-E smoked dome - Spring pipe adaptor - U-profile pipe adaptor - Installation guide - Windows decoder 1-user license - AVHS authentication key
    Axis P5624-E Mk II User Manual Axis P5624-E Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  30. Axis P1435-LE 10~22mm Network Camera 0890-001
    £697.20 Incl VAT Excl VAT. £581.00
    In Stock
    The Axis P1435-LE provides excellent image quality in HDTV 1080p resolution and a varifocal range of 10~22mm. The camera features corridor format, pixel counter, remote zoom and focus. Axis' Zipstream technology reduces bandwidth and storage requirements. The P1435-LE is outdoor ready and comes with an adjustable weather shield.
    - Mounting bracket - Weather Shield L - Drill template - Installation Guide - Windows decoder 1-user license
    Axis P1435-LE Network Camera User Manual Axis P1435-LE Network Camera Installation GuideAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  31. AXIS C2005 Network Ceiling Speaker 0834-001
    Axis C2005 Network Ceiling Speaker 0834-001
    £427.20 Incl VAT Excl VAT. £356.00
    In Stock
    The Axis C2005 network speaker is an all-in-one system that allows the operator to not only play back audio tracks, but also broadcast live verbal commands and receive audio through its built-in microphone.
    The speaker is ready out-of-the-box to produce high quality audio without any fine-tuning. Background music can be played via the pre-installed AXIS Audio Player application, but if you wish to play your own audio tracks you can install an SD card with them on or stream them through supported third-party streaming services.
    The speaker can also be used for voice announcements (scheduled or live) and with its built-in audio synchronization technology multiple speakers can be linked together.
    - AXIS Camera Station license key
    This camera is currently not stocked by our distributor and so has a 10-14 day lead time for delivery.
    AXIS C2005 Installation Guide How-To Guide: Recording & Triggering Audio Messages from the C2005 Axis Product Comparison Table
    Learn More
  32. AXIS C1004-E Network Cabinet Speaker - Black 0823-001
    Axis C1004-E Network Cabinet Speaker - Black 0923-001
    £588.00 Incl VAT Excl VAT. £490.00
    In Stock
    The Axis C1004-E network speaker is an all-in-one system that allows the operator to not only play back audio tracks, but also broadcast live verbal commands and receive audio through its built-in microphone.
    The speaker can also be used for voice announcements (scheduled or live) and with its built-in audio synchronisation technology multiple speakers can be linked together.
    - cable shoe
    - bracket with screws and washers
    - AXIS Connector Guard A
    AXIS C1004-E Installation Guide How To Guide: Recording & Triggering Audio Messages from the C1004-E Axis Product Comparison Table
    Learn More
  33. AXIS C1004-E Network Cabinet Speaker - White 0833-001
    Axis C1004-E Network Cabinet Speaker - White 0833-001
    - cable shoe
    Learn More
  34. AXIS Q1615-E Mk II Outdoor Network Camera with Intelligent i-CS Lens 0884-001
    Axis Q1615-E Mk II Outdoor Network Camera with Intelligent i-CS Lens 0884-001
    £1,390.80 Incl VAT Excl VAT. £1,159.00
    In Stock
    The Axis Q1615 Mk II is a 1080p resolution camera with Axis' new intelligent i-CS lens that can store lens settings for quick remote or automatic image adjustment (zoom, focus, Iris).
    It uses WDR and lightfinder technology to achieve HDTV images even in the most difficult lighting conditions, it also features Axis' Zipstream Technology that reduces bandwidth and storage requirements. It housing it can record up to 120 fps at 720p and 60fps at 1080p.
    - Stand
    - Connector kit
    - Resistorx T20 tool
    -Installation Guide
    AXIS Q1615-E Installation Guide AXIS Q1615-E User Manual AXIS i-CS Lens: How Does it Work? Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  35. AXIS Q1615 Mk II Indoor Network Camera with Intelligent i-CS Lens 0883-001
    Axis Q1615 Mk II Indoor Network Camera with Intelligent i-CS Lens 0883-001
    £1,069.20 Incl VAT Excl VAT. £891.00
    In Stock
    It uses WDR and lightfinder technology to achieve HDTV images even in the most difficult lighting conditions, it also features Axis' Zipstream Technology that reduces bandwidth and storage requirements, it can record up to 120 fps at 720p and 60fps at 1080p.
    - Stand
    - Connector kit
    AXIS Q1615 Mk II Installation Guide AXIS Q1615 Mk II User Manual AXIS i-CS Lens: How Does it Work? Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  36. AXIS T8061 Ethernet Surge Protector 5801-641
    Axis T8061 Ethernet Surge Protector 5801-641
    £108.00 Incl VAT Excl VAT. £90.00
    In Stock
    The Axis T8061 is an Ethernet surge protector that prevents network devices, such as IP cameras, switches & midspans, from being damaged by electrical surges such as lightning strikes.
    It can be easily installed with either its wall or pole mounts and with its weatherproof casing it can withstand water, dust & ingress of water. The device can either be installed before the cable enters the building to protect indoor devices, or immediately adjacent to outdoor network cameras.
    AXIS T8061 Installation Guide Axis Product Comparison Table
    Learn More
  37. AXIS S2024 All-in-One 24-channel Camera Station with NVR & PoE Switch 0939-002
    Axis S2024 All-in-One 24-channel Camera Station with NVR & PoE Switch 0939-002
    £5,044.39 Incl VAT Excl VAT. £4,203.66
    In Stock
    The Axis S2024 is an out-of-the-box ready compact NVR that features an integrated 24 channel PoE Switch, this model is validated for reliable recording up to 4K. It features 12TB's of sotrage and Axis' Camera Station software that is both user friendly and fully compatible with all AXIS IP products, it can also be integrated with third-party cameras.
    - Mounting brackets
    - Power cable
    AXIS S2024 Installation Guide AXIS S2024 User Manual Axis Product Comparison Table
    Learn More
  38. AXIS S2016 All-in-One 16-channel Camera Station with NVR & PoE Switch 0938-002
    Axis S2016 All-in-One 16-channel Camera Station with NVR & PoE Switch 0938-002
    £4,213.44 Incl VAT Excl VAT. £3,511.20
    In Stock
    The Axis S2016 is an out-of-the-box ready compact NVR that features an integrated 16 channel PoE Switch, this model is validated for reliable recording up to 4K. It features 8TB's of storage and Axis' Camera Station software that is both user friendly and fully compatible with all AXIS IP products, it can also be integrated with third-party cameras.
    - Mounting brackets
    - Power cable
    AXIS S2016 Installation Guide AXIS S2016 User Manual Axis Product Comparison Table
    Learn More
  39. AXIS S2008 All-in-One Camera Station with NVR & PoE Switch 0937-002
    Axis S2008 All-in-One 8-channel Camera Station with NVR & PoE Switch 0937-002
    £2,610.41 Incl VAT Excl VAT. £2,175.34
    In Stock
    The Axis S2008 is an out-of-the-box ready compact NVR that features an integrated 8 channel PoE Switch, this model is validated for reliable recording up to 4K. It features a 4TB HDD and Axis' Camera Station software that is both user friendly and fully compatible with all AXIS IP products, it can also be integrated with third-party cameras.
    - Mounting brackets
    - Power supply
    AXIS S2008 Installation Guide AXIS S2008 User Manual Axis Product Comparison Table
    Learn More
  40. AXIS M3105-LVE Outdoor Mini Dome Network Camera with built-in IR illumination 0868-001
    Axis M3105-LVE Outdoor Mini Dome Network Camera with built-in IR illumination 0868-001
    £373.79 Incl VAT Excl VAT. £311.49
    The Axis M3105-LVE is a 1080p resolution mini dome with a flat-faced design that reduces reflections. It uses WDR and IR illumination to achieve HDTV images even in the most difficult lighting conditions, its sleek and compact design allows for easy installation in a whole variety positions.
    It also features Axis' Zipstream Technology that reduces bandwidth and storage requirements, it is weatherproof up to IP66 and vandal-proof up to IK08.
    AXIS M3105-LVE Installation Guide AXIS M3105-LVE User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  41. AXIS M3105-L Indoor Mini Dome Network Camera with built-in IR illumination 0867-001
    Axis M3105-L Indoor Mini Dome Network Camera with built-in IR illumination 0867-001
    £324.29 Incl VAT Excl VAT. £270.24
    In Stock
    The Axis M3105-L is a 1080p resolution mini dome with a flat-faced design that reduces reflections. It uses WDR and IR illumination to achieve HDTV even in the most difficult lighting conditions, its sleek and compact design allows for easy installation in a whole variety positions.
    It also features Axis' Zipstream Technology that reduces bandwidth and storage requirements.
    AXIS M3105-L Installation Guide AXIS M3105-L User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  42. AXIS M3104-LVE Outdoor Mini Dome Network Camera with built-in IR illumination 0866-001
    Axis M3104-LVE Outdoor Mini Dome Network Camera with built-in IR illumination 0866-001
    In Stock
    The Axis M3104-LVE is a 720p resolution mini dome with a flat-faced design that reduces reflections. It uses WDR and IR illumination to achieve HDTV images even in the most difficult lighting conditions, its sleek and compact design allows for easy installation in a whole variety positions.
    AXIS M3104-LVE Installation Guide AXIS M3104-LVE User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  43. AXIS M3104-L Indoor Mini Dome Network Camera with built-in IR illumination 0865-001
    Axis M3104-L Indoor Mini Dome Network Camera with built-in IR illumination 0865-001
    £265.20 Incl VAT Excl VAT. £221.00
    The Axis M3104-L is a 720p resolution mini dome with a flat-faced design that reduces reflections. It uses WDR and IR illumination to achieve HDTV even in the most difficult lighting conditions, its sleek and compact design allows for easy installation in a whole variety positions.
    AXIS M3104-L Installation Guide AXIS M3104-L User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  44. AXIS Q6055 Indoor PTZ Dome Network Camera 0907-002
    Axis Q6055 Indoor PTZ Dome Network Camera 0907-002
    £2,730.00 Incl VAT Excl VAT. £2,275.00
    The Axis Q6055 is an indoor PTZ dome with 1080p resolution, fast & accurate pan/tilt performance and 32x optical zoom. this model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention. it also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilization, two-way audio, I/O ports and 24V AC/DC power.
    Included Accessories: - Axis PoE+ midspan 1-port
    - Recessed mount for hard and drop ceilings
    - Smoked dome cover
    Axis Q6055 Installation GuideAxis Q6055 User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  45. AXIS Q6055-E Outdoor PTZ Dome Network Camera 0909-002
    Axis Q6055-E Outdoor PTZ Dome Network Camera 0909-002
    £3,319.20 Incl VAT Excl VAT. £2,766.00
    The Axis Q6055-E is an outdoor PTZ dome with 1080p resolution, fast & accurate pan/tilt performance and 32x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
    It also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilization, two-way audio, I/O ports and 24V AC/DC power. As an outdoor model it also features an IP66 weatherproof rating and an IK10 vandal-proof rating.
    Included Accessories: - Axis High PoE 60 W midspan 1-port
    - RJ45 Push-pull Connector (IP66)
    - Sunshield
    Axis Q6055-E Installation GuideAxis Q6055-E User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  46. AXIS Q6052-E Outdoor PTZ Dome Network Camera 0901-002
    Axis Q6052-E Outdoor PTZ Dome Network Camera 0901-002
    £2,784.00 Incl VAT Excl VAT. £2,320.00
    The Axis Q6052-E is an outdoor PTZ dome with D1 resolution, fast & accurate pan/tilt performance and 36x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
    It also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilisation, two-way audio, I/O ports and 24V AC/DC power. As an outdoor model it also features an IP66 weatherproof rating and an IK10 vandal-proof rating.
    - Sunshield
    Axis Q6052 Installation GuideAxis Q1942-E User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  47. AXIS Q6052 Indoor PTZ Dome Network Camera 0899-002
    Axis Q6052 Indoor PTZ Dome Network Camera 0899-002
    £2,154.68 Incl VAT Excl VAT. £1,795.57
    The Axis Q6052 is an indoor PTZ dome with D1 resolution, fast & accurate pan/tilt performance and 36x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
    - Smoked dome cover
    Axis Q6052 Installation GuideAxis Q6052 User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  48. AXIS T94P01B Corner Bracket 5504-711
    Axis T94P01B Corner Bracket 5504-711
    £70.80 Incl VAT Excl VAT. £59.00
    In Stock
    The Axis T94P01B is an aluminium corner bracket for indoors and outdoors use, this is a great bracket for any Axis dome camera with a wide horizontal field of view as it will allow you to see in 2 separate directions.
    This mount is compatible with these adaptors: AXIS P3214-V / AXIS P3214-VE / AXIS P3215-V / AXIS P3215-VE / AXIS P3224-LV / AXIS P3224-LVE / AXIS P3225-LV / AXIS P3225-LVE / AXIS P3364-VE / AXIS P3364-LVE / AXIS P3365-VE / AXIS P3367-VE / AXIS P3384-VE / AXIS P5414-E / AXIS P5415-E / AXIS Q1765-LE / AXIS Q1931-E / AXIS Q1942-E / AXIS Q2901-E / AXIS Q3505-V / AXIS Q3505-VE / AXIS Q3615-VE / AXIS Q3617-VE
    AXIS T94P01B Installation Guide Learn More
  49. AXIS T94B02D Pendant Adaptor Kit 5507-361
    Axis T94B02D Pendant Adaptor Kit 5507-361
    In Stock
    The Axis T94B02D Pendant mounting adaptor allows you mount specific AXIS dome models to a pendant ceiling mount, these style of mounts are perfect for buildings with high or dropped ceilings.
    This mount is compatible with:
    M3044-V / M3045-V / M3046-V / Companion Dome V Learn More
  50. AXIS A8105-E Flush Mount 5801-481
    Axis A8105-E Flush Mount 5801-481
    £74.40 Incl VAT Excl VAT. £62.00
    In Stock
    The Axis A8105-E flush mount is a recessed aluminium mount that allows low profile (possibly invisible if built into a new building) mounting of the A8105-E Network Video Door Station in walls both interior and exterior locations, with matching colour design and screw covers for concealing mounting screws this mount is designed to look both discreet and professional.
    - Screw Covers - Resitorx Screws TR 20 - Installation Guide
    This camera is not yet in stock with our distributors, it can be directly ordered from the manufacturer with a 10-14 day lead-time for delivery.
    Axis A8105-E Flush Mount Installation GuideAxis Product Comparison Table
    Learn More
Grid  List
