Dome Cameras
Sidebar
Dome Cameras
Dome IP cameras are typically vandal-proof and are extremely resistant to tampering, making them a fantastic choice for situations in which this is a risk.
Grid  List
  1. Axis M3037-PVE Outdoor Network Dome Camera 0548-001
    £852.65 Incl VAT Excl VAT. £710.54
    In Stock
    The Axis M3037-PVE is an outdoor ready fixed focus mini dome camera that provides excellent image quality in daylight as well as night time, the camera offers full duplex audio with echo cancellation and noise reduction as well as supporting Session Initiation Protocol (SIP) for easy integration with IP phone systems.
    Included Accessories: - Installation guide - Windows decoder 1-user license - Installation and management software CD - Drill hole template - Resitorx L-key - Terminal block connector
    Axis M3037-PVE User Manual Axis M3037-PVE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table February 2015 Axis Product Comparison Table FREE 30-day trial of Axis Camera Station software Articles about Axis Network Cameras Learn More
  2. Vivotek FD8382-VF2 Fixed Dome Network Camera
    £346.70 Incl VAT Excl VAT. £288.92
    The FD8382-VF2 is an outdoor dome camera with a fixed lens. This camera offers 15fps at 5MP resolution while meeting the needs of outdoor applications. Smart Stream technology allows the optimization of a specific desired area while 3D Noise Reduction technology keeps the picture as clear and detailed as possible. The IK-10 vandal proof and IP66 weatherproof housing makes this camera perfect for outdoor applications without the worry of damage to the camera. FD8382-VF2
    Quick Installation Guide User Manual V Pro Line Brochure Learn More
  3. Vivotek FD8382-TV Fixed Dome Network Camera
    Vivotek FD8382-TV 5MP Fixed Dome Network Camera
    £508.70 Incl VAT Excl VAT. £423.92
    The Vivotek FD8382-TV is a 5MP fixed dome camera which offers 30fps at 1080p resolution and can be controlled remotely with P-iris control and built-in stepping in motors.The FD8382-TV uses Smart Stream technology and 3D DNR to optimize resolution and the use of bandwidth. This camera can be mounted in harsh outdoor conditions as it is armed with IP-66 rated weather-proof housing and IK-10 rated vandal proof housing. 8382-tv
    Quick Installation Guide User Manual Learn More
  4. Vivotek FD8182-T Fixed Dome Network Camera
    £439.70 Incl VAT Excl VAT. £366.42
    The FD8182-T is an indoor dome camera from Vivotek capable of 5MP recording at 15 fps. This camera gives you the best image possible with the use of 2D Noise Reduction technology and resolution optimisation. This camera is easy to control with the use of remote focus and P-iris that also helps control the camera remotely. FD8182-T Features
    Quick Installation Guide User Manual V Pro Flyer Learn More
  5. AXIS Q6052 Indoor PTZ Dome Network Camera 0899-002
    Axis Q6052 Indoor PTZ Dome Network Camera 0899-002
    £2,154.68 Incl VAT Excl VAT. £1,795.57
    The Axis Q6052 is an indoor PTZ dome with D1 resolution, fast & accurate pan/tilt performance and 36x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
    It also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilisation, two-way audio, I/O ports and 24V AC/DC power.
    - Axis PoE+ midspan 1-port
    - Recessed mount for hard and drop ceilings
    - Smoked dome cover
    - Installation Guide
    Axis Q6052 Installation GuideAxis Q6052 User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  6. AXIS Q6055 Indoor PTZ Dome Network Camera 0907-002
    Axis Q6055 Indoor PTZ Dome Network Camera 0907-002
    £2,730.00 Incl VAT Excl VAT. £2,275.00
    The Axis Q6055 is an indoor PTZ dome with 1080p resolution, fast & accurate pan/tilt performance and 32x optical zoom. this model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention. it also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilization, two-way audio, I/O ports and 24V AC/DC power.
    Included Accessories: - Axis PoE+ midspan 1-port
    - Smoked dome cover
    Axis Q6055 Installation GuideAxis Q6055 User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  7. Vivotek FD836BA-HVF2 2MP Fixed Dome Network Camera
    £228.00 Incl VAT Excl VAT. £190.00
    The FD836BA-HVF2 is a 2MP dome from Vivotek that can record at 2MP resolution with a 30 fps frame rate. This camera provides excellent images in both light and dark with the use of wide dynamic range and smart IR technology. It's IR illuminators are effective up to 30 meters. With two-way audio, weather and vandal proof housing, the FD836BA-HVF2 is perfect for outdoor applications. FD836BA-HVF2 Banner Quick Installation Guide User Manual Learn More
  8. Vivotek FD9181-HT 5MP Indoor Fixed Dome Camera
    £800.40 Incl VAT Excl VAT. £667.00
    The Vivotek FD9181-HT is a 5MP, varifocal indoor dome camera that features both H.265 and Smart Stream II reducing both bandwidth and storage consumption whilst still producing high quality images. Thanks to the built-in infra-red illuminators, this camera is able to capture images at up to 30m in the dark. In addition, it features a built-in PIR sensor to help detect any unexpected events and to provide real-time responses.
  9. Vivotek FD9371-HTV 3MP Outdoor Fixed Dome Camera
    £654.71 Incl VAT Excl VAT. £545.59
    The Vivotek FD9371-HTV is a 3MP outdoor vari-focal dome camera with a wealth of features including; H.265 compression, Smart Stream II, WDR Pro and a P-iris lens. The built-in infra-red LED's allow the FD9371-HTV to see up to 30m in the dark. This camera also benefits from an IP66 weather-proof rated and an IK10 vandal-resistance rated housing, making it suitable for a wide range of indoor or outdoor applications.
    Quick Installation Guide User Manual Accessory Manual Learn More
  10. Vivotek FD9381-HTV 5MP Outdoor Fixed Dome Network Camera
    £881.46 Incl VAT Excl VAT. £734.55
    The Vivotek FD9381-HTV is a 5 megapixel outdoor fixed dome camera with H.265 technology enabling this camera to provide higher and more efficient image compression rates.
  11. Vivotek FE9381-EHV 5MP Fisheye Camera
    £696.00 Incl VAT Excl VAT. £580.00
    The Vivotek FE9381-EHV is a 5MP fisheye camera equipped with full EN50155 compliance, a vandalproof IK10 and weatherproof IP66 rated housing to ensure the camera is able to withstand shock, vibration, humidity, dust and temperature fluctuations. This versatile camera can be used in a wide range of applications both indoors and outdoors and thanks to its 180° panoramic view (wall mount) or 360° surround view (ceiling/floor mount) it has zero blind spots, making it perfect to provide coverage of wide open areas, such as airports, shopping malls, retail stores and offices.
  12. Vivotek FD9371-EHTV 3MP Vari-Focal  Dome Camera
    £510.00 Incl VAT Excl VAT. £425.00
    The Vivotek FD9371-EHTV is a 3MP vari-focal dome camera that is both IP66 and IK10-rated meaning it can be used either indoors or outdoors plus, this model is suitable for use in extreme weather conditions of -50°C ~ 50°C and humidity levels of 90%. The FD9371-EHTV benefits from a range of alarm and event triggers including motion detection, tampering detection and audio detection. By using H.265 compression you can capture quality images but use less storage space.
    This item may not be available for immediate delivery. Please check with us before purchasing as it could take 10-14 days to fetch from Vivotek.
    User Manual Quick Installation Guide Accessory Guide Learn More
  13. Vivotek FD8382-ETV 5MP Vari-Focal Extreme Weather Dome Camera
    £444.68 Incl VAT Excl VAT. £370.57
    The Vivotek FD8382-ETV is a 5MP vari-focal dome camera with built-in infra-red LED's and two-way audio. The housing is IP66-rated and IK-10 rated meaning the camera can be used both indoors and outdoors in extreme weather conditions. This camera comes ready for changing environments, with wide dynamic range for improved visibility in bright and dark situations. The FD8382-ETV also benefits from video rotation through its corridor view.
    User Manual Quick Installation Guide Learn More
Grid  List
