Indoor IP Cameras
Sidebar
Indoor IP Cameras
Grid  List
  1. Hikvision DS-2CD2335FWD-I/G | 4mm 3MP Grey Turret Network Camera
    The Hikvision DS-2CD2335FWD-I/G is a grey 3MP (2560 x 1920) turret camera with a 4mm fixed lens. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2335FWD-I/G is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2335FWD-I/G also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2335FWD-I/G has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
    Learn More
  2. Hikvision DS-2CD2735FWD-IZS/G Grey 3MP Motorised Zoom Dome Network Camera
    The Hikvision DS-2CD2735FWD-IZS/G is a grey 3MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2735FWD-IZS/G can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2735FWD-IZS/G has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
    Hikvision H.265+ banner
  3. Hikvision DS-2CD2155FWD-I/B | 2.8mm 5MP Black Dome Network Camera
    The DS-2CD2155FWD-I/B is a black 5MP (2560 x 1920) dome camera with the choice of either a 2.8mm, 4mm or 6mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2155FWD-I/B has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2155FWD-I/B can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  4. Hikvision DS-2CD4B36FWD-IZS 3MP Low Light Smart Bullet Camera
    Hikvision DS-2CD4B36FWD-IZS 3MP Darkfighter Smart Bullet Camera
    The Hikvision DS-2CD4B36FWD-IZS is a 3MP bullet camera with a 2.8mm-12mm motorised zoom lens which provides a 88.5° to 32.8° horizontal field of view. This camera has built in IR LEDs that are effective up to 30m, an audio/alarm I/O and uses IP67 rated weatherproof housing to ensure that the camera can be mounted externally without any concerns. The DS-2CD4B36FWD-IZS is designed for low light applications with 0.005 lux (color), or 0.0005 lux (B/W) minimum illumination with IR off and a range of imaging enhancing features: Wide dynamic range (WDR), back light/highlight compensation (BLC/HLC), electronic image stabilization (EIS) and Defog.This camera also comes with a range of smart features such as motion detection, line crossing detection, intrusion detection, object removal detection and more. The DS-2CD4B36FWD-IZS has 3-axis adjustment which means that any area of interest can be covered easily and an optional on board SD card slot for recording ease if preferred. H.265+ video compression can be used to dramatically reduce storage and bandwidth needs. This camera can be powered with either a 12V DC power supply or a PoE injector and can be accessed remotely through a browser or through the Hik-Connect app.
  5. Hikvision DS-2DE4A204IW-DE 2MP Low Light Network PTZ Camera
    Hikvision DS-2DE4A204IW-DE 2MP 4X Mini PTZ Camera
    The Hikvision DS-2DE4A204IW-DE is a 2MP PTZ with a 2.8mm-12mm lens that offers 4x optical zoom and 16x digital zoom. This PTZ is designed to work well in low light environments with the use of image enhancers such as wide dynamic range (WDR), back light compensation (BLC) and 3D digital noise reduction (3D DNR) technology. Built-in IR LEDs allow recording in complete darkness up to 50m. The DS-2DE4A204IW-DE is a great choice for external applications with IP66 rated weatherproof housing and the option for external microphones/speakers to be connected. This PTZ supports 300 presets, 8 patrols and 4 pattern scans. It is also loaded with a range of smart features to improve security such as intrusion detection, line crossing detection and region entrance/exit detection. There is an on-board SD card slot which can be utilised along with H.265+ compression; offering a huge saving on bandwidth and storage usage. This camera can be powered via a 12VDC power supply or a PoE+ injector. Remote access is possible through the Hik-Connect app or via a browser.
    Hikvision Product CatalogueHikvision Quick GuideUser Manual Learn More
  6. Hikvision DS-2DE4A225IW-DE 2MP IR Mini PTZ Camera
    Hikvision DS-2DE4A225IW-DE 2MP 25x Mini PTZ Camera
    The DS-2DE4A225IW-DE is a mini PTZ from Hikvision with 2MP resolution and a 25fps max frame rate. With a 4.7mm-94mm focal length this camera offers 25x optical zoom and built in IR LEDs that provide clear night-time images up to 50m. The DS-2DE4A225IW-DE is fitted with IP66 rated weatherproof housing and audio/alarm I/Os. It also utilises a range of features to improve image quality such as wide dynamic range (WDR), back light compensation (BLC) and 3D digital noise reduction (3D DNR). This camera supports 300 presets, 8 patrols and 4 patterns with access for up to 32 users. The DS-2DE4A225IW-DE has a built-in micro SD card slot and can be powered through a 12VDC power supply or 18W PoE injector. Remote access is possible through a browser or through the Hik-Connect app.
  7. Hikvision DS-2DE4225IW-DE 2MP 25x PTZ Camera
    The Hikvision DS-2DE4225IW-DE is a 2MP PTZ camera with a 4.8mm - 120mm lens that allows optical zooming up to 25x. This camera has infra-red LEDs that are effective up to 100m and also works in ultra low light environments by using a range of image enhancing features: wide dynamic range (WDR), highlight/back light compensation (HLC/BLC), 3D digital noise reduction technology (3D DNR) and electronic image stabilization (EIS). The DS-2DE4225IW-DE is suitable for external applications with IP66 rated weatherproof housing and the option to connect external microphones or speakers. It is also fitted with a range of smart features to further improve security such as motion detection, intrusion detection, line crossing detection and object removal detection. This PTZ supports up to 300 presets, 8 patrols and 4 pattern scans. It also utilises H.265+ compression which offers a huge saving on bandwidth and storage usage. Impressive compression means that the on board SD card slot can be utilised without the worry of reaching maximum capacity too quickly. The DS-2DE4225IW-DE can be powered with either a 12VDC power supply or PoE+ injector can can be accessed remotely though the Hik-Connect app or through a web browser.
    Hikvision E Series Network Speed Dome User ManualHikvision Product CatalogueHikvision Quick Guide Learn More
  8. Hikvision DS-2DE5225IW-AE 2MP 25x PTZ Camera
    The DS-2DE5225IW-AE is a 2MP PTZ camera from Hikvision with a 4.8mm - 120mm lens offering 25x optical zoom. With IP66 rated weatherproof housing and infra-red LEDs effective up to 150m, this PTZ is a great choice for outdoor applications where clear nighttime images over long distances are important. The DS-2DE5225IW-AE is also fitted with a range of image enhancing features that help the camera to provide impressive quality in low light environments: wide dynamic range (WDR), highlight/back light compensation (HLC/BLC), 3D digital noise reduction (3D DNR), defog, electronic image stabilization (EIS) and regional exposure/focus. Along with image enhancing features, this camera also supports a range of smart features to improve security further such as motion detection, intrusion detection, line crossing detection and many more. The DS-2DE5225IW-AE also supports 300 presets, 8 patrols and 4 pattern scans. This PTZ also supports H.265+ compression which means that the on board SD card slot can be utilised without concern of reaching maximum capacity so quickly. It can be powered by both 24V AC power supply and a 30W PoE injector. The DS-2DE5225IW-AE can be accessed remotely though the Hik-Connect app or through a browser.
  9. Hikvision DS-2DE7232IW-AE 2MP 32x PTZ Camera
    The DS-2DE7232IW-AE is a 2MP PTZ camera from Hikvision with a 4.8mm-153mm lens providing 32x optical zoom. This camera is a great choice for external applications with an audio/alarm I/O, IP66 rated weatherproof housing and infra-red LEDs that are effective up to 150m. The DS-2DE7232IW-AE also performs really well in low light environments by using a range of image enhancing features such as wide dynamic range (WDR), highlight/back light compensation (HLC/BLC), 3D digital noise reduction (3D DNR), defog, electronic image stabilization (EIS) and regional exposure/focus. Along with image enhancing, the DS-2DE7232IW-AE also features improved security by using smart features such as motion detection, intrusion detection, line crossing detection object removal detection and more. This camera also supports a range of PTZ functions such as 300 presets, 8 patrols and 4 pattern scans. The DS-2DE7232IW-AE uses H.265+ video compression which dramatically reduces bandwidth and storage usage. This camera supports on board storage and can be powered by either a 24V AC power supply or by a 40W hi-poe injector. Remote access is possible through a browser or via the Hik-Connect app.
  10. Hikvision DS-2DF6A236X-AEL 2MP 36X PTZ Camera
    The Hikvision DS-2DF6A236X-AEL is a 2MP PTZ camera with a 5.7mm - 205.2mm lens that can provide up to 36x optical zoom and 16x digital zoom. This camera is perfect for external applications with IK10 rated vandal proof housing and IP67 rated weatherproof housing. The DS-2DF6A236X-AEL is equipped with a variety of image enhancing features which make it perfect for low light environments: 120dB wide dynamic range (120dB), 3D digital noise reduction (3D DNR), highlight/back light compensation (HLC/BLC), defog, electronic image stabilization (EIS). With the help of these features the DS-2DF6A236X-AEL is effective in colour at 0.002 lux and black and white at 0.0002 lux. This camera also uses a range of smart features in improve security such as intrusion detection, line crossing detection, face detection and many more. It also uses the latest technology in auto tracking and can track specific target types such as humans or vehicles. The DS-2DF6A236X-AEL supports 300 presets, 8 patrols and 4 pattern scans. IT also supports H.265+ video compression which offers a huge saving on bandwidth and storage usage meaning that the on-board SD card slot can be used more effectively. This PTZ can be powered by a 24V AC power supply or by 50W PoE injector and can be accessed remotely through a browser or through the Hik-Connect app.
    Hikvision Product Catalogue Hikvision Quick Guide Learn More
  11. Axis P1290 Thermal Network Camera 01168-001
    £909.60 Incl VAT Excl VAT. £758.00
    The Axis P1290 is a cost effective indoor thermal camera with a 208 x 156 resolution and a 35° field of view. Thermal technology ensures a reliable detection with low rate of false alarms. The camera is protected in a fixed dome enclosure and can be used for surveillance in both retail and residential applications. The P1290 can be used as a sensor to avoid compromising privacy; for example schools and care homes thermal imaging detects incidents without revealing personal details of the people in the image. Used with Axis analytics the thermal camera can trigger alerts or alarms in response to patient or resident falls, which allows staff to take immediate action. Included Accessories: - Installation guide - Windows decoder 1-user license - AVHS Authentication key - Rotation tool
    Please contact us for stock levels, this camera may have a 10-14 day lead time for delivery.
    Axis P1290 User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table Autumn 2016 Axis Product Guide
    Learn More
  12. Vivotek IB8382-ET 5MP Vari-focal Extreme Weather Bullet Camera
    £444.68 Incl VAT Excl VAT. £370.57
    The IB8382-ET is a 5MP vari-focal bullet camera from Vivotek that is suitable for use both indoors and outdoors thanks to its IP66, IK10 rated housing. This camera can also be subject to extreme weather conditions of -50°C ~ 50°C thanks to a built-in heater. The Vivotek IB8382-ET also benefits from built-in infra-red illuminators that allow you to capture images in the dark up to 30m away. Wide dynamic range and 3D noice reduction mean the IB8382-ET is capable of capturing high quality images in extremely bright or dark conditions.
    This item may not be available for immediate delivery. Please check with us before purchasing as it could take 10-14 days to fetch from Vivotek.
    User Manual Quick Installation Guide Learn More
  13. Vivotek FD8382-ETV 5MP Vari-Focal Extreme Weather Dome Camera
    The Vivotek FD8382-ETV is a 5MP vari-focal dome camera with built-in infra-red LED's and two-way audio. The housing is IP66-rated and IK-10 rated meaning the camera can be used both indoors and outdoors in extreme weather conditions. This camera comes ready for changing environments, with wide dynamic range for improved visibility in bright and dark situations. The FD8382-ETV also benefits from video rotation through its corridor view.
  14. Vivotek FD8169A 2MP IR Dome Camera
    £152.40 Incl VAT Excl VAT. £127.00
    The Vivotek FD8169A is an affordable 2MP indoor dome camera with built-in infra-red LED's meaning it can see up to 20m in the dark. The removable IR-cut filter also allows the FD8169A to adapt to changing lighting conditions so the user can capture high quality images in all lighting situations. This camera also benefits from a built-in MicroSD/SDHC/SDXC card slot for on-board storage. The built-in 2.8mm lens can capture a 114° horizontal field of view and as the camera is only 129mm wide, it is perfect for compact applications that require a discreet solution.
    User Manual Quick Installation Guide Accessories Chart Learn More
  15. Hikvision DS-2CD2H35FWD-IZ 3MP Vari-focal Turret Network Camera
    *SPECIAL OFFER* Hikvision DS-2CD2H35FWD-IZS 3MP Motorised Zoom Turret Network Camera *OPEN BOX*
    OPEN BOX ~ Only 1 Available!
    The Hikvision DS-2CD2H35FWD-IZS is a 3MP (2048 x 1536) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H35FWD-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H35FWD-IZS also uses a range of smart features such as line crossing detection, intrusion detection and object removal detection. As with all cameras in the EasyIP 3.0 family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H35FWD-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
    Hikvision DS-2CD2H35FWD-IZ banner
  16. Wisenet XNO-6020R/INT 2MP Intrusion Pro Bullet Camera
    Wisenet XNO-6020R/INT 2MP AI-Intrusion Pro Bullet Camera
    £691.73 Incl VAT Excl VAT. £576.44
    Due 30 Jul 2018
    The Wisenet XNO-6020R/INT is an out-of-box solution that allows users to intelligent video analytics from A.I. Tech to reliably detect any activity occurring in prohibited zones. Wisenet and A.I. Tech have worked together to product this advanced application, which is suitable for use both indoors and outdoors in environments that require an intelligent security solution. The XNO-6020R/INT is a 2 megapixel network IR bullet camera that is part of the the Wisenet X series of cameras with improved features such as; people counting, queue management, loitering and directional detection. The camera also benefits from built-in infra-red LED's that enable it to see up to 30m in the dark. Alarm events picked up by the smart A.I. Tech technology built in to the XNO-6020R/INT can be sent to Wisenet NVR's and is supported by Wisenet WAVE and Wisenet SSM VMS. It is also supported by third party VMS, including Milestone Xprotect. XRN-1610S banner
    This product may not be immediately available from UK stock, in which case there will be a 7 day lead time to fetch from their European warehouse. Intrusion Detection Solution Brochure A.I. Tech Brochure
    Learn More
  17. Wisenet XND-6085 2MP Varifocal Low-light Dome Camera
    £743.81 Incl VAT Excl VAT. £619.84
    The Wisenet XND-6085 is a 2MP vari-focal dome camera that boasts digital Pan, Tilt, Rotate and Zoom (DPTRZ) to make installation and configuration easier. Plus, the user can select hallway view, which allows the user to fit the camera in a narrow environment. The XND-6085 has extraLUX technology allowing it to perform extremely well in low light conditions of 0.004 Lux@F0.94 (Color) and 0.0004 Lux@F0.94 (B/W). It also benefits from the wide range of smart technology the X-series is known for, including fog detection, audio detection and motion detection. XRN-1610S banner
  18. Wisenet XND-6085V 2MP Varifocal Low-light IK08 Dome Camera
    £806.57 Incl VAT Excl VAT. £672.14
    The Wisenet XND-6085V is a 2MP vari-focal dome camera that boasts digital Pan, Tilt, Rotate and Zoom (DPTRZ) to make installation and configuration easier. Plus, the user can select hallway view, which allows the user to fit the camera in a narrow environment. The XND-6085V has extraLUX technology allowing it to perform extremely well in low light conditions of 0.004 Lux@F0.94 (Color) and 0.0004 Lux@F0.94 (B/W). It also benefits from the wide range of smart technology the X-series is known for, including fog detection, audio detection and motion detection. In addition, the XND-6085V is suitable for use in a wide range of indoor environments thanks to its IK08 vandal resistant-rated housing. XRN-1610S banner
  19. Hikvision DS-2CD2323G0-I 2MP Turret Network Camera
    This turret camera is part of Hikvision's brand new Easy IP 2.0+ range released in June 2018. The Hikvision DS-2CD2323G0-I is a 2MP (1920 x 1080) turret camera available in 2.8mm and 4mm fixed focal lengths. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2323G0-I is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2323G0-I also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2323G0-I has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
  20. Hikvision DS-2CD2343G0-I 4MP Turret Network Camera
    This turret camera is part of Hikvision's brand new Easy IP 2.0+ range released in June 2018. The Hikvision DS-2CD2343G0-I is a 4MP (2560 x 1440) turret camera available in 2.8mm, 4mm and 6mm fixed focal lengths. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2343G0-I is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2343G0-I also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2343G0-I has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
  21. Hikvision DS-2CD2H23G0-IZS 2MP Motorised Zoom Turret Network Camera
    The Hikvision DS-2CD2H23G0-IZS is a 2MP (1920 x 1080) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. This camera is from Hikvision's newest EasyIP 2.0+ range released in June 2018. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H23G0-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H23G0-IZS also uses a range of smart features such as line crossing detection and intrusion detection. As with all cameras in the EasyIP 2.0+ family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H23G0-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
  22. Hikvision DS-2CD2H43G0-IZS 4MP Motorised Zoom Turret Network Camera
    The Hikvision DS-2CD2H43G0-IZS is a 4MP (2560 x 1440) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. This camera is from Hikvision's newest EasyIP 2.0+ range released in June 2018. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H43G0-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H43G0-IZS also uses a range of smart features such as line crossing detection and intrusion detection. As with all cameras in the EasyIP 2.0+ family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H43G0-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
  23. Hikvision DS-2CD2123G0-I 2MP Dome Network Camera
    The DS-2CD2123G0-I is a 2MP (1920 x 1080) dome camera from Hikvision's brand new EasyIP 2.0+ range, released in June 2018. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2123G0-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2123G0-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  24. Hikvision DS-2CD2123G0-IS 2MP Dome Network Camera
    The DS-2CD2123G0-IS is a 2MP (1920 x 1080) dome camera from Hikvision's brand new EasyIP 2.0+ range, released in June 2018. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2123G0-IS has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. There is also an alarm I/O which provides the user with the option to utilize an external microphone or speaker. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2123G0-IS can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  25. Hikvision DS-2CD2143G0-I 4MP Dome Network Camera
    The DS-2CD2143G0-I is a 4MP (2688 x 1520) dome camera from Hikvision's brand new EasyIP 2.0+ range, released in June 2018. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2143G0-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2143G0-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  26. Hikvision DS-2CD2143G0-IS 4MP Dome Network Camera
    The DS-2CD2143G0-IS is a 4MP (2688 x 1520) dome camera from Hikvision's brand new EasyIP 2.0+ range. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2143G0-IS has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. This camera also includes an audio I/O to provide users with the option of connecting an external microphone/speaker. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2143G0-IS can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  27. Hikvision DS-2CD2723G0-IZS 2MP Motorised Zoom Dome Network Camera
    The Hikvision DS-2CD2723G0-IZS is a 2MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is from Hikvision's brand new EasyIP 2.0+ range, launched in June 2018. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2723G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection and intrusion detection. The DS-2CD2723G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  28. Wisenet XNB-6005 2MP Box Camera
    £501.60 Incl VAT Excl VAT. £418.00
    The Wisenet XNB-6005 is a 2MP box camera that is capable of capturing up to 60 frames per second using both H.265 and H.264 compression. This camera also has a built in SD card slot and bi-directional audio support. The XNB-6005 benefits from low light capabilities of 0.006 Lux@F1.2 (Color) and 0.0006 Lux@F1.2 (B/W). In addition it brings all the benefits of the Wisenet X-series, including loitering, directional detection and fog detection. Please note this camera does not include the lens. XRN-1610S banner
  29. Hikvision DS-2CD2743G0-IZS 4MP Motorised Zoom Dome Network Camera
    The Hikvision DS-2CD2743G0-IZS is a 4MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is from Hikvision's brand new EasyIP 2.0+ range, launched in June 2018. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2743G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection and intrusion detection. The DS-2CD2743G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  30. Wisenet XNP-6320 2MP Indoor PTZ Dome Camera
    £2,146.80 Incl VAT Excl VAT. £1,789.00
    The Wisenet XNP-6320 is a 2MP indoor PTZ dome camera that has a built-in SD card slot and bi-directional audio. It is capable of H.265, H.264 and MJPEG compression and can be used with the SHP-3701H housing to make it suitable for use outdoors. The XNP-6320 is also compatible with a wide range of mounting accessories, meaning it can be used in a selection of applications. XRN-1610S banner
  31. Hikvision DS-2CD2623G0-IZS 2MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2623G0-IZS is a 2MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is from Hikvision'a brand new Easy IP 2.0+ range. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2623G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection and line crossing detection. The DS-2CD2623G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  32. Hikvision DS-2CD2643G0-IZS 4MP Motorised Zoom Bullet Network Camera
    The Hikvision DS-2CD2643G0-IZS is a 4MP bullet camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 50m. This camera is from Hikvision'a brand new Easy IP 2.0+ range. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2643G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection and line crossing detection intrusion detection. The DS-2CD2643G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  33. Hikvision DS-2CD2T23G0-I5 2MP Bullet Network Camera
    The DS-2CD2T23G0-I5 is a 2MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T23G0-I5 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
    Hikvision Easy IP 3.0 banner for DS-2CD2TX5FWD-
  34. Hikvision DS-2CD2T23G0-I8 2MP Bullet Network Camera
    The DS-2CD2T23G0-I8 is a 2MP bullet camera with powerful infra-red LEDs that work up to 80m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T23G0-I8 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
  35. Hikvision DS-2CD2T43G0-I8 4MP Bullet Network Camera
    The DS-2CD2T43G0-I8 is a 4MP bullet camera with powerful infra-red LEDs that work up to 80m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T43G0-I8 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
  36. Hikvision DS-2CD2063G0-I 6MP Mini Bullet Network Camera
    The Hikvision DS-2CD2063G0-I is a 6MP mini bullet camera that is available in either a 2.8mm or 4mm fixed lens. This camera comes fitted with infra-red LEDs that are effective up to 30m and IP67 rated weatherproof housing. This camera is from Hikvision's brand new EasyIP 2.0+ range released in June 2018. The DS-2CD2063G0-I also comes with a built in bracket that has 3-axis adjustability so there is a lot of flexibility if you need to cover a wide area. The image is improved using back light compensation (BLC) and 3D digital noise reduction technology (3D DNR). The DS-2CD2063G0-I also utilises smart features such as motion detection, line crossing detection and intrusion detection to improve security even further. Fitted with Hikvision's H.265+ video compression, the on board SD card slot can be used without worry of using up the memory so quickly. This camera can be powered by 12VDC power supply or PoE, it can be accessed remotely through a browser or by using the Hik-connect app.
    Hikvision Mini Bullet banner for easy IP 3.0 range
  37. Hikvision DS-2CD2043G0-I 4MP Mini Bullet Network Camera
    The Hikvision DS-2CD2043G0-I is a 4MP mini bullet camera that is available in a 2.8mm fixed lens. This camera comes fitted with infra-red LEDs that are effective up to 30m and IP67 rated weatherproof housing. This camera is from Hikvision's brand new EasyIP 2.0+ range released in June 2018. The DS-2CD2043G0-I also comes with a built in bracket that has 3-axis adjustability so there is a lot of flexibility if you need to cover a wide area. The image is improved using back light compensation (BLC) and 3D digital noise reduction technology (3D DNR). The DS-2CD2043G0-I also utilises smart features such as motion detection, line crossing detection and intrusion detection to improve security even further. Fitted with Hikvision's H.265+ video compression, the on board SD card slot can be used without worry of using up the memory so quickly. This camera can be powered by 12VDC power supply or PoE, it can be accessed remotely through a browser or by using the Hik-connect app.
  38. Hikvision DS-2CD2783G0-IZS 8MP Motorised Zoom Dome Network Camera
    The Hikvision DS-2CD2783G0-IZS is a 8MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is from Hikvision's brand new EasyIP 2.0+ range, launched in June 2018. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2783G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection and intrusion detection. The DS-2CD2783G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  39. Hikvision DS-2CD2383G0-I 8MP Turret Network Camera
    This turret camera is part of Hikvision's brand new Easy IP 2.0+ range released in June 2018. The Hikvision DS-2CD2383G0-I is a 8MP (3840 x 2160) turret camera available in 2.8mm, 4mm and 6mm fixed focal lengths. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2383G0-I is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2383G0-I also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2383G0-I has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
  40. Axis Q3518-LVE 4K Outdoor Dome Camera 01493-001
    £1,444.80 Incl VAT Excl VAT. £1,204.00
    The Axis Q8518-LVE is a 4K outdoor dome camera featuring many of Axis' high quality functions such as; - Forensic WDR ~ which enables the camera to deliver excellent detail even in scenes where there are both extremely bright and dark areas - Lightfinder Technology ~ enabling sharp images and colour in low light - OptimisedIR ~ ensures excellent low-noise video even in complete darkness - Zipstream Technology ~ preserves important details in full image quality whilst reducing storage and bandwidth by around 50%
    Designed for outdoor use this camera is able to withstand extreme temperatures ranging from -50°C to 60°C and has a weatherproof shield to protect the camera against, sun, rain and snow. Not only this but its IP166, IP66 and NEMA 4X-rated casing also protects the camera from water, corrosion and dust.
    Included Accessories: - Installation guide - Windows decoder 1-user license - Drill hole template - Cable gaskets - I/O and DC connectors - Connector guard - Weathershield - Axis U-shape conduit adapter Resitorx T20 L-key - Mounting bracket
    Axis Q3518-LVE User Manual Axis Q3518-LVE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide FREE 30-day trial of Axis Camera Station software Articles about Axis Network Cameras Learn More
  41. Hikvision DS-2CD2H55FWD-IZ 5MP Vari-focal Turret Network Camera
    *SPECIAL OFFER* Hikvision DS-2CD2H55FWD-IZS 5MP Motorised Zoom Turret Network Camera *OPEN BOX*
    The Hikvision DS-2CD2H55FWD-IZS is a 5MP (2944 x 1656) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H55FWD-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H55FWD-IZS also uses a range of smart features such as line crossing detection, intrusion detection and object removal detection. As with all cameras in the EasyIP 3.0 family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H55FWD-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
  42. Hikvision DS-2CD2163G0-I 6MP Dome Network Camera
    The DS-2CD2163G0-I is a 6MP (3072 × 2048) dome camera from Hikvision's brand new EasyIP 2.0+ range, released in June 2018. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2163G0-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2163G0-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  43. Hikvision DS-2CD2163G0-IS 6MP Dome Network Camera
    The DS-2CD2163G0-IS is a 6MP (3072 × 2048) dome camera from Hikvision's brand new EasyIP 2.0+ range, released in June 2018. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2163G0-IS has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. This camera also utilises an audio I/O to support external microphones. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2163G0-IS can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  44. Hikvision DS-2CD2183G0-I 8MP Dome Network Camera
    The DS-2CD2183G0-I is a 8MP (3840 x 2160) dome camera from Hikvision's brand new EasyIP 2.0+ range, released in June 2018. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2183G0-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2183G0-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  45. Hikvision DS-2CD2183G0-IS 8MP Dome Network Camera
    The DS-2CD2183G0-IS is a 8MP (3840 x 2160) dome camera from Hikvision's brand new EasyIP 2.0+ range, released in June 2018. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2183G0-IS has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. This model has an audio I/O to support an external microphone. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2183G0-IS can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  46. Hikvision DS-2CD2763G0-IZS 6MP Motorised Zoom Dome Network Camera
    The Hikvision DS-2CD2763G0-IZS is a 6MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is from Hikvision's brand new EasyIP 2.0+ range, launched in June 2018. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2763G0-IZS can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection and intrusion detection. The DS-2CD2763G0-IZS has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
  47. Hikvision DS-2CD2363G0-I 6MP Turret Network Camera
    This turret camera is part of Hikvision's brand new Easy IP 2.0+ range released in June 2018. The Hikvision DS-2CD2363G0-I is a 6MP (3072 x 2048) turret camera available in 2.8mm and 4mm fixed focal lengths. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2363G0-I is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2363G0-I also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2363G0-I has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
  48. Hikvision DS-2CD2H63G0-IZS 6MP Motorised Zoom Turret Network Camera
    The Hikvision DS-2CD2H63G0-IZS is a 6MP (3072 x 2048) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. This camera is from Hikvision's newest EasyIP 2.0+ range released in June 2018. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H63G0-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H63G0-IZS also uses a range of smart features such as line crossing detection and intrusion detection. As with all cameras in the EasyIP 2.0+ family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H63G0-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
  49. Hikvision DS-2CD2H83G0-IZS 8MP Motorised Zoom Turret Network Camera
    The Hikvision DS-2CD2H83G0-IZS is a 8MP (3840 x 2160) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. This camera is from Hikvision's newest EasyIP 2.0+ range released in June 2018. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H83G0-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H83G0-IZS also uses a range of smart features such as line crossing detection and intrusion detection. As with all cameras in the EasyIP 2.0+ family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H83G0-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
  50. Hikvision DS-2CD2T63G0-I5 6MP Bullet Network Camera
    The DS-2CD2T63G0-I5 is a 6MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T63G0-I5 supports Hikvision's latest H.265+ video compression which dramatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
Grid  List
