Bullet Cameras
Sidebar
Bullet Cameras
Bullet IP cameras are versatile and can be used in a very wide variety of situations. They're typically suitable for outdoor use and are an excellent all-round choice.
Grid  List
  1. Milesight UI-5D62-FIPCV 5MP Pro Remote Focus and Zoom Bullet Network Camera
    £260.40 Incl VAT Excl VAT. £217.00
    In Stock
    The Milesight UI-5D62-FIPCV Pro bullet is equipped with 3rd generation dot matrix IR LEDs providing superior night visibility up to 35m as well as ensuring a long lifespan and energy efficiency. This camera has been designed for outdoor use with an IP66 weatherproof housing to protect the camera against outdoor weather conditions as well as a PTFE membrane with ventilation holes to keep moisture and dust out of the camera whilst allowing air to flow in and out of the device.
    Featuring video content analysis to supply users with the most advanced, smart video analytics for Milesight cameras. Milesight VCA has 8 detection modes; - Region entrance and region exiting ~ the two functions are used to alert when people/object enter/exit a specific area. - Advanced motion detection ~ with more intelligent features than traditional motion detection, advanced motion detection can filter out 'noise' such as lighting changes, tree movement etc. Parameters can be set to detect various movements depending on requirements. - Tamper detection ~ triggers an alarm when there is an attempt to move the camera or a suspicious object/person is obstructing the camera view. - Line crossing ~ when enable, an event will be triggered everytime an object crosses the virtual line. - Loitering ~ an alarm is triggered when an object stays in a specified area for a certain length of time. - Human detection ~ this can be used to determine if an object is human or not. - People counting ~ counts how many people enter/exit an area/.
    Other camera features include; H.265+ video compression, PoE built-in, a motorised zoom lens and super WDR.
    Included accessories: - Quick start guide - Junction Box - Mounting template - Screws - Rawl plugs - Screwdrivers
    Milesight User ManualMilesight Product BrochureMilesight Product Catalogue Learn More
  2. Milesight UI-5D63-PCV 5 Megapixel H.265 Mini Bullet Network Camera
    Milesight UI-5D63-PCV 5MP Mini Bullet Network Camera
    Regular Price: £168.00
    Special Price £134.40 Incl VAT Excl VAT. £112.00
    In Stock
    With a unique housing design the Milesight UI-5D63-PCV mini bullet camera effectively blocks the sun from entering the lens path due to the sunshield almost encompassing the camera, not only this but the housing also offers thermal insulation and is IP67 weatherproof protecting the camera against harsh outdoor weather.
    The camera's mounting bracket tightly conceals the cable to make sure it is well protected from dust, water and even shock damages as well as this the bracket has a 3-axis design to enable users to easily angle the camera to find the perfect spot for surveillance.
    Other impressive features include; Super WDR (wide dynamic range) which is a sensor based technology used to balance out the colour representation in areas with extreme back light and high contrast conditions to produce true colour images and H.265+ video compression to reduce bandwidth by 70-80% compared to H.264.
    Also included with this camera is VCA (video content analysis) which allows users access to even more advanced options such as; region entrance, region exiting, advanced motion detection, line crossing, loitering and people counting.
    Focal length options are: - 4mm ~ 62.8° FOV - 6mm ~ 44° FOV
    Included Accessories: - Quick start guide - Screws - Rawl plugs - Screwdriver
  3. Milesight UI-2A63-PCV 2 Megapixel H.265 Mini Bullet Network Camera
    Milesight UI-2A63-PCV 2MP Mini Bullet Network Camera
    Regular Price: £150.48
    Special Price £120.00 Incl VAT Excl VAT. £100.00
    In Stock
    With a unique housing design the Milesight UI-2A63-PCV mini bullet camera effectively blocks the sun from entering the lens path due to the sunshield almost encompassing the camera, not only this but the housing also offers thermal insulation and is IP67 weatherproof protecting the camera against harsh outdoor weather. The camera's mounting bracket tightly conceals the cable to make sure it is well protected from dust, water and even shock damages as well as this the bracket has a 3-axis design to enable users to easily angle the camera to find the perfect spot for surveillance.
    This camera also features Milesight's starlight technology which enables the camera to provide incredibly detailed colour images even in very low light environments without any extra added lighting. Other impressive features include; Super WDR (wide dynamic range) which is a sensor based technology used to balance out the colour representation in areas with extreme back light and high contrast conditions to produce true colour images and H.265+ video compression to reduce bandwidth by 70-80% compared to H.264.
    This camera comes in a choice of two focal lengths: - 4mm ~ 78.8° FOV - 6mm ~ 53.8° FOV
Grid  List
