Dome Cameras
Sidebar
Dome Cameras
Dome IP cameras are typically vandal-proof and are extremely resistant to tampering, making them a fantastic choice for situations in which this is a risk.
Grid  List
  1. AXIS Q6055-E Outdoor PTZ Dome Network Camera 0909-002
    Axis Q6055-E Outdoor PTZ Dome Network Camera 0909-002
    £3,319.20 Incl VAT Excl VAT. £2,766.00
    The Axis Q6055-E is an outdoor PTZ dome with 1080p resolution, fast & accurate pan/tilt performance and 32x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
    It also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilization, two-way audio, I/O ports and 24V AC/DC power. As an outdoor model it also features an IP66 weatherproof rating and an IK10 vandal-proof rating.
    Included Accessories: - Axis High PoE 60 W midspan 1-port
    - RJ45 Push-pull Connector (IP66)
    - Sunshield
    - Installation Guide
    Axis Q6055-E Installation GuideAxis Q6055-E User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  2. AXIS Q6052-E Outdoor PTZ Dome Network Camera 0901-002
    Axis Q6052-E Outdoor PTZ Dome Network Camera 0901-002
    £2,784.00 Incl VAT Excl VAT. £2,320.00
    The Axis Q6052-E is an outdoor PTZ dome with D1 resolution, fast & accurate pan/tilt performance and 36x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
    It also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilisation, two-way audio, I/O ports and 24V AC/DC power. As an outdoor model it also features an IP66 weatherproof rating and an IK10 vandal-proof rating.
    - Sunshield
    Axis Q6052 Installation GuideAxis Q1942-E User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  3. AXIS Q6052 Indoor PTZ Dome Network Camera 0899-002
    Axis Q6052 Indoor PTZ Dome Network Camera 0899-002
    £2,154.68 Incl VAT Excl VAT. £1,795.57
    The Axis Q6052 is an indoor PTZ dome with D1 resolution, fast & accurate pan/tilt performance and 36x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
    - Axis PoE+ midspan 1-port
    - Recessed mount for hard and drop ceilings
    - Smoked dome cover
    Axis Q6052 Installation GuideAxis Q6052 User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  4. AXIS Q3615-VE Network Camera
    Axis Q3617-VE PTRZ Dome Network Camera 0744-001
    £1,658.40 Incl VAT Excl VAT. £1,382.00
    In Stock
    Thanks to its 1/1.8” sensor and high-performance image processing, Axis Q3617-VE supports Lightfinder and WDR - Forensic Capture with optimal image quality in difficult light conditions. The camera can record video at 4 MP at 30 fps with WDR, or 6 MP at 20 fps with WDR disabled, the installation and positioning of the camera is made simple by its unique remote pan/tilt/roll/zoom (PTRZ) solution. The camera also comes with electronic image stabilisation that makes the camera robust and reliable even in the harshest conditions.
    Included Accessories: - AXIS Connector Guard A - Safety hook wire - Installation Guide - Windows decoder 1-user license - Resistorx® L-key - Weather shield - Mounting bracket - Drill template - Cable gasket - Axis U-shape conduit adapter
    Axis Q3615-VE Installation GuideAxis Q3617-VE User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  5. AXIS Q3615-VE Network Camera
    Axis Q3615-VE PTRZ Dome Network Camera 0743-001
    £1,443.60 Incl VAT Excl VAT. £1,203.00
    In Stock
    Thanks to its 1/1.9” sensor and high-performance image processing, Axis Q3615-VE supports Lightfinder and WDR - Forensic Capture with optimal image quality in difficult light conditions. The camera can record video at 1080p and up to 60 fps, the installation and positioning of the camera is made simple by its unique remote pan/tilt/roll/zoom (PTRZ) solution. The camera also comes with electronic image stabilisation that makes the camera robust and reliable even in the harshest conditions.
    Included Accessories: - Axis Connector Guard A - Safety hook wire - Installation Guide - Windows decoder 1-user license - Resistorx® L-key - Weather shield - Mounting bracket - Drill template - Cable gasket - Axis U-shape conduit adapter
    Axis Q3615-VE Installation GuideAxis Q3615-VE User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  6. AXIS P3707-PE Multisensor Network Camera
    Axis P3707-PE Multisensor Network Camera 0815-001
    £1,210.98 Incl VAT Excl VAT. £1,009.15
    The Axis P3707-PE network camera can capture a combined 8 MP resolution across its 4 independent & varifocal lenses, with this 4-cameras-in-1 design you get the most flexible, cost-effective solution for multi-directional surveillance in large indoor and outdoor areas. Each camera head can be moved along the circular track built into the camera and each can be rotated into Axis' corridor format. Included Accessories: - RJ45 mounting tool - Installation Guide - Windows Decoder 1-user Licence Axis P3707-PE Installation GuideAxis P3707-PE User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table FREE 30-day trial of Axis Camera Station software
    Learn More
  7. AXIS Companion Dome V
    Axis Companion Dome V 0894-001
    £212.40 Incl VAT Excl VAT. £177.00
    The Axis Companion Dome V is an indoor, vandal resistant fixed dome camera that gives high quality video in HDTV 1080p / 2 MP resolution. The plug & go design of the Companion series combined with the domes WDR makes it the perfect starting point for any IP camera novice looking to build a system for their home or small business. It is important to know that Companion products are ONLY compatible with Companion Video Management Software & mobile app.
    Included Accessories: - L-Key Tools - Installation Guide - Windows Decoder 1-user Licence
    Axis Companion Dome V Installation GuideAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  8. AXIS Q3708-PVE Fixed Dome Network Camera
    Axis Q3708-PVE Fixed Dome Network Camera 0801-001
    £2,140.80 Incl VAT Excl VAT. £1,784.00
    The Axis Q3708-PVE is a fixed dome camera with Wide Dynamic Range(WDR) and excellent light sensitivity, Axis call this Forensic Capture as it lets you see much more detail in very low light situations. What really separates this dome from many others on the market is its 3 sensors in 1 design that allows you to see a huge 180 degree panoramic field of view in up to Quad HD resolution.
    Included Accessories: - RJ45 push-pull connector - L-key - Weather shield - Installation guide - Windows decoder 3-user license
    Axis Q3708-PVE User Manual Axis Q3708-PVE Installation Guide Axis Assigning IP Address User Manual Axis Product Guide
    Learn More
  9. AXIS M3044–V Dome Network Camera
    Axis M3046–V Dome Network Camera 0806-001
    £372.60 Incl VAT Excl VAT. £310.50
    The palm-sized Axis M3046-V is one of the most affordable 4MP dome cameras in this price bracket, it offers Quad HD resolution and a wide-dynamic range (WDR) that ensures that both the dark and bright areas of the scene are visible.
    The camera also supports video analytics such as people counting, and even though the camera has a fixed focus lens using a combination of its 4MP resolution and digital PTZ capability you are able to crop the view whilst still recording at 1080p.
    User ManualInstallation GuideAxis Assigning IP Address User Manual
    Learn More
  10. AXIS M3044–V Dome Network Camera
    Axis M3045–V Dome Network Camera 0804-001
    £272.90 Incl VAT Excl VAT. £227.42
    The palm-sized M3045-V is one of the best vandal & dust-resistant indoor cameras in this price bracket, it offers HDTV 720p resolution and a wide-dynamic range(WDR) that ensures that both the dark and bright areas of the scene are visible.
    The camera supports Power over Ethernet (PoE) and HDMI, the camera has 3-axis camera angle adjustment allowing it to be placed in huge variety of positions whilst still capturing the required footage.
    User ManualInstallation GuideAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  11. AXIS M3044–V Dome Network Camera
    Axis M3044–V Dome Network Camera 0802-001
    £205.67 Incl VAT Excl VAT. £171.39
    In Stock
    The palm-sized M3044-V is one of the best vandal & dust-resistant indoor cameras in this price bracket, it offers HDTV 720p resolution and a wide-dynamic range (WDR) that ensures that both the dark and bright areas of the scene are visible.
    Included Accessories: - Installation guide - Windows decoder 1-user license - Torx L-Key
    Learn More
  12. Axis M3037-PVE Outdoor Network Dome Camera 0548-001
    £852.65 Incl VAT Excl VAT. £710.54
    In Stock
    The Axis M3037-PVE is an outdoor ready fixed focus mini dome camera that provides excellent image quality in daylight as well as night time, the camera offers full duplex audio with echo cancellation and noise reduction as well as supporting Session Initiation Protocol (SIP) for easy integration with IP phone systems.
    Included Accessories: - Installation guide - Windows decoder 1-user license - Installation and management software CD - Drill hole template - Resitorx L-key - Terminal block connector
    Axis M3037-PVE User Manual Axis M3037-PVE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table February 2015 Axis Product Comparison Table FREE 30-day trial of Axis Camera Station software Articles about Axis Network Cameras Learn More
  13. Axis Q3709-PVE Fixed Dome Network Camera 0664-001
    £2,156.40 Incl VAT Excl VAT. £1,797.00
    In Stock
    The Axis Q3709-PVE network camera is a fixed dome with multiple sensors that provides a broad overview with great detail.
    Axis Q3709-PVE User Manual Axis Q3709-PVE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide
  14. Axis P3905-RE 2MP Fixed Dome Network Camera
    Axis P3905-RE 2MP Fixed Dome Network Camera 0662-001
    £493.20 Incl VAT Excl VAT. £411.00
    The Axis P3905-RE is part of the Axis P39-R network camera series, which has been specifically designed for video surveillance on buses, trains, tubes and emergency vehicles. This camera has an IP67 rated protection against dust and water and can withstand tough conditions such as; vibrations, shocks, bumps and temperature fluctuations.
    Included Accessories: - Installation and management software CD - Installation guide - Drill hole template - Top cover tool - Lens tool - Allen key resitorx - Windows decoder 1-user license
    Axis P3905-RE User Manual Axis P3905-RE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide FREE 30-day trial of Axis Camera Station software Articles about Axis Network Cameras Learn More
  15. Axis Q8414-LVS Corner Mount Stainless Steel Network Camera White 0710-001
    £1,120.90 Incl VAT Excl VAT. £934.08
    Axis Q8414-LVS network camera features vandal resistant stainless steel anti-ligature casing and built-in invisible IR LED for high quality indoor video surveillance even in complete darkness.
    Included Accessories: - Installation guide - Installation and management software CD - Windows decoder 1-user license - AVHS authentication key - Resitorx 20 bit - Connector kit - Washers - Mounting tool for RJ45
    Axis Q8414-LVS User Manual Axis Q8414-LVS Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  16. Axis Q8414-LVS Corner Mount Stainless Steel Network Camera Metal 0709-001
    £1,116.50 Incl VAT Excl VAT. £930.42
  17. Axis F1035-E 2MP Fisheye Sensor Unit 12M 0736-001
    £227.98 Incl VAT Excl VAT. £189.98
    In Stock
    The Axis F series provides, flexible, high-performance 1080p cameras for extremely discreet indoor, outdoor and mobile surveillance applications. They are ideal for use in ATMs, banks, stores, hotels, as well as rugged environments such as emergency vehicles, buses and trains. *This sensor unit is supplied with a 12 metre cable* *Main unit sold separately*
    F1035-E
    Included Accessories: - Installation guide - Axis F8201 vari-angle mounting bracket
    Axis F1035-E 12M Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  18. Axis F1035-E 2MP Fisheye Sensor Unit 3M 0737-001
    £222.54 Incl VAT Excl VAT. £185.45
    In Stock
    The Axis F series provides, flexible, high-performance 1080p cameras for extremely discreet indoor, outdoor and mobile surveillance applications. They are ideal for use in ATMs, banks, stores, hotels, as well as rugged environments such as emergency vehicles, buses and trains. *This sensor unit is supplied with a 3 metre cable* *Main unit sold separately*
    F1035-E
    Axis F1035-E 3M Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  19. Axis M3027-PVE 5MP Fixed Mini Dome Camera 0556-001
    £673.20 Incl VAT Excl VAT. £561.00
    In Stock
    The Axis M3027-PVE is a 5 megapixel fixed mini dome camera which can provide a 360° view when mounted on a ceiling or soffit and a 180° view when wall mounted. This camera has an IP66 and IK10 rated housing to protect the camera from both harsh outdoor weather conditions and vandal attempts.
    Included Accessories: - Installation guide - Installation and management software CD - Windows decoder 1-user license - Drill hole template - Resitorx L-key - Terminal block connector
    Axis M3027-PVE User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  20. Axis P5415-E PTZ Dome Network Camera 0546-001
    £1,738.51 Incl VAT Excl VAT. £1,448.76
    In Stock
    AXIS P5415-E Series comprises outdoor-ready, wall-mounted HDTV pan/tilt/zoom cameras that are aesthetically designed to blend in with a building. The attractively priced cameras are ideal for use in city and perimeter surveillance, parking houses and school yards.
    Included Accessories: - Installation guide - AVHS authentication key - Installation and management software CD - Windows decoder 1-user license - Axis camera companion
    Axis P5415-E User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  21. Axis P5414-E PTZ Dome Network Camera 0544-001
    £1,366.97 Incl VAT Excl VAT. £1,139.14
    In Stock
    Axis P5414-E PTZ Dome Network Camera is an attractively priced, outdoor-ready HDTV 720p PTZ dome with 18x optical zoom for wall mount surveillance installations. Designed to blend in with the environment, the camera is ideal for use in city surveillance, parking lots and on school grounds.
    Axis P5414-E User Manual Axis P5414-E Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  22. Axis M3026-VE 3MP Outdoor Ready Fixed Mini Dome Network Camera
    Axis M3026-VE 3MP Outdoor Ready Fixed Mini Dome Network Camera 0547-001
    £583.20 Incl VAT Excl VAT. £486.00
    In Stock
    The Axis M3026-VE is 3 megapixel, wide angle, light sensitive camera that is part of the Axis M30 series of affordably priced, vandal-resistant HDTV fixed mini domes. The M3026-VE is ideal for installation inside or outside the entrance of hotels, boutiques, restaurants, offices and schools.
    Included Accessories: - Drill hole template - Resitorx L-key - Terminal block connector - Installation guide - Installation and management software CD - Windows decoder 1-user license
    Axis M3026-VE User Manual Axis M3026-VE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  23. Axis M3025-VE Outdoor Fixed Mini Dome Network Camera 0536.001
    Axis M3025-VE Outdoor Fixed Mini Dome Network Camera 0536-001
    £467.16 Incl VAT Excl VAT. £389.30
    In Stock
    The Axis M3025-VE is an affordable, vandal-resistant HDTV fixed mini dome that provides excellent images during the day and night both indoors and outdoors. The camera is ideal for use inside or outside the entrance of a hotel, boutique, restaurant, office or school.
    Included Accessories: - Installation guide - Installation and management software CD - Windows decoder 1-user license - Drill hole template - Resitorx L-Key - Terminal block connector
    Axis M3025-VE User Manual Axis M3025-VE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  24. Axis M3024-LVE Outdoor Fixed Mini Dome Network Camera
    Axis M3024-LVE Outdoor Fixed Mini Dome Network Camera 0535-001
    £460.06 Incl VAT Excl VAT. £383.38
    In Stock
    The Axis M3024-LVE is an affordable, vandal-resistant HDTV fixed mini dome that provides excellent images both day and night. This camera is ideal for use inside or outside the entrance of a hotel, boutique, restaurant, office or school.
    Axis M3024-LVE User Manual Axis M3024-LVE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  25. Axis P3367-VE Dome Network Camera
    Axis P3367-VE Dome Network Camera 0407-001
    £1,077.60 Incl VAT Excl VAT. £898.00
    In Stock
    The Axis P3367-VE is an outdoor-ready vandal resistant fixed dome network camera. The camera is ideal for unobtrusive video surveillance in exposed areas such as airports, subways, retail stores, schools and university campuses. This 5 megapixel model can cover a large area with exceptional detail and light sensitivity, can operate in extreme temperatures from -40°C to 55°C and has an IP66- and NEMA 4X-rated, IK10 impact-resistant aluminium casing with integrated dehumidifying membrane.
    Included Accessories: - Mounting and connector kits - Installation guide - CD with installation tools - Recording software - User manual - Windows decoder 1-user license - Smoked transparent cover - Mounting bracket - Weather shield - 5m network cable with premounted gasket
    Axis P3367-VE User Manual Axis P3367-VE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  26. Axis P3367-V Dome Network Camera
    Axis P3367-V Dome Network Camera 0406-001
    £897.60 Incl VAT Excl VAT. £748.00
    In Stock
    The Axis P3367-V is an indoor vandal-resistant fixed dome network camera with an IK10 impact-resistant aluminium casing. This camera is ideal for unobtrusive video surveillance and can cover a large are with exceptional detail and light sensitivity. This camera also has a unique pixel counter feature which allows the installer to easily verify that the camera installationfulfills any reglatory or specific customer requirements.
    Axis P3367-V User Manual Axis P3367-V Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
Grid  List
