Bullet Cameras
Bullet IP cameras are versatile and can be used in a very wide variety of situations. They're typically suitable for outdoor use and are an excellent all-round choice.
£420.84 Incl VAT Excl VAT. £350.70
£398.95 Incl VAT Excl VAT. £332.46
£260.40 Incl VAT Excl VAT. £217.00
In Stock
The Milesight UI-5D62-FIPCV Pro bullet is equipped with 3rd generation dot matrix IR LEDs providing superior night visibility up to 35m as well as ensuring a long lifespan and energy efficiency. This camera has been designed for outdoor use with an IP66 weatherproof housing to protect the camera against outdoor weather conditions as well as a PTFE membrane with ventilation holes to keep moisture and dust out of the camera whilst allowing air to flow in and out of the device.
Featuring video content analysis to supply users with the most advanced, smart video analytics for Milesight cameras. Milesight VCA has 8 detection modes; - Region entrance and region exiting ~ the two functions are used to alert when people/object enter/exit a specific area. - Advanced motion detection ~ with more intelligent features than traditional motion detection, advanced motion detection can filter out 'noise' such as lighting changes, tree movement etc. Parameters can be set to detect various movements depending on requirements. - Tamper detection ~ triggers an alarm when there is an attempt to move the camera or a suspicious object/person is obstructing the camera view. - Line crossing ~ when enable, an event will be triggered everytime an object crosses the virtual line. - Loitering ~ an alarm is triggered when an object stays in a specified area for a certain length of time. - Human detection ~ this can be used to determine if an object is human or not. - People counting ~ counts how many people enter/exit an area/.
Other camera features include; H.265+ video compression, PoE built-in, a motorised zoom lens and super WDR.
Included accessories: - Quick start guide - Junction Box - Mounting template - Screws - Rawl plugs - Screwdrivers
£219.60 Incl VAT Excl VAT. £183.00
In Stock
The Milesight UI-2A62-FIPCV Pro bullet is equipped with 3rd generation dot matrix IR LEDs providing superior night visibility up to 35m as well as ensuring a long lifespan and energy efficiency. This camera has been designed for outdoor use with an IP66 weatherproof housing to protect the camera against outdoor weather conditions as well as a PTFE membrane with ventilation holes to keep moisture and dust out of the camera whilst allowing air to flow in and out of the device.
£418.80 Incl VAT Excl VAT. £349.00
The Milesight Mini PTZ Bullet camera provides a refreshing take on the traditional PTZ camera with its sleek and aesthetically pleasing bullet design. The UI-5D61-EPCV offers a 360° endless pan and 75° tilt to provide provide coverage to a wide area.
12x optical zoom enables the camera to zoom in on distant object whilst maintaining the image clarity, providing high quality images at all times.
With improved Smart IR II technology the viewing range has increased to up to 100m, the top two IR LEDs work as high beam and the two bottom LEDs work as low beam for better quality even over a large distance. Not only this but the camera has an intelligent White LED that can be turned on as a supplementary light source/warning signal.
Featuring Smart PTZ motion detection users are able to monitor a specific pre-set area clearly when motion has been detected. The UI-5D61-EPCV will automatically pan and tilt to the motion detected area and zoom where needed to provide a clear image of the area and source of motion.
With an IP66 weatherproof rating the camera can be used for both indoor and outdoor applications depending on the need of the user. The camera housing also has a breathable screw-in vent to reduce fogging, condensation, eliminate moisture and improve the lifespan of the product.
Included Accessories: - Junction box - Quick start guide - Mounting template - Waterproof connectors - Screws - Rawl plugs - Screwdriver
£358.80 Incl VAT Excl VAT. £299.00
Out of Stock
The Milesight Mini PTZ Bullet camera provides a refreshing take on the traditional PTZ camera with its sleek and aesthetically pleasing bullet design. The UI-2A61-EPCV offers a 360° endless pan and 75° tilt to provide provide coverage to a wide area.
12x optical zoom enables the camera to zoom in on distant object whilst maintaining the image clarity, providing high quality images at all times. With improved Smart IR II technology the viewing range has increased to up to 100m, the top two IR LEDs work as high beam and the two bottom LEDs work as low beam for better quality even over a large distance. Not only this but the camera has an intelligent White LED that can be turned on as a supplementary light source/warning signal.
Featuring Smart PTZ motion detection users are able to monitor a specific pre-set area clearly when motion has been detected. The UI-2A61-EPCV will automatically pan and tilt to the motion detected area and zoom where needed to provide a clear image of the area and source of motion.
Included Accessories: - Quick start guide - Mounting template - Waterproof connectors - Screws - Rawl plugs - Screwdriver
£345.60 Incl VAT Excl VAT. £288.00
In Stock
The Milesight UI-8E62-FIPC is a 4K bullet camera that delivers ultra high definition video which is effectively four times that of Full HD.
This camera also features High Light Compensation which can identify high light areas and adjust exposure around this area to provide clear distinctive images, this can be used to capture license plates. Its P-Iris lens has a more precise control of the iris to provide a clearer scene with a greater depth of view.
With its IP67 weatherproof housing this camera is ideal for outdoor use as it is protected against rain and dust ensuring stable operation in all weather conditions.
As well as this the 4K camera has an integrated junction box to aid cable management and ease installation, the housing is also IP67 rated to protect the cables from rain and dust. Not only this but the camera has ventilation holes designed to keep moisture and dust out whilst allowing air flow in and out of the device preventing fogging and condensation build up on the camera lens.
Featuring Milesight's 3rd generation dot matrix IR LEDs the UI-8E62-FIPC is able to deliver superior night visibility, this alongside Smart IR II which has upgraded the IR LEDs technology for improved image quality. The two top LEDs work as high beam whilst the bottom two work as low beam, giving a better image clarity, the beams brightness can be adjusted.
Regular Price: £214.80
Special Price £168.00 Incl VAT Excl VAT. £140.00
In Stock
With many of the same features as the Milesight Mini Bullet camera the UI-5D63-FIPCV has the added extra of a motorised lens. This feature will enable users to remotely zoom between 2.8~12mm depending on what area they wish to cover/how detailed they require certain parts of a scene to be.
Like the fixed mini bullet this camera has an IP67 rated weatherproof housing protecting the camera against water and dust and a sunshield to stop sunlight entering the path of the lens and distorting the image.
The camera also features a 3-axis bracket which ensures ease of installation and has a robust design to protect and conceal power cables.
The P-Iris lens provides a more precise iris control, delivering improved video quality and depth of field by limiting the iris opening to ensure just the right amount of light is let into the lens for optimal image quality.
With features such as H.265+ video compression and video content analysis this camera has many of the newest/most desirable features on the market making it a go to choice for users from all backgrounds.
Included Accessories: - Quick start guide - Screws - Rawl plugs - Screwdriver
Regular Price: £168.00
Special Price £152.40 Incl VAT Excl VAT. £127.00
In Stock
With many of the same features as the Milesight Mini Bullet camera the UI-2A63-FIPCV has the added extra of a motorised lens. This feature will enable users to remotely zoom between 2.8~12mm depending on what area they wish to cover/how detailed they require certain parts of a scene to be.
Like the fixed mini bullet this camera has an IP67 rated weatherproof housing protecting the camera against water and dust and a sunshield to stop sunlight entering the path of the lens and distorting the image. The camera also features a 3-axis bracket which ensures ease of installation and has a robust design to protect and conceal power cables.
Special Price £134.40 Incl VAT Excl VAT. £112.00
In Stock
With a unique housing design the Milesight UI-5D63-PCV mini bullet camera effectively blocks the sun from entering the lens path due to the sunshield almost encompassing the camera, not only this but the housing also offers thermal insulation and is IP67 weatherproof protecting the camera against harsh outdoor weather.
The camera's mounting bracket tightly conceals the cable to make sure it is well protected from dust, water and even shock damages as well as this the bracket has a 3-axis design to enable users to easily angle the camera to find the perfect spot for surveillance.
Other impressive features include; Super WDR (wide dynamic range) which is a sensor based technology used to balance out the colour representation in areas with extreme back light and high contrast conditions to produce true colour images and H.265+ video compression to reduce bandwidth by 70-80% compared to H.264.
Also included with this camera is VCA (video content analysis) which allows users access to even more advanced options such as; region entrance, region exiting, advanced motion detection, line crossing, loitering and people counting.
Focal length options are: - 4mm ~ 62.8° FOV - 6mm ~ 44° FOV
Regular Price: £150.48
Special Price £120.00 Incl VAT Excl VAT. £100.00
In Stock
With a unique housing design the Milesight UI-2A63-PCV mini bullet camera effectively blocks the sun from entering the lens path due to the sunshield almost encompassing the camera, not only this but the housing also offers thermal insulation and is IP67 weatherproof protecting the camera against harsh outdoor weather. The camera's mounting bracket tightly conceals the cable to make sure it is well protected from dust, water and even shock damages as well as this the bracket has a 3-axis design to enable users to easily angle the camera to find the perfect spot for surveillance.
This camera also features Milesight's starlight technology which enables the camera to provide incredibly detailed colour images even in very low light environments without any extra added lighting. Other impressive features include; Super WDR (wide dynamic range) which is a sensor based technology used to balance out the colour representation in areas with extreme back light and high contrast conditions to produce true colour images and H.265+ video compression to reduce bandwidth by 70-80% compared to H.264.
This camera comes in a choice of two focal lengths: - 4mm ~ 78.8° FOV - 6mm ~ 53.8° FOV
£150.00 Incl VAT Excl VAT. £125.00
£138.00 Incl VAT Excl VAT. £115.00
£942.00 Incl VAT Excl VAT. £785.00
£636.00 Incl VAT Excl VAT. £530.00
£296.81 Incl VAT Excl VAT. £247.34
£348.80 Incl VAT Excl VAT. £290.67
£765.60 Incl VAT Excl VAT. £638.00
£480.73 Incl VAT Excl VAT. £400.61
£626.82 Incl VAT Excl VAT. £522.35
£337.20 Incl VAT Excl VAT. £281.00
The Wisenet XNO-6010R and XNO-6020R are 2 megapixel network IR bullet cameras that are part of the Wisenet X series of cameras with improved features such as; people counting, queue management, loitering and directional detection.
- XNO-6010R = 2.4mm lens
- XNO-6020R = 4mm lens
£1,444.80 Incl VAT Excl VAT. £1,204.00
£126.00 Incl VAT Excl VAT. £105.00
In Stock
The Axis F1004 is a bullet sensor unit designed for discreet indoor installations on both ceilings and walls. The F1004 comes with a detachable 8m cable for connection to an Axis F main unit.
This product requires an Axis F main unit for use.
-Installation guide - Detachable 8m cable
£302.17 Incl VAT Excl VAT. £251.81
£508.70 Incl VAT Excl VAT. £423.92
£264.00 Incl VAT Excl VAT. £220.00
£372.00 Incl VAT Excl VAT. £310.00
£228.00 Incl VAT Excl VAT. £190.00
£414.00 Incl VAT Excl VAT. £345.00
£351.60 Incl VAT Excl VAT. £293.00
In Stock
£359.50 Incl VAT Excl VAT. £299.58
£148.80 Incl VAT Excl VAT. £124.00
£237.60 Incl VAT Excl VAT. £198.00
£1,081.51 Incl VAT Excl VAT. £901.26
£697.20 Incl VAT Excl VAT. £581.00
In Stock
The Axis P1435-LE provides excellent image quality in HDTV 1080p resolution and a varifocal range of 10~22mm. The camera features corridor format, pixel counter, remote zoom and focus. Axis' Zipstream technology reduces bandwidth and storage requirements. The P1435-LE is outdoor ready and comes with an adjustable weather shield.
- Mounting bracket - Weather Shield L - Drill template - Installation Guide - Windows decoder 1-user license
£724.80 Incl VAT Excl VAT. £604.00
The A42 is a 5 megapixel bullet camera that offers 1080p HD resolution, it features a 2.8x zoom lens with extreme WDR that helps it perform incredibly well in very low light situations, day or night. It also includes adaptive IR LED's, weatherproofing (IP66) and vandal proofing (IK10) and it is also fully compatible with ACTi software.
£5,503.20 Incl VAT Excl VAT. £4,586.00
In Stock
The Axis Q1942-E is an affordable bullet style, thermal camera, it records at a 640x480 resolution and feature image stabilisation and window heater to keep your recording smooth in the harshest environments. This model offers a range of lenses (10/19/35/60mm) and fps (8.3/30 fps) to optimise the camera to your unique scenario, the camera also runs Axis' Zipstream, video analytics via AXIS Camera Application Platform (ACAP) and a range of third party software.
- Resistorx® L-key
- Wall & ceiling Mounting bracket
- Terminal block connector
- Axis Video Motion Detection 3
