Indoor IP Cameras
Sidebar
Indoor IP Cameras
Grid  List
  1. Geovision GV-MFD4700 4MP Indoor Mini Dome
    £306.00 Incl VAT Excl VAT. £255.00
    The GV-MFD4700 is a 4MP indoor dome camera with a choice of either a 2.8mm (96°), 3.8mm (72°) or 2.3mm (129°) fixed lens. This camera supports two-way audio, one sensor input and an alarm output. Any area of interest can be covered with ease with the use of a 3-axis mechanism providing pan (‐45° ~ 45°), tilt (0° ~ 70°) and rotate (0° ~ 360°) adjustability. The GV-MFD4700 uses a range of image enhancing features to improve recording quality such as wide dynamic range, backlight compensation, defog, low lux enhancement and 3D noise reduction technology. It also supports smart features to improve security such as motion detection, tampering alarm, focus change and camera shift. For user friendliness this camera supports triple streams including H.265 and also supports on board storage with a micro SD card slot. The GV-MFD4700 can be powered by a 12VDC power supply or by a PoE injector. Remote access is possible through a web browser or through the GV-Eye app.
    GV-MFD2700 packing list
    Quick Start GuideGeovision BrochureGeovision Mount Guide Learn More
  2. Geovision GV-EBL4702 4MP Bullet Camera
    £248.40 Incl VAT Excl VAT. £207.00
    The GV-EBL4702 is a 4MP bullet camera from Geovision with the choice of a 2.8mm, 3.8mm or 6mm fixed lens. This camera uses intelligent infra-red effective up to 30m and is protected by both IP67 weatherproof housing and IK10 vandal resistant housing. This camera has the ability to pan (0° ~ 360°) and tilt (90° ~ 180°) so adjustability isn't an issue. The GV-EBL4702 uses a range of image enhancing features such as wide dynamic range, defog, low lux enhancement and denoise. It also supports some smart features such as tampering alarm and IP address filtering. The GV-EBL4702 supports on board storage and has the capability to use dual streams from H.265, H.264 and MJPEG. It can be powered by either a 12VDC power supply or by POE. Remote access is possible through internet explorer or through the GV-Eye app.
    GV-EBL4711 packing list
  3. Geovision GV-ADR4701 4MP 2.8mm Mini Rugged Dome
    £164.40 Incl VAT Excl VAT. £137.00
    The GV-ADR4701 is a 4MP mini dome camera from Geovision with a 2.8mm fixed lens and intelligent IR LEDs effective up to 30m. With IP67 rated weatherproof housing, IK10 vandal resistant housing and the ability to pan (0°~360°) and tilt (0°~68°) this camera is a versatile choice for both internal and external applications. The GV-ADR4701 uses wide dynamic range to improve image quality in areas with intense bright and dark areas which would normally cause an issue. The camera configuration allows users to adjust brightness, contrast, saturation, sharpness and orientation to provide the perfect image in any application. It also supports features such as motion detection to further improve security. This camera supports triple streams from H.264, H,264 and MJPEG and can be powered by either PoE or a 12VDC power supply. Remote access is possible through internet explorer or through the GV-Eye app.
    GV-ADR2701 packing list4
    BUILT TO ORDER - PLEASE ALLOW 5-7 WORKING DAYS FOR DELIVERY.
    Quick Start GuideUser ManualGeovision BrochureGeovision Mount Guide Learn More
  4. Hikvision DS-2CD2T43G0-I8 4MP Bullet Network Camera
    The DS-2CD2T43G0-I8 is a 4MP bullet camera with powerful infra-red LEDs that work up to 80m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T43G0-I8 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
    Hikvision Easy IP 3.0 banner for DS-2CD2TX5FWD-
  5. Hikvision DS-2CD2143G0-IS 4MP Dome Network Camera
    The DS-2CD2143G0-IS is a 4MP (2688 x 1520) dome camera from Hikvision's brand new EasyIP 2.0+ range. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2143G0-IS has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. This camera also includes an audio I/O to provide users with the option of connecting an external microphone/speaker. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2143G0-IS can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  6. Hikvision DS-2CD2143G0-I 4MP Dome Network Camera
    The DS-2CD2143G0-I is a 4MP (2688 x 1520) dome camera from Hikvision's brand new EasyIP 2.0+ range, released in June 2018. It is available with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2143G0-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2143G0-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  7. Hikvision DS-2CD2343G0-I 4MP Turret Network Camera
    This turret camera is part of Hikvision's brand new Easy IP 2.0+ range released in June 2018. The Hikvision DS-2CD2343G0-I is a 4MP (2560 x 1440) turret camera available in 2.8mm, 4mm and 6mm fixed focal lengths. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2343G0-I is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2343G0-I also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2343G0-I has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
  8. Vivotek FD8379-HV 4MP Outdoor Fixed Dome Camera
    £328.80 Incl VAT Excl VAT. £274.00
    The Vivotek FD8379-HV is a 4 megapixel outdoor dome camera featuring Vivotek's Smart Stream II technology enabling the camera to optimise image quality for selected areas, ensuring maximum efficiency of bandwidth usage.
    Quick Installation Guide User Manual Learn More
  9. Vivotek FD8179-H 4MP Indoor Fixed Dome Camera
    £273.80 Incl VAT Excl VAT. £228.17
    The Vivotek FD8179-H is a 4 megapixel indoor dome camera featuring WDR Pro, Smart Stream II technology, a removable IR-cut filter and IR illuminators effective up to 30m.
  10. Wisenet QNV-7010R 4MP Vandal-Resistant IR Dome Camera
    Wisenet QNV-7010R/QNV-7020R/QNV-7030R | 4MP Vandal-Resistant IR Dome Camera
    £148.80 Incl VAT Excl VAT. £124.00
    The Wisenet QNV-7010R/QNV-7020R/QNV-7030R are 4MP Vandal-Resistant IR Dome Cameras that come with a choice of fixed lens and IR range so you can find the perfect fit for you. - QNV-7010R = 2.8mm fixed lens - QNV-7020R = 3.6mm fixed lens - QNV-7030R = 6mm fixed lens With the ability to record at 30fps and H.265 codec, a high quality image is guaranteed. These cameras use many smart features such as motion detection and defocus detection to provide security at all hours. Each camera is protected by IK10 rated vandal resistant housing and IP66 rated weatherproof housing so they can be mounted outdoors with no worry. Banner
    Accessory ChartUser ManualH.265 BrochureQ Series Brochure
    Learn More
  11. Wisenet QNO-7010R 4MP Full HD IR Bullet Camera
    Wisenet QNO-7010R/QNO-7020R/QNO-7030R | 4MP Full HD IR Bullet Camera
    This camera is a 4MP camera that comes with a choice of focal lengths and IR LEDS meaning that you can find the perfect fit for any application. - QNO-7010R = 2.8mm lens - QNO-7020R = 3.6mm lens - QNO-7030R = 6mm lens Each camera comes with vandal proof and weatherproof housing so your camera can be safely mounted outside. Banner
    Accessory ChartUser ManualH.265 BrochureQ Series Brochure Learn More
  12. Wisenet QND-7010R 4MP Full HD IR Dome Camera
    Wisenet QND-7010R/QND-7020R/QND-7030R | 4MP Full HD IR Dome Camera
    £136.80 Incl VAT Excl VAT. £114.00
    These cameras use 4MP resolution and IR LEDs to provide a great picture day and night. They come with a choice of focal lengths: 2.8mm, 3.6mm or 6mm so you can find the correct fit for your application. - QND-7010R = 2.8mm lens - QND-7020R = 3.6mm lens - QND-7030R = 6mm lens Each camera uses smart features such as motion detection and defocus detection to ensure that your security needs are fulfilled. Banner
Grid  List
