Clearance
Selection of IP CCTV products on special clearance offers.
Regular Price: £132.00
Special Price £120.00 Incl VAT Excl VAT. £100.00
Only 1 in stock
User Manual Hikvision R6 Catalogue Hikvision Product Catalogue Hikvision Quick Guide
Regular Price: £106.80
Special Price £96.00 Incl VAT Excl VAT. £80.00
Out of Stock
The Hikvision DS-2CD2042WD-I is a 4MP wide dynamic range mini bullet camera, with an array of IR LEDs for nightvision recording, as well as a number of other features. The camera body is small and discreet, and is easily mounted in most locations making it perfect for business, industry, and domestic use.
The DS-2CD2042WD-I has an IP66 rated housing, making it completely resistant to harsh weather conditions and excellent for both indoor and outdoor use.
The 30m IR range makes it great at covering short-to-medium ranges at night, and the 120dB WDR means that it's very effective at maintaining picture quality against strong backlighting. This is ideal for use within store fronts and homes, where strong glare from outside windows may obscure detail in other cameras.
The camera supports PoE, meaning it can be powered by a single network cable used to connect it to your network. It also supports Hikvision's H.264+ codec, which can reduce bandwidth and storage requirements by up to 50% without sacrificing any quality. Both of these features are fantastic at helping you reduce costs and make the most of your budget.
User Manual Hikvision Product Catalogue Hikvision Quick Guide Hikvision R6 Catalogue
Regular Price: £112.80
Special Price £100.80 Incl VAT Excl VAT. £84.00
Only 1 in stock
The Hikvision DS-2CD2142FWD-I is a 4MP dome camera with the option of either a 2.8mm or 4mm lens. This camera is a great choice for external, domestic applications as it is fitted with IP66 rated weatherproof housing and IK10 vandal resistant housing. There are also built in infra-red LEDs that are effective up to 30m and help this camera to provide high quality images day and night. The DS-2CD2142FWD-I has 3-axis adjustment allowing it to be mounted in versatile ways to ensure that any area of interest can be covered. There is also the optional choice of junction box or bracket to further expand the mounting options available to this camera. This camera uses a range of image enhancing features to improve image quality even further: wide dynamic range (WDR), back light compensation (BLC) and 3D digital noise reduction (3D DNR). The DS-2CD2142FWD-I features a host of alarm trigger features such as motion detection, tampering alarm and many more. Using H.264+ codec, this camera is able to reduce bandwidth and storage needs allowing the on board micro SD card slot to be efficiently used. This dome camera can be powered by either a 12V DC power supply or by PoE. Remote access is possible through a web browser or through the Hik-Connect app.
Hikvision Product Catalogue Hikvision Quick Guide Hikvision R6 Catalogue User Manual
£98.40 Incl VAT Excl VAT. £82.00
Out of Stock
OPEN BOX ~ ONLY 2 AVAILABLE!!
The Hikvision DS-2CD2442FWD-IW is a cube network camera with Wi-Fi support for wireless network transmission, on-board storage via sd card, and IR infrared LEDs for night-vision recording. It has a small, easily adjustable body, and is great for use in homes or small businesses.
Part of Hikvision's Easy IP Solution family of cameras and NVRs, the DS-2CD2442FWD-IW is built to be as simple to setup and use as possible. Mobile monitoring is possible via Hivision's mobile app Hik-Connect, or via their network solution iVMS-4500, making this camera easily scalable and perfect for use either as a standalone security camera, or as part of a larger system.
The camera comes with an in-built microphone and support for two-way audio, allowing you to hear what's being recorded as well as send sound via the camera's speaker, great when used as a baby monitor or to scare away would-be intruders.
This camera support power over ethernet (PoE), meaning that it's able to be powered via the use of a standard Cat5 or Cat6 network cable used to connect it to your network video recorder (NVR). This saves on installation and maintenance costs, and further streamlines the process to make it quick and easy. It also has a 120dB wide dynamic range (WDR) to ensure it captures great quality images even in locations with strong back-lighting, such as by windows or facing store-fronts. The 10m IR range is ideal for most interior locations and ensures you receive 24/7 security.
Click here to see the full range of focal lengths available for the Hikvision DS-2CD2442FWD-IW.
Please note: this camera is suitable for interior use only.
Regular Price: £144.00
Special Price £126.00 Incl VAT Excl VAT. £105.00
Only 1 in stock
Click here to see the full range of focal lengths available for the Hikvision DS-2CD2542FWD-I.
Hikvision User Manual V5.3 Hikvision Product Catalogue Hikvision Quick Guide Hikvision R6 Catalogue
Regular Price: £234.00
Special Price £210.00 Incl VAT Excl VAT. £175.00
Out of Stock
The Hikvision DS-2CD2742FWD-IZS is a black 4 megapixel varifocal vandal proof dome camera with a range of features such as dual streaming, day and night function, digital wide dynamic range, power over ethernet for quick and easy installation, a built-in MicroSD card slot for up to 128GB storage, an IP66 rated housing to protect the camera from outdoor weather conditions and an IK10 rated housing to protect the camera from vandal attempts. The lens is a varifocal lens from 2.8 to 12mm offering adjustable field of views.
Hikvision Product Catalogue Hikvision Quick Guide User Manual Hikvision R6 Catalogue
Regular Price: £117.60
Special Price £105.60 Incl VAT Excl VAT. £88.00
Only 1 in stock
The Hikvision DS-2CD2342WD-I is a 4 megapixel EXIR turret camera with a range of features including; 3D digital noise reduction, 120dB wide dynamic range, 3-axis adjustment, an IR range of up to 30m and an IP66 weatherproof protection. This camera has 3-axis lens adjustment, allowing you full control over how the camera is mounted and the view adjustment; the third axis of adjustment "Rotate:" (aka horizon adjustment) will allow you to bring the view back to level regardless of the pan & tilt adjustments. Hikvision User Manual V5.3 Hikvision Product Catalogue Hikvision Quick Guide Hikvision R6 Catalogue Learn More
Regular Price: £219.32
Special Price £180.00 Incl VAT Excl VAT. £150.00
Only 1 in stock
The Hikvision DS-2CD2742FWD-I is a 4 megapixel varifocal dome network camera with a range of features including 120dB wide dynamic range, 3D digital noise reduction, a built-in microSD card slot for up to 128GB on board storage and and IP66 rated housing to protect the camera against harsh outdoor weather conditions. Hikvision User Manual V5.3 Hikvision Product Catalogue Hikvision Quick Guide Hikvision R6 Catalogue
Learn More
