Indoor IP Cameras
Sidebar
Indoor IP Cameras
Grid  List
  1. Hikvision DS-2CD4B26FWD-IZS 2MP Darkfighter Smart Bullet Camera
    The Hikvision DS-2CD4B26FWD-IZS is a 2MP bullet camera with a 2.8mm-12mm motorized lens. This camera is great for external applications as it comes fitted with IP67 rated weatherproof housing and built-in infra-red LEDs that are effective up to 30m. The DS-2CD4B26FWD-IZS is a versatile camera that can be mounted in a variety of ways with a built-in bracket that uses 3-axes adjust-ability. This camera is designed to work in low light environments by using a range of features which ensures high quality images are recorded in 0.002 lux (colour) and 0.0002 lux (black/white) before the infra-red switches on. Wide dynamic range (WDR), defog, electronic image stabilization (EIS), 3D digital noise reduction (3D DNR) and highlight/back light compensation (HLC/BLC) are all used to ensure that the best quality images are captured at all times. The DS-2CD4B26FWD-IZS also uses a range of smart features to improve security such as intrusion detection, line crossing detection, motion detection and many more. There is the option to connect an external microphone or speaker if you wish to use audio along with your footage. This camera has an on-board SD card slot and can be powered by either a 12VDC power supply or by PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    Hikvision Product CatalogueHikvision Quick GuideHikvision Dark Fighter CatalogueUser Manual
    Learn More
  2. Hikvision DS-2CD4D26FWD-IZS 2MP Darkfighter Smart Dome Camera
    The Hikvision DS-2CD4D26FWD-IZS is a 2MP dome camera with a 2.8mm-12mm motorized, vari-focal lens. This camera is a great choice for external applications as it comes fitted with IP66 rated weatherproof housing and built-in infra-red LEDs that are effective up to 30m. The DS-2CD4D26FWD-IZS is a Darkfighter camera designed to produce high quality images in low light environments with the use of enhancing features such as wide dynamic range (WDR), defog, back light compensation (BLC) and electronic image stabilization (EIS). It also supports a range of smart features such as intrusion detection, motion detection and line crossing detection. This camera is versatile with 3-axis adjustment and a range of mounting options (please see the frequently bought together section). It also comes with the option of using on board storage and can be powered with either a 12VDC power supply or by PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    User ManualHikvision Product CatalogueHikvision Quick GuideHikvision Dark Fighter Catalogue Learn More
  3. Vivotek IP8152 Mini Box Network Camera
    £302.17 Incl VAT Excl VAT. £251.81
    This product is now End of Life. Please feel free to browse our Vivotek category. This is a compact box camera from Vivotek with a vari focal lens and a 1.3MP sensor. This camera is capable of outputting 30 fps at 1280 x 1024 resolution. The IP8152 uses Supreme Night Visibility to provide excellent video quality at all hours of the day and in any lighting conditions.
    This product is subject to a 14-day lead-time to fetch it from manufacturer's Taiwan stock/ there may be no UK stock of this model. Please check stock before purchasing.
    Vivotek IP8152 User ManualVivotek IP8152 Installation GuideProduct BrochureSurveillance Handbook Learn More
  4. Vivotek IP8131 Cube Camera
    Vivotek IP8131 Cube Network Camera
    £157.20 Incl VAT Excl VAT. £131.00
    Out of Stock
    This product is now End of Life. Please feel free to browse the rest of our Vivotek category.
    The IP8131 is a cube camera from Vivotek that is compact making it perfect for personal use. This camera also comes with a built-in microphone and IR LEDs meaning it is suitable for many applications. Equipped with a 1MP sensor, this camera can out put 30 fps at a 1280 x 800 resolution.
    This product is subject to a 14-day lead-time to fetch it from manufacturer's Taiwan stock/ there is no UK stock of this model
    Vivotek IP8131 User ManualVivotek IP8131 Installation GuideProduct BrochureSurveillance Handbook Learn More
Grid  List
