Indoor IP Cameras
£2,248.80 Incl VAT Excl VAT. £1,874.00
The Axis Q6054 Mk III is an indoor PTZ dome with 720p resolution, fast & accurate pan/tilt performance and 30x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
It also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilisation, two-way audio, I/O ports and 24V AC/DC power.
- Axis PoE+ midspan 1-port
- Recessed mount for hard and drop ceilings
- Smoked dome cover
- Installation Guide
£674.40 Incl VAT Excl VAT. £562.00
The Axis P3235-LV is a HDTV 1080p indoor fixed dome camera with two-way audio and I/O ports. The camera comes equipped with audio connectors for line out and mic or line in and also has a supervised digital output.
You can easily connect a microphone and speaker and take advantage of audio and video in one stream, listen in on transactions or incidents and trigger audio warnings.
A sensor or detector can be connected to the camera's digital input to trigger alarms or actions, users can also connect a device such as a relay to the digital output to activate lights or lock/unlock doors and be controlled by the camera.
The camera features some of Axis' high quality functions such as: WDR Forensic Capture ~ for clarity when there are both dark and light areas in the scene Lightfinder ~ for high quality colour images even when they're recorded in near darkness P-Iris Control ~ for optimal clarity and depth of field OptimisedIR ~ ensures even illumination for excellent video quality even in complete darkness
£2,377.20 Incl VAT Excl VAT. £1,981.00
£1,926.00 Incl VAT Excl VAT. £1,605.00
The GV-VR360 is a virtual reality camera from Geovision comprised of two 4MP fisheye cameras to provide a 720° panoramic view with no blind spots. With 4 built in IR LEDs effective up to 10m, IP67 rated weather proof housing and IK10 rated vandal resistant housing this camera is more that suitable for use internally or externally. This camera utilises a range of built-in image enhancers to ensure that quality is kept at its best day and night: Flicker-less, image orientation, day/night sensitivity, wide dynamic range, defog and metering. Providing a live view of any area with a 720° field of view and extended depth of field, the GV-VR360 can be streamed live to YouTube or to the GV-Eye app allowing users to enjoy a completely immersive experience. This camera uses H.265 to efficiently compress images and reduce stress on bandwidth or storage requirements. It can be powered by a 12VDC power supply or via PoE+ injector and can be remotely accessed through internet explorer or through the GV-Eye app.
£2,006.40 Incl VAT Excl VAT. £1,672.00
£2,132.40 Incl VAT Excl VAT. £1,777.00
£1,623.60 Incl VAT Excl VAT. £1,353.00
£1,837.20 Incl VAT Excl VAT. £1,531.00
£495.60 Incl VAT Excl VAT. £413.00
£444.00 Incl VAT Excl VAT. £370.00
£440.40 Incl VAT Excl VAT. £367.00
The Geovision GV-EVD5100 is a 5MP dome camera with a vari-focal 2.8mm~12mm lens and intelligent IR LEDs effective up to 30m. Fitted with IP67 rated weatherproof housing and IK10 vandal resistant housing, this camera is a sturdy choice for outdoor applications. The GV-EVD5100 has a 3-axis mechanism for precise set up ensuring any area of interest can be easily covered. This camera also supports two way audio for the connection of an external microphone and speaker. With a range of image enhancers such as wide dynamic range, back light compensation, 3D noise reduction and image configuration such as contrast, brightness and saturation, the GV-EVD5100 can provide excellent video quality day or night. Security is further improved with the use of motion detection, tampering alarm and privacy mask. This camera supports on board storage and H.264 compression. It can be powered by a 12VDC power supply or by PoE and remote access is possible through internet explorer or the GV-Eye app.
Vandal Resistant Dome Quick Start GuideGeovision Brochure
Geovision Mount Guide Learn More£200.40 Incl VAT Excl VAT. £167.00
£108.00 Incl VAT Excl VAT. £90.00
£164.40 Incl VAT Excl VAT. £137.00
The GV-ADR4701 is a 4MP mini dome camera from Geovision with a 2.8mm fixed lens and intelligent IR LEDs effective up to 30m. With IP67 rated weatherproof housing, IK10 vandal resistant housing and the ability to pan (0°~360°) and tilt (0°~68°) this camera is a versatile choice for both internal and external applications. The GV-ADR4701 uses wide dynamic range to improve image quality in areas with intense bright and dark areas which would normally cause an issue. The camera configuration allows users to adjust brightness, contrast, saturation, sharpness and orientation to provide the perfect image in any application. It also supports features such as motion detection to further improve security. This camera supports triple streams from H.264, H,264 and MJPEG and can be powered by either PoE or a 12VDC power supply. Remote access is possible through internet explorer or through the GV-Eye app.
BUILT TO ORDER - PLEASE ALLOW 5-7 WORKING DAYS FOR DELIVERY.
Quick Start GuideUser ManualGeovision BrochureGeovision Mount Guide Learn More
£604.80 Incl VAT Excl VAT. £504.00
Geovision Mount Guide Learn More£692.40 Incl VAT Excl VAT. £577.00
Geovision Mount Guide Learn More£306.00 Incl VAT Excl VAT. £255.00
Geovision Mount Guide Learn More£542.40 Incl VAT Excl VAT. £452.00
Quick Start GuideGeovision BrochureGeovision Mount Guide Learn More
£410.40 Incl VAT Excl VAT. £342.00
£366.00 Incl VAT Excl VAT. £305.00
£248.40 Incl VAT Excl VAT. £207.00
£358.80 Incl VAT Excl VAT. £299.00
£399.60 Incl VAT Excl VAT. £333.00
The GV-ABL4701 is a 4MP bullet camera from Geovision with a 4mm fixed lens providing a wide 78° horizontal field of view. This camera is great for domestic, external applications with 30m IR range and IP66 rated weatherproof housing. This camera uses a range of image enhancing features to improve quality such as wide dynamic range, defog and 3D noise reduction technology. It also supports smart features such as motion detection and privacy mask. The GV-ABL4701 supports triple streams from H.265, H.264 and MJPEG and can be powered by either a 12VDC power supply or by PoE. Remote access is possible through a browser or through the GV-Eye app.
Learn More£264.00 Incl VAT Excl VAT. £220.00
Learn More£114.00 Incl VAT Excl VAT. £95.00
Learn More£276.00 Incl VAT Excl VAT. £230.00
£170.40 Incl VAT Excl VAT. £142.00
£144.00 Incl VAT Excl VAT. £120.00
Due 19 Oct 2018
The Milesight UI-2A75-PCV is a 2 megapixel weather resistant mini dome camera equipped with many advanced features including video content analysis.
Milesight VCA has 8 detection modes: - Region entrance - Region exiting - Advanced motion detection - Tamper detection - Line crossing - Loitering - Human detection - People counting These modes enable users to further enhance their surveillance by enabling quicker response times to monitoring scenes. Other advanced features include:
Smart IR II Technology ~ featuring Milesight's Smart IR II greatly improves IR performance with the adjustable illumination intensity and anti-reflection IR panel.
3-Axis Mechanical Design ~ allows for fast and easy adjustment of the camera.
£168.00 Incl VAT Excl VAT. £140.00
Due 19 Oct 2018
The Milesight UI-5D75-PCV is a 5 megapixel weather resistant mini dome camera and one of the newest additions to the Milesight family, the Mini Series 3.0.
Taking on Milesight's new style dome structure this camera brings a 2018 update to their previous mini dome models and also features the newest Sony sensors.
Smart IR II Technology ~ combining both High and Low beam LEDs and with an anti-reflection panel IR illumination is greatly improved.
3-Axis Mechanical Design ~ allows for fast and easy adjustment of the camera which enables users to position the camera precisely depending on the individual application.
Due 19 Oct 2018
The UI-2A64-PCV is the first Vandal Resistant bullet camera from Milesight. This 2MP camera is packed full of Milesight's most advanced features including:
Smart IR II Technology ~ with an IR anti reflection panel IR performance is greatly improved.
New Design ~ same high quality in a more compact style. Milesight have reduced the size of the mini bullet from 76 x 208mm to 64 x 160mm without compromising on any of the features.
IP67 & IK10 ~ supporting both IP67 weather resistance and IK10 vandal resistance adds to the camera's appeal.
Due 19 Oct 2018
The Milesight UI-5D64-PCV is a 5MP vandal resistant mini bullet camera and one of the newest additions to the Milesight range.
£204.00 Incl VAT Excl VAT. £170.00
Due 19 Oct 2018
The Milesight UI-2A64-FIPCV is a 2MP vandal resistant mini bullet camera and one of the newest additions to the Milesight range.
£228.00 Incl VAT Excl VAT. £190.00
Due 19 Oct 2018
The Milesight UI-5D64-FIPCV is a 5MP vandal resistant motorised mini bullet camera, one of the first of it's kind. Vandal resistance is a rare feature in a bullet style camera which makes this camera even more impressive.
