Hikvision
Hikvision IP Cameras
Sidebar
Hikvision
Hikvision is the UK's leading brand of IP cameras and accessories, and provide the highest quality cameras with the best value for money on the market. Hikvision cameras are available in all shapes and sized and can be used for both domestic or commercial installations. Take a look at the newest EasyIP 3.0 family for a range of 3MP, 5MP and 8MP cameras with a variety of functions that are guaranteed to suit your application!
Grid  List
  1. Hikvision DS-2CD2055FWD-I 5MP Mini Bullet Network Camera
    The Hikvision DS-2CD2055FWD-I is a 5MP mini bullet camera that is available in either a 2.8mm, 4mm or 6mm fixed lens. This camera comes fitted with infra-red LEDs that are effective up to 30m and IP67 rated weatherproof housing. The DS-2CD2055FWD-I also comes with a built in bracket that has 3-axis adjustability so there is a lot of flexibility if you need to cover a wide area. The image is improved using back light compensation (BLC) and 3D digital noise reduction technology (3D DNR). The DS-2CD2055FWD-I also utilises smart features such as motion detection, line crossing detection and intrusion detection to improve security even further. Fitted with Hikvision's H.265+ video compression, the on board SD card slot can be used without worry of using up the memory so quickly. This camera can be powered by 12VDC power supply or PoE, it can be accessed remotely through a browser or by using the Hik-connect app.
    Hikvision Mini Bullet banner for easy IP 3.0 range
  2. Hikvision DS-2CD2035FWD-I 3MP Mini Bullet Network Camera
    The Hikvision DS-2CD2035FWD-I is a 3MP mini bullet camera that is available in either a 2.8mm, 4mm or 6mm fixed lens. This camera comes fitted with infra-red LEDs that are effective up to 30m and IP67 rated weatherproof housing. The DS-2CD2035FWD-I also comes with a built in bracket that has 3-axis adjustability so there is a lot of flexibility if you need to cover a wide area. The image is improved using back light compensation (BLC) and 3D digital noise reduction technology (3D DNR). The DS-2CD2035FWD-I also utilises smart features such as motion detection, line crossing detection and intrusion detection to improve security even further. Fitted with Hikvision's H.265+ video compression, the on board SD card slot can be used without worry of using up the memory so quickly. This camera can be powered by 12VDC power supply or PoE, it can be accessed remotely through a browser or by using the Hik-connect app.
    Banner for 2MP and 5MP Hikvision Easy 3.0 2MP and 3MP Mini Bullets
  3. Hikvision DS-2CD4B26FWD-IZS 2MP Darkfighter Smart Bullet Camera
    The Hikvision DS-2CD4B26FWD-IZS is a 2MP bullet camera with a 2.8mm-12mm motorized lens. This camera is great for external applications as it comes fitted with IP67 rated weatherproof housing and built-in infra-red LEDs that are effective up to 30m. The DS-2CD4B26FWD-IZS is a versatile camera that can be mounted in a variety of ways with a built-in bracket that uses 3-axes adjust-ability. This camera is designed to work in low light environments by using a range of features which ensures high quality images are recorded in 0.002 lux (colour) and 0.0002 lux (black/white) before the infra-red switches on. Wide dynamic range (WDR), defog, electronic image stabilization (EIS), 3D digital noise reduction (3D DNR) and highlight/back light compensation (HLC/BLC) are all used to ensure that the best quality images are captured at all times. The DS-2CD4B26FWD-IZS also uses a range of smart features to improve security such as intrusion detection, line crossing detection, motion detection and many more. There is the option to connect an external microphone or speaker if you wish to use audio along with your footage. This camera has an on-board SD card slot and can be powered by either a 12VDC power supply or by PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    Hikvision Product CatalogueHikvision Quick GuideHikvision Dark Fighter CatalogueUser Manual
    Learn More
  4. Hikvision DS-2CD4D26FWD-IZS 2MP Darkfighter Smart Dome Camera
    The Hikvision DS-2CD4D26FWD-IZS is a 2MP dome camera with a 2.8mm-12mm motorized, vari-focal lens. This camera is a great choice for external applications as it comes fitted with IP66 rated weatherproof housing and built-in infra-red LEDs that are effective up to 30m. The DS-2CD4D26FWD-IZS is a Darkfighter camera designed to produce high quality images in low light environments with the use of enhancing features such as wide dynamic range (WDR), defog, back light compensation (BLC) and electronic image stabilization (EIS). It also supports a range of smart features such as intrusion detection, motion detection and line crossing detection. This camera is versatile with 3-axis adjustment and a range of mounting options (please see the frequently bought together section). It also comes with the option of using on board storage and can be powered with either a 12VDC power supply or by PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    User ManualHikvision Product CatalogueHikvision Quick GuideHikvision Dark Fighter Catalogue Learn More
  5. Hikvision DS-2CD4125FWD-IZ 2MP Vandalproof Network Dome Camera
    Hikvision DS-2CD4125FWD-IZ 2MP Lightfighter Vandalproof Indoor Network Dome Camera
    The Hikvision DS-2CD4125FWD-IZ is a dome camera that comes fitted with a 2.8mm-12mm varifocal lens. This camera is great for internal applications where vandalism may be a concern as it is protected by IK10 vandal resistant housing. There are also infra-red LEDs within the camera that are effective up to 30m. The DS-2CD4125FWD-IZ is a Lightfighter camera which is specifically designed to cope with heavily back-lit applications and uses a range of features to improve these images: digital wide dynamic range (DWDR), defog, 3D digital noise reduction technology (3D DNR) and back light/highlight compensation (BLC/HLC).b This camera also uses a range of smart features to further improve security such as motion detection, line crossing detection and intrusion detection. The DS-2CD4125FWD-IZ has a micro SD card slot for on board storage and can be powered with either a 12V DC power supply or by PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    Hikvision Product Catalogue Hikvision Quick Guide 4 Line Guide User Manual
    Learn More
Grid  List
