Hikvision
Hikvision IP Cameras
Sidebar
Hikvision
Hikvision is the UK's leading brand of IP cameras and accessories, and provide the highest quality cameras with the best value for money on the market. Hikvision cameras are available in all shapes and sized and can be used for both domestic or commercial installations. Take a look at the newest EasyIP 3.0 family for a range of 3MP, 5MP and 8MP cameras with a variety of functions that are guaranteed to suit your application!
Grid  List
  1. Hikvision DS-2CD2735FWD-IZS/G Grey 3MP Motorised Zoom Dome Network Camera
    The Hikvision DS-2CD2735FWD-IZS/G is a grey 3MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2735FWD-IZS/G can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2735FWD-IZS/G has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
    Hikvision H.265+ banner
  2. Hikvision DS-2CD2335FWD-I/G | 4mm 3MP Grey Turret Network Camera
    The Hikvision DS-2CD2335FWD-I/G is a grey 3MP (2560 x 1920) turret camera with a 4mm fixed lens. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2335FWD-I/G is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2335FWD-I/G also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2335FWD-I/G has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
    Learn More
  3. Hikvision DS-2CD2355FWD-I | 2.8mm 5MP Turret Network Camera
    Hikvision DS-2CD2355FWD-I/G | 2.8mm 5MP Grey Turret Network Camera
    The Hikvision DS-2CD2355FWD-I/G is a grey 5MP (2560 x 1920) turret camera with a 2.8mm fixed lens. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2355FWD-I/G is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2355FWD-I/G also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2355FWD-I/G has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
    Learn More
  4. Hikvision DS-2CD2555FWD-I 5MP Mini Dome Network Camera
    Hikvision DS-2CD2555FWD-IS 5MP Mini Dome Network Camera
    The DS-2CD2555FWD-IS is a 5MP (2944 x 1656) mini dome camera with a 2.8mm or 4mm fixed lens. It is the most compact of all of Hikvision's cameras with a total diameter of 110mm making it a great choice for discreet applications. It also has built in infra-red LEDs that reach a maximum distance of 10m meaning it can be used in applications where a camera is needed near a front door without making the person/object of interest appear white out - This can happen with infra-red that is more powerful. This camera comes fitted with IK08 vandal resistant housing, IP66 weatherproof housing and a lens which can be adjusted on 3-axes. The DS-2CD2555FWD-IS uses wide dynamic range (WDR) , 3D digital noise reduction (3D DNR) and back light compensation (BLC) to ensure that the best possible image is always captured. On top of these features, the DS-2CD2555FWD-IS utilises smart features such as motion detection. intrusion detection and line crossing detection to further improve security. This camera also comes with a built-in microphone. H.265+ reduces and bandwidth and storage usage up to 70% when compared to H.264 so the on board SD card slot can be used without reaching maximum capacity so quickly. This camera can be powered with either a 12VDC power supply or PoE and can be accessed remotely through a browser or via the Hik-Connect app.
    Hikvision Product CatalogueHikvision Quick GuideUser ManualMini Dome Quick Start Manual Learn More
  5. Hikvision DS-2CD2535FWD-I 3MP Mini Dome Network Camera
    Hikvision DS-2CD2535FWD-IS 3MP Mini Dome Network Camera
    The DS-2CD2535FWD-IS is a 3MP (2048 x 1536) mini dome camera with a 2.8mm fixed lens. It is the most compact of all of Hikvision's cameras with a total diameter of 110mm making it a great choice for discreet applications. It also has built in infra-red LEDs that reach a maximum distance of 10m meaning it can be used in applications where a camera is needed near a front door without making the person/object of interest appear white out - This can happen with infra-red that is more powerful. This camera comes fitted with IK08 vandal resistant housing, IP66 weatherproof housing and a lens which can be adjusted on 3-axes. The DS-2CD2535FWD-IS uses wide dynamic range (WDR) , 3D digital noise reduction (3D DNR) and back light compensation (BLC) to ensure that the best possible image is always captured. On top of these features, the DS-2CD2535FWD-IS utilises smart features such as motion detection. intrusion detection and line crossing detection to further improve security. This camera also comes with with a built-in microphone. H.265+ reduces and bandwidth and storage usage up to 70% when compared to H.264 so the on board SD card slot can be used without reaching maximum capacity so quickly. This camera can be powered with either a 12VDC power supply or PoE and can be accessed remotely through a browser or via the Hik-Connect app.
    Hikvision DS-2CD2535FWD-I key features banner
  6. Hikvision DS-2CD2555FWD-I 5MP Mini Dome Network Camera
    The DS-2CD2555FWD-I is a 5MP (2944 x 1656) mini dome camera with either a 2.8mm, 4mm or 6mm fixed lens. It is the most compact of all of Hikvision's cameras with a total diameter of 110mm making it a great choice for discreet applications. It also has built in infra-red LEDs that reach a maximum distance of 10m meaning it can be used in applications where a camera is needed near a front door without making the person/object of interest appear white out - This can happen with infra-red that is more powerful. This camera comes fitted with IK08 vandal resistant housing, IP66 weatherproof housing and a lens which can be adjusted on 3-axes. The DS-2CD2555FWD-I uses wide dynamic range (WDR) , 3D digital noise reduction (3D DNR) and back light compensation (BLC) to ensure that the best possible image is always captured. On top of these features, the DS-2CD2555FWD-I utilises smart features such as motion detection. intrusion detection and line crossing detection to further improve security. H.265+ reduces and bandwidth and storage usage up to 70% when compared to H.264 so the on board SD card slot can be used without reaching maximum capacity so quickly. This camera can be powered with either a 12VDC power supply or PoE and can be accessed remotely through a browser or via the Hik-Connect app.
  7. Hikvision DS-2CD2535FWD-I 3MP Mini Dome Network Camera
    The DS-2CD2535FWD-I is a 3MP (2048 x 1536) mini dome camera with a 2.8mm fixed lens. It is the most compact of all of Hikvision's cameras with a total diameter of 110mm making it a great choice for discreet applications. It also has built in infra-red LEDs that reach a maximum distance of 10m meaning it can be used in applications where a camera is needed near a front door without making the person/object of interest appear white out - This can happen with infra-red that is more powerful. This camera comes fitted with IK08 vandal resistant housing, IP66 weatherproof housing and a lens which can be adjusted on 3-axes. The DS-2CD2535FWD-I uses wide dynamic range (WDR) , 3D digital noise reduction (3D DNR) and back light compensation (BLC) to ensure that the best possible image is always captured. On top of these features, the DS-2CD2535FWD-I utilises smart features such as motion detection. intrusion detection and line crossing detection to further improve security. H.265+ reduces and bandwidth and storage usage up to 70% when compared to H.264 so the on board SD card slot can be used without reaching maximum capacity so quickly. This camera can be powered with either a 12VDC power supply or PoE and can be accessed remotely through a browser or via the Hik-Connect app.
  8. Hikvision DS-2CD2H85FWD-IZ 8MP Vari-focal Turret Network Camera
    Hikvision DS-2CD2H85FWD-IZS 8MP Motorised Zoom Turret Network Camera
    The Hikvision DS-2CD2H85FWD-IZS is an 8MP (3840 x 2160) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H85FWD-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H85FWD-IZS also uses a range of smart features such as line crossing detection, intrusion detection and object removal detection. As with all cameras in the EasyIP 3.0 family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H85FWD-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
    Hikvision DS-2CD2H35FWD-IZ banner
  9. Hikvision DS-2CD2H55FWD-IZ 5MP Vari-focal Turret Network Camera
    Hikvision DS-2CD2H55FWD-IZS 5MP Motorised Zoom Turret Network Camera
    The Hikvision DS-2CD2H55FWD-IZS is a 5MP (2944 x 1656) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H55FWD-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H55FWD-IZS also uses a range of smart features such as line crossing detection, intrusion detection and object removal detection. As with all cameras in the EasyIP 3.0 family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H55FWD-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
  10. Hikvision DS-2CD2685FWD-IZS 8MP Vari-focal Bullet Network Camera
    Hikvision DS-2CD2685FWD-IZS 8MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2685FWD-IZS is an 8MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2685FWD-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2685FWD-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  11. Hikvision DS-2CD2785FWD-IZS 8MP Vari-focal Dome Network Camera
    Hikvision DS-2CD2785FWD-IZS 8MP Motorised Zoom Dome Network Camera
    The Hikvision DS-2CD2785FWD-IZS is an 8MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2785FWD-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2785FWD-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  12. Hikvision DS-2CD2H35FWD-IZ 3MP Vari-focal Turret Network Camera
    Hikvision DS-2CD2H35FWD-IZS 3MP Motorised Zoom Turret Network Camera
    The Hikvision DS-2CD2H35FWD-IZS is a 3MP (2048 x 1536) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H35FWD-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H35FWD-IZS also uses a range of smart features such as line crossing detection, intrusion detection and object removal detection. As with all cameras in the EasyIP 3.0 family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H35FWD-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
  13. Hikvision DS-2CD2755FWD-IZS 5MP Vari-focal Dome Network Camera
    The Hikvision DS-2CD2755FWD-IZS is a 5MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2755FWD-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2755FWD-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  14. Hikvision DS-2CD2735FWD-IZS 3MP Vari-focal Dome Network Camera
    Hikvision DS-2CD2735FWD-IZS 3MP Motorised Zoom Dome Network Camera
    The Hikvision DS-2CD2735FWD-IZS is a 3MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2735FWD-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2735FWD-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  15. Hikvision DS-2CD2655FWD-IZS 5MP Bullet Network Camera
    Hikvision DS-2CD2655FWD-IZS 5MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2655FWD-IZS is a 5MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2655FWD-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2655FWD-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  16. Hikvision DS-2CD2635FWD-IZS 3MP Bullet Network Camera
    Hikvision DS-2CD2635FWD-IZS 3MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2635FWD-IZS is a 3MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2635FWD-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2635FWD-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  17. Hikvision DS-2CD2155FWD-IS 5MP Dome Network Camera
    The DS-2CD2155FWD-IS is a 5MP (2560 x 1920) dome camera with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2155FWD-IS has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. There is also an audio/alarm I/O so external accessories such as microphones can be used. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2155FWD-IS can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  18. Hikvision DS-2CD2135FWD-IS 3MP Dome Network Camera
    The DS-2CD2135FWD-IS is a 3MP (2048 x 1536) dome camera with a 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2135FWD-IS has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. There is also an audio/alarm I/O so external accessories such as microphones can be used. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2135FWD-IS can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  19. Hikvision DS-2CD2185FWD-I 8MP Dome Network Camera
    The DS-2CD2185FWD-I is a 8MP (3840 x 2160) dome camera with the choice of either a 2.8mm, 4mm or 6mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2185FWD-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2185FWD-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  20. Hikvision DS-2CD2155FWD-I 5MP Dome Network Camera
    The DS-2CD2155FWD-I is a 5MP (2560 x 1920) dome camera with the choice of either a 2.8mm, 4mm or 6mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2155FWD-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2155FWD-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  21. Hikvision DS-2CD2135FWD-I | 3MP Dome Network Camera
    Hikvision DS-2CD2135FWD-I 3MP Dome Network Camera
    The DS-2CD2135FWD-I is a 3MP (2048 x 1536) dome camera with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2135FWD-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2135FWD-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  22. Hikvision DS-2CD2385FWD-I 8MP Turret Network Camera
    The Hikvision DS-2CD2385FWD-I is an 8MP (3840 x 2160) turret camera available in 2.8mm, 4mm and 6mm fixed focal lengths. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2385FWD-I is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2385FWD-I also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2385FWD-I has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
    Learn More
  23. Hikvision DS-2CD2355FWD-I 5MP Turret Network Camera
    The Hikvision DS-2CD2355FWD-I is a 5MP (2560 x 1920) turret camera available in 2.8mm, 4mm and 6mm fixed focal lengths. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2355FWD-I is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2355FWD-I also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2355FWD-I has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
  24. Hikvision DS-2CD2335FWD-I 3MP Turret Network Camera
    The Hikvision DS-2CD2335FWD-I is a 3MP (2048 x 1536) turret camera available in 2.8mm, 4mm and 6mm fixed focal lengths. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2335FWD-I is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2335FWD-I also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2335FWD-I has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
  25. Hikvision DS-2CD2T55FWD-I8 5MP Bullet Network Camera
    The DS-2CD2T55FWD-I8 is a 5MP bullet camera with powerful infra-red LEDs that work up to 80m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T55FWD-I8 supports Hikvision's latest H.265+ video compression which dramatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
    Banner for 5MP and 8MP bullet Hikvision Easy IP 3.0 range
  26. Hikvision DS-2CD2T85FWD-I8 8MP Bullet Network Camera
    The DS-2CD2T85FWD-I8 is a 8MP bullet camera with powerful infra-red LEDs that work up to 80m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T85FWD-I8 supports Hikvision's latest H.265+ video compression which dramatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
  27. Hikvision DS-2CD2T85FWD-I5 8MP Bullet Network Camera
    The DS-2CD2T85FWD-I5 is a 8MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T85FWD-I5 supports Hikvision's latest H.265+ video compression which dramatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
  28. Hikvision DS-2CD2T55FWD-I5 5MP Bullet Network Camera
    The DS-2CD2T55FWD-I5 is a 5MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T55FWD-I5 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
    Hikvision Easy IP 3.0 banner for DS-2CD2TX5FWD-
  29. Hikvision DS-2CD2T35FWD-I5 3MP Bullet Network Camera
    The DS-2CD2T35FWD-I5 is a 3MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T35FWD-I5 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
  30. Hikvision DS-2CD2055FWD-I 5MP Mini Bullet Network Camera
    The Hikvision DS-2CD2055FWD-I is a 5MP mini bullet camera that is available in either a 2.8mm, 4mm or 6mm fixed lens. This camera comes fitted with infra-red LEDs that are effective up to 30m and IP67 rated weatherproof housing. The DS-2CD2055FWD-I also comes with a built in bracket that has 3-axis adjustability so there is a lot of flexibility if you need to cover a wide area. The image is improved using back light compensation (BLC) and 3D digital noise reduction technology (3D DNR). The DS-2CD2055FWD-I also utilises smart features such as motion detection, line crossing detection and intrusion detection to improve security even further. Fitted with Hikvision's H.265+ video compression, the on board SD card slot can be used without worry of using up the memory so quickly. This camera can be powered by 12VDC power supply or PoE, it can be accessed remotely through a browser or by using the Hik-connect app.
    Hikvision Mini Bullet banner for easy IP 3.0 range
  31. Hikvision DS-2CD2035FWD-I 3MP Mini Bullet Network Camera
    The Hikvision DS-2CD2035FWD-I is a 3MP mini bullet camera that is available in either a 2.8mm, 4mm or 6mm fixed lens. This camera comes fitted with infra-red LEDs that are effective up to 30m and IP67 rated weatherproof housing. The DS-2CD2035FWD-I also comes with a built in bracket that has 3-axis adjustability so there is a lot of flexibility if you need to cover a wide area. The image is improved using back light compensation (BLC) and 3D digital noise reduction technology (3D DNR). The DS-2CD2035FWD-I also utilises smart features such as motion detection, line crossing detection and intrusion detection to improve security even further. Fitted with Hikvision's H.265+ video compression, the on board SD card slot can be used without worry of using up the memory so quickly. This camera can be powered by 12VDC power supply or PoE, it can be accessed remotely through a browser or by using the Hik-connect app.
    Banner for 2MP and 5MP Hikvision Easy 3.0 2MP and 3MP Mini Bullets
  32. Hikvision DS-2DE4220IW-D 2MP H.265 20X Network IR PTZ Dome Camera
    Hikvision DS-2DE4220IW-DE 2MP 20X PTZ Camera
    The Hikvision DS-2DE4220IW-DE is a 2MP PTZ camera which is able to capture high quality images in low light environment with its black anti-reflective glass. With a 4.7mm - 94mm focal length the DS-2DE4220IW-DE offers 20x optical zoom. This camera also offers 100m IR range and audio I/O's allowing the user to connect external microphones or speakers. The DS-2DE4220IW-DE uses a range of features to enhance images such as Dynamic Wide Dynamic Range (DWDR), 3D Digital Noise Reduction (3D DNR) and Highlight/Back Light Compensation (HLC/BLC). This PTZ supports 300 presets, 4 pattern scans and 8 patrols. It also includes smart features such as intrusion detection, line crossing detection and motion detection. The DS-2DE4220IW-DE can be powered by 12VDC power supply or 15W PoE and has a built in micro SD card slot. This PTZ can be accessed and controlled remotely through a browser or the Hik-Connect app.
    Hikvision E Series Network Speed Dome User ManualHikvision Product CatalogueHikvision Quick Guide Learn More
  33. Hikvision DS-2DE4A320IW-DE 3MP IR Mini PTZ Camera
    Hikvision DS-2DE4A320IW-DE 3MP 20x Mini PTZ Camera
    The DS-2DE4A320IW-DE is a mini PTZ from Hikvision with 3MP resolution and a 25fps max frame rate. With a 4.7mm-94mm focal length this camera offers 20x optical zoom and built in IR LEDs that provide clear night-time images up to 50m. The DS-2DE4A320IW-DE is fitted with IP66 rated weatherproof housing and audio/alarm I/Os. It also utilises a range of features to improve image quality such as wide dynamic range (WDR), back light compensation (BLC) and 3D digital noise reduction (3D DNR). This camera supports 300 presets, 8 patrols and 4 patterns with access for up to 32 users. The DS-2DE4A320IW-DE has a built-in micro SD card slot and can be powered through a 12VDC power supply or 18W PoE injector. Remote access is possible through a browser or through the Hik-Connect app.
    Hikvision Product CatalogueHikvision Quick GuideUser Manual Learn More
  34. Hikvision DS-2DE4A220IW-DE 2MP IR Mini PTZ Camera
    Hikvision DS-2DE4A220IW-DE 2MP 20x Mini PTZ Camera
    The DS-2DE4A220IW-DE is a mini PTZ from Hikvision with 2MP resolution and a 25fps max frame rate. With a 4.7mm-94mm focal length this camera offers 20x optical zoom and built in IR LEDs that provide clear night-time images up to 50m. The DS-2DE4A220IW-DE is fitted with IP66 rated weatherproof housing and audio/alarm I/Os. It also utilises a range of features to improve image quality such as wide dynamic range (WDR), back light compensation (BLC) and 3D digital noise reduction (3D DNR). This camera supports 300 presets, 8 patrols and 4 patterns with access for up to 32 users. The DS-2DE4A220IW-DE has a built-in micro SD card slot and can be powered through a 12VDC power supply or 18W PoE injector. Remote access is possible through a browser or through the Hik-Connect app.
  35. Hikvision PanoVu DS-2DP0818Z-D 8MP Panoramic and PTZ Camera
    The DS-2DP0818Z-D is a panoramic camera matched with a PTZ camera. The panoramic camera is made up of 4 x 2MP fixed lenses and offers a horizontal viewing angle of 180°. The PTZ camera is 2MP and offers 36x optical zoom with 360° endless pan. A range of smart features such as intrusion detection, motion detection and line crossing are supported. The DS-2DP0818Z-D is also able to detect up to 30 moving targets at the same time. There are a range of built-in features to improve image quality such as wide dynamic range (WDR), highlight compensation (HLC) and defog. The DS-2DP0818Z-D supports 8 patrols and 300 presets. There is also space for on-board storage with the option of an SD card. This camera can be powered by a 36V DC power supply or 70W PoE supply. Remote access is possible through a browser or through the Hik-Connect app.
    Hikvision Product CatalogueHikvision Quick GuideHikvision Dark Fighter CatalogueUser Manual Learn More
  36. Hikvision DS-2CD4B26FWD-IZS 2MP Darkfighter Smart Bullet Camera
    The Hikvision DS-2CD4B26FWD-IZS is a 2MP bullet camera with a 2.8mm-12mm motorized lens. This camera is great for external applications as it comes fitted with IP67 rated weatherproof housing and built-in infra-red LEDs that are effective up to 30m. The DS-2CD4B26FWD-IZS is a versatile camera that can be mounted in a variety of ways with a built-in bracket that uses 3-axes adjust-ability. This camera is designed to work in low light environments by using a range of features which ensures high quality images are recorded in 0.002 lux (colour) and 0.0002 lux (black/white) before the infra-red switches on. Wide dynamic range (WDR), defog, electronic image stabilization (EIS), 3D digital noise reduction (3D DNR) and highlight/back light compensation (HLC/BLC) are all used to ensure that the best quality images are captured at all times. The DS-2CD4B26FWD-IZS also uses a range of smart features to improve security such as intrusion detection, line crossing detection, motion detection and many more. There is the option to connect an external microphone or speaker if you wish to use audio along with your footage. This camera has an on-board SD card slot and can be powered by either a 12VDC power supply or by PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    Learn More
  37. Hikvision DS-2CD4D26FWD-IZS 2MP Darkfighter Smart Dome Camera
    The Hikvision DS-2CD4D26FWD-IZS is a 2MP dome camera with a 2.8mm-12mm motorized, vari-focal lens. This camera is a great choice for external applications as it comes fitted with IP66 rated weatherproof housing and built-in infra-red LEDs that are effective up to 30m. The DS-2CD4D26FWD-IZS is a Darkfighter camera designed to produce high quality images in low light environments with the use of enhancing features such as wide dynamic range (WDR), defog, back light compensation (BLC) and electronic image stabilization (EIS). It also supports a range of smart features such as intrusion detection, motion detection and line crossing detection. This camera is versatile with 3-axis adjustment and a range of mounting options (please see the frequently bought together section). It also comes with the option of using on board storage and can be powered with either a 12VDC power supply or by PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    User ManualHikvision Product CatalogueHikvision Quick GuideHikvision Dark Fighter Catalogue Learn More
  38. Hikvision DS-2CD6986F-5MM Panoramic Dome Camera
    Hikvision PanoVu DS-2CD6986F-5MM Panoramic Dome Camera
    The DS-2CD6986F-5MM is a panoramic, multi-imaging, Darkfighter camera from Hikvision's PanoVu range which is capable of capturing high quality images in low-light environments with 4 different lenses in HD resolution. This camera uses many smart features such as Defog and 3D DNR along with three-level user authentication management.
    Please use the chat button at the bottom-right of your screen to check stock before purchasing. This Camera is treated as a project-only product, only a low quantity of certain models are kept in UK stock. As an official Authorised Partner of HikVision we have access to all available stock in the UK, Europe and China.
  39.  Hikvision DS-2CD4A26FWD-IZS 2MP Darkfighter IR Array Bullet Network Camera
    Hikvision DS-2CD4A26FWD-IZS/P | 2MP Darkfighter IR Array Bullet Network Camera
    The Hikvision DS-2CD4A26FWD-IZS is a 2MP bullet camera with the option of a 2.8mm-12mm or 8mm-32mm motorised zoom lens. Great for external applications, the DS-2CD4A26FWD-IZS is protected by IP66 rated weatherproof housing and has infra-red LEDs that are effective up to 100m (8mm-32mm) or 50m (2.8mm-12mm). This camera is designed for low light applications making it Hikvision's recommended camera for ANPR purposes. By using a range of image enhancing images such as wide dynamic range (WDR), defog, 3D digital noise reduction technology (3D DNR), back light compensation (BLC) and electronic image stabilization (EIS) the DS-2CD4A26FWD-IZS provides excellent quality in all light levels. This camera utilises a range of smart features to improve security even further such as motion detection and a variety of road traffic detections (with ANPR firmware). The DS-2CD4A26FWD-IZS can be used with a micro SD card and can be powered by either a 12VDC power supply or be a PoE injector. Remote access is made possible with the Hik-Connect app or by using a web browser.
    4a26 banner
    Hikvision Dark Fighter Catalogue Hikvision Quick Guide Hikvision Product Catalogue
    Learn More
  40.  Hikvision DS-2CD4A25FWD-IZS 2MP Lightfighter Smart IP Outdoor Bullet Camera
    The Hikvision DS-2CD4A25FWD-IZS is a 2MP bullet camera with a choice of vari-focal motorised lenses: 2.8mm-12mm or 8mm-32mm. This camera is great for external application applications with IP67 rated weatherproof housing and a built in mounting bracket. The DS-2CD4A25FWD-IZS is designed to tackle environments with intense back light by using a range of image enhancing features such as 140dB wide dynamic range (WDR), highlight/back light compensation (HLC/BLC), defog and 3D digital noise reduction (3D DNR). This camera also comes fitted with a range of smart features to further improve security such as intrusion detection, line crossing detection, defocus detection, face detection and object counting. There is an audio/alarm I/O to be used with an external microphone or speaker if audio is a necessity in your application. The DS-2CD4A25FWD-IZS supports on-board storage and can be powered by either a 12V DC power supply or a PoE injector. Remote access is made possible through a web browser or through the Hik-Connect app.
    Hikvision Product Catalogue Hikvision Quick Guide Hikvision 4-Line Camera Guide User Manual
    Learn More
  41. Hikvision DS-2DF8223I-AELW 2MP Smart Darkfighter PTZ Outdoor Network Camera
    Hikvision DS-2DF8223I-AELW 2MP 23x Smart PTZ Camera with Wiper
    The Hikvision DS-2DF8223I-AELW is a 2MP PTZ IP camera with a built-in wiper and 23x optical zoom (5.9mm - 135.7mm). This camera includes a host of smart detection and and tracking features. It is part of Hikvision's Darkfighter series, which provides full colour images up to 0.005 lux, and black and white images up to 0.0005 lux with no additional illumination. It also comes with in-built IR LEDs to provide up to 200m illumination in 0 lux environments. The DS-2DF8223I-AELW provides full 360° pan function with -15° - 90° tilt range, giving a very wide range of view. It also comes with support for face, intrusion, line-crossing, audio exception, and motion detection, as well as 8 programmable patrols with up to 300 presets. The camera supports an internal micro SD/SDHC/SDXC card for use with Hikvision's Edge recording, allowing the camera to continue recording to this card even if the network drops for any reason. This ensures you never lose any data and your property remains secure. This camera can be powered by 60W PoE or a 24VAC power supply and can be accessed remotely through a web browser or through the Hik-Connect app.
  42. Hikvision DS-2DE5120I-AE 2MP 20X Network IR PTZ Dome Camera
    Hikvision DS-2DE5120I-AE 1.3MP 20X PTZ Dome Camera
    The Hikvision DS-2DE5120I-AE is a 1.3MP PTZ Dome Camera is able to capture high quality images in low light environment with its black anti-reflective glass. With a 2.9mm - 94mm focal lens this camera offers a 58.3° to 3.2° viewing angle and 20x optical zoom. The DS-2DE5120I-AE has infra-red LEDs that are effective up to 150m along with Audio/Alarm I/Os. This camera uses a range of features to improve images day and night such as digital wide dynamic range (DWDR), 3D digital noise reduction (3D DNR) and Highlight/Backlight comepnsation (HLC/BLC). This PTZ camera supports 300 presets, 8 patrols and a variety of scheduled tasks. It also supports a range of smart features such as intrusion detection, line crossing detection and motion detection. The DS-DE5120I-AE has a built-in micro SD card slot and can be powered by a 24VAC power supply or by PoE plus (30W). Remote access is possible through a browser or through the Hik-Connect app.
    Learn More
  43. Hikvision DS-2CD63C2F-IVS 12MP Fisheye Network Camera
    The Hikvision DS-2CD63C2F-IVS is a 12MP fisheye camera with a 1.98mm lens that offers a 360° field of view. This fisheye camera is a great choice for external applications as it is rated both IP66 weatherproof and IK10 vandal resistant. It also has built-in infra-red LEDs that are effective up to 15m. The DS-2CD63C2F-IVS uses a range of image enhancing features such as digital wide dynamic range, region of interest and 3D digital noise reduction technology. It also supports smart features to improve security further such as line crossing detection, intrusion detection and motion detection. The option to add an external microphone/speaker is possible as this camera as an audio/alarm I/O. This camera supports multiple viewing modes such as panorama and PTZ and footage can be stored on a micro SD card with the use of the built-in storage slot. The DS-2CD63C2F-IVS can be powered by either a 12V DC power supply or by PoE and remote access is possible through the Hik-Connect app or through a web browser.
    Hikvision Product Catalogue Hikvision Quick Guide User Manual Hikvision Fisheye Camera Guide
    Learn More
  44. Hikvision DS-2CD4625FWD-IZS 2MP Vandalproof IR Bullet Network Camera
    Hikvision DS-2CD4625FWD-IZS 2MP Lightfighter Vandalproof IR Bullet Network Camera
    The Hikvision DS-2CD4625FWD-IZS is a 2MP smart bullet camera with a 2.8mm-12mm lens which provides a 113°-33.8° horizontal viewing angle. This camera is perfect for outdoor applications as it is fitted with both IP66 rated weatherproof housing and IK10 vandal resistant housing. The DS-2CD4625FWD-IZS has built-in infra-red LEDs that are effective up to 50m and is also fitted with a range of features that make this camera effective at handling areas of interest with intense light levels. Image distortion correction, digital wide dynamic range (DWDR), defog and back light/highlight compensation (BLC/HLC) all ensure that the image is enhanced to the best ability. This camera also comes fitted with a range of smart features to improve security even further such as motion detection, line crossing detection and intrusion detection. The DS-2CD4625FWD-IZS also supports 6 behavior analysis and 4 exception detections. This camera can be powered by 24V AC power supply and also by a PoE+ injector. Remote access is made possible through the Hik-Connect app or through a web browser.
    Hikvision Product Catalogue Hikvision Quick Guide 4 Line Guide User Manual
    Learn More
  45. Hikvision DS-2CD4126FWD-IZ 2MP Outdoor Darkfighter Dome Network Camera
    Hikvision DS-2CD4126FWD-IZ 2MP Indoor Darkfighter Dome Network Camera
    The Hikvision DS-2CD4126FWD-IZ is a 2MP dome camera with a motorized, vari-focal 2.8mm-12mm lens. This camera is a great choice for internal applications where a vandal resistant camera is necessary as it comes protected by IK10 rated housing. The DS-2CD4126FWD-IZ uses infra-red LEDs that are effective up to 30m along with a range of image enhancing features which make it specifically helpful for ultra-low light applications. This camera uses wide dynamic range (WDR), back light/highlight compensation (BLC/HLC), 3D digital noise reduction (3D DNR), region of interest (ROI), defog and electronic image stabilization (EIS) to achieve this. A smart feature set is used within the camera to further improve security. Features include: motion detection, line crossing detection, intrusion detection and many more. The DS-2CD4126FWD-IZ has a built-in micro SD card slot for on board storage and can be powered by a 12V DC power supply or PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    Learn More
  46. Hikvision DS-2CD4626FWD-IZHS 2MP Darkfighter Vandal-proof IR Array Bullet Network Camera
    Hikvision DS-2CD4626FWD-IZS 2MP Darkfighter Vandal-proof IR Array Bullet Network Camera
    The Hikvision DS-2CD4626FWD-IZS is a 2MP bullet camera from Hikvision with a 2.8mm-12mm lens which provides a 92°~32° viewing angle. This camera is a great choice for external applications as it uses both IP66 rated weatherproof housing and IK10 vandal resistant housing. The DS-2CD4626FWD-IZS has built-in infra-red LEDs that are effective up to 50m and a range of image enhancing features which ensure the camera works in ultra low light environments: 120dB wide dynamic range (WDR), defog, 3D digital noise reduction technology (3D DNR), region of interest (ROI), back light compensation (BLC) and electronic image stabilization (EIS). This camera also uses a range of smart features to improve security even further such as motion detection, line crossing detection, region entrance/exit and object removal detection. There is also the option to connect a microphone/speaker to the audio I/O if audio is a function you require. The DS-2CD4626FWD-IZS features a micro SD card slot and can be powered by either a 24V AC power supply or by a PoE+ injector. Remote access is possible by using the Hik-Connect app or by using a web browser.
    Learn More
  47. Hikvision DS-2DF8223I-AEL 2MP Smart PTZ Outdoor Network Camera
    Hikvision DS-2DF8223I-AEL 2MP 23x Smart PTZ Camera
    The Hikvision DS-2DF8223I-AEL is a 2MP PTZ IP camera with 23x optical zoom (5.9mm - 135.7mm) and a host of smart detection and and tracking features. It is part of Hikvision's Darkfighter series, which provides full colour images up to 0.005 lux, and black and white images up to 0.0005 lux with no additional illumination. It also comes with in-built IR LEDs to provide up to 200m illumination in 0 lux environments. The DS-2DF8223I-AEL provides full 360° pan function with -15° - 90° tilt range, giving a very wide range of view. It also comes with support for face, intrusion, line-crossing, audio exception, and motion detection, as well as 8 programmable patrols with up to 300 presets. The camera supports an internal micro SD/SDHC/SDXC card for use with Hikvision's Edge recording, allowing the camera to continue recording to this card even if the network drops for any reason. This ensures you never lose any data and your property remains secure. This camera can be powered by 60W PoE or a 24VAC power supply and can be accessed remotely through a web browser or through the Hik-Connect app.
Grid  List
