Bullet Cameras
Sidebar
Bullet Cameras
Bullet IP cameras are versatile and can be used in a very wide variety of situations. They're typically suitable for outdoor use and are an excellent all-round choice.
Grid  List
  1. Hikvision DS-2CD5A85G0-IZS 2MP Motorised Zoom Bullet Camera
    The DS-2CD5A85G0-IZS is a 8MP motorised zoom camera from Hikvision with a 2.8mm ~ 12mm lens and built in IR LEDs effective up to 50m. This camera is great for external applications with IP67 rated weatherproof housing and IK10 vandal resistant housing. This camera is suitable for multiple applications with excellent adjustability (pan: 0°to 355°, tilt: 0°to 75°, rotate: 0°to 355°). It also supports a range of image enhancing features such as wide dynamic range (WDR), back/highlight compensation (BLC/HLC), defog, electronic image stabilization (EIS) and 3D digital noise reduction (3D DNR). This camera hosts a range of impressive smart features which make it an excellent choice for monitoring complicated areas of interests including 6 behaviour analyses, 3 exception detections, 7 alarm triggers, counting and face detection (please see datasheet for a list of these features). The DS-2CD5A85G0-IZS also has the ability to record and playback up to 5 streams. With an on board micro SD card slot and support of H.265+, the DS-2CD5A85G0-IZS ensures that you can enjoy every functionality without putting great stress on storage or bandwidth requirements. This camera can be powered by PoE or a 12VDC power supply and has the ability to be remotely accessed through a browser or through the Hik-Connect app.
    Hikvision Product CatalogueQuick Start GuideHikvision Security GuidanceUser Manual Learn More
  2. Hikvision DS-2CD5A26G0-IZS 2MP Motorised Zoom Bullet Camera
    The DS-2CD5A26G0-IZS is a 2MP motorised zoom camera from Hikvision with a 2.8mm ~ 12mm lens and built in IR LEDs effective up to 50m. This camera is great for external applications with IP67 rated weatherproof housing and IK10 vandal resistant housing. This camera is suitable for multiple applications with excellent adjustability (pan: 0°to 355°, tilt: 0°to 75°, rotate: 0°to 355°). It also supports a range of image enhancing features such as wide dynamic range (WDR), back/highlight compensation (BLC/HLC), defog, electronic image stabilization (EIS) and 3D digital noise reduction (3D DNR). This camera hosts a range of impressive smart features which make it an excellent choice for monitoring complicated areas of interests including 6 behaviour analyses, 3 exception detections, 7 alarm triggers, counting and face detection (please see datasheet for a list of these features). The DS-2CD5A26G0-IZS also has the ability to record and playback up to 6 streams. With an on board micro SD card slot and support of H.265+, the DS-2CD5A26G0-IZS ensures that you can enjoy every functionality without putting great stress on storage or bandwidth requirements. This camera can be powered by PoE or a 12VDC power supply and has the ability to be remotely accessed through a browser or through the Hik-Connect app.
  3. Hikvision DS-2CD2683G0-IZS 8MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2683G0-IZS is an 8MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is from Hikvision'a brand new Easy IP 2.0+ range. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2683G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection and line crossing detection intrusion detection. The DS-2CD2683G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
    Hikvision H.265+ banner
  4. Hikvision DS-2CD2663G0-IZS 6MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2663G0-IZS is a 6MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is from Hikvision'a brand new Easy IP 2.0+ range. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2663G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection and line crossing detection intrusion detection. The DS-2CD2663G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  5. Hikvision DS-2CD2T83G0-I5 8MP Bullet Network Camera
    The DS-2CD2T83G0-I5 is a 8MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T83G0-I8 supports Hikvision's latest H.265+ video compression which dramatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
    Hikvision Easy IP 3.0 banner for DS-2CD2TX5FWD-
  6. Hikvision DS-2CD2T63G0-I5 6MP Bullet Network Camera
    The DS-2CD2T63G0-I5 is a 6MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T63G0-I5 supports Hikvision's latest H.265+ video compression which dramatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
  7. Hikvision DS-2CD2T23G0-I5 2MP Bullet Network Camera
    The DS-2CD2T23G0-I5 is a 2MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T23G0-I5 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
  8. Hikvision DS-2CD2643G0-IZS 4MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2643G0-IZS is a 4MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is from Hikvision'a brand new Easy IP 2.0+ range. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2643G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection and line crossing detection intrusion detection. The DS-2CD2643G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  9. Hikvision DS-2CD2623G0-IZS 2MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2623G0-IZS is a 2MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is from Hikvision'a brand new Easy IP 2.0+ range. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2623G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection and line crossing detection. The DS-2CD2623G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  10. Hikvision DS-2CD2685FWD-IZS 8MP Vari-focal Bullet Network Camera
    Hikvision DS-2CD2685FWD-IZS 8MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2685FWD-IZS is an 8MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2685FWD-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2685FWD-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  11. Hikvision DS-2CD2655FWD-IZS 5MP Bullet Network Camera
    Hikvision DS-2CD2655FWD-IZS 5MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2655FWD-IZS is a 5MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2655FWD-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2655FWD-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  12. Hikvision DS-2CD2635FWD-IZS 3MP Bullet Network Camera
    Hikvision DS-2CD2635FWD-IZS 3MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2635FWD-IZS is a 3MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2635FWD-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2635FWD-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  13. Hikvision DS-2CD2T85FWD-I5 8MP Bullet Network Camera
    The DS-2CD2T85FWD-I5 is a 8MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T85FWD-I5 supports Hikvision's latest H.265+ video compression which dramatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
    Banner for 5MP and 8MP bullet Hikvision Easy IP 3.0 range
  14. Hikvision DS-2CD2T55FWD-I5 5MP Bullet Network Camera
    The DS-2CD2T55FWD-I5 is a 5MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T55FWD-I5 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
  15. Hikvision DS-2CD2T35FWD-I5 3MP Bullet Network Camera
    The DS-2CD2T35FWD-I5 is a 3MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T35FWD-I5 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
  16.  Hikvision DS-2CD4A25FWD-IZS 2MP Lightfighter Smart IP Outdoor Bullet Camera
    The Hikvision DS-2CD4A25FWD-IZS is a 2MP bullet camera with a choice of vari-focal motorised lenses: 2.8mm-12mm or 8mm-32mm. This camera is great for external application applications with IP67 rated weatherproof housing and a built in mounting bracket. The DS-2CD4A25FWD-IZS is designed to tackle environments with intense back light by using a range of image enhancing features such as 140dB wide dynamic range (WDR), highlight/back light compensation (HLC/BLC), defog and 3D digital noise reduction (3D DNR). This camera also comes fitted with a range of smart features to further improve security such as intrusion detection, line crossing detection, defocus detection, face detection and object counting. There is an audio/alarm I/O to be used with an external microphone or speaker if audio is a necessity in your application. The DS-2CD4A25FWD-IZS supports on-board storage and can be powered by either a 12V DC power supply or a PoE injector. Remote access is made possible through a web browser or through the Hik-Connect app.
    Hikvision Product Catalogue Hikvision Quick Guide Hikvision 4-Line Camera Guide User Manual
    Learn More
Grid  List
