Indoor IP Cameras
Sidebar
Indoor IP Cameras
Grid  List
  1. AXIS M3104-L Indoor Mini Dome Network Camera with built-in IR illumination 0865-001
    Axis M3104-L Indoor Mini Dome Network Camera with built-in IR illumination 0865-001
    £265.20 Incl VAT Excl VAT. £221.00
    The Axis M3104-L is a 720p resolution mini dome with a flat-faced design that reduces reflections. It uses WDR and IR illumination to achieve HDTV even in the most difficult lighting conditions, its sleek and compact design allows for easy installation in a whole variety positions.
    It also features Axis' Zipstream Technology that reduces bandwidth and storage requirements.
    AXIS M3104-L Installation Guide AXIS M3104-L User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  2. AXIS Q6055 Indoor PTZ Dome Network Camera 0907-002
    Axis Q6055 Indoor PTZ Dome Network Camera 0907-002
    £2,730.00 Incl VAT Excl VAT. £2,275.00
    The Axis Q6055 is an indoor PTZ dome with 1080p resolution, fast & accurate pan/tilt performance and 32x optical zoom. this model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention. it also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilization, two-way audio, I/O ports and 24V AC/DC power.
    Included Accessories: - Axis PoE+ midspan 1-port
    - Recessed mount for hard and drop ceilings
    - Smoked dome cover
    - Installation Guide
    Axis Q6055 Installation GuideAxis Q6055 User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  3. AXIS Q6052 Indoor PTZ Dome Network Camera 0899-002
    Axis Q6052 Indoor PTZ Dome Network Camera 0899-002
    £2,154.68 Incl VAT Excl VAT. £1,795.57
    The Axis Q6052 is an indoor PTZ dome with D1 resolution, fast & accurate pan/tilt performance and 36x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
    It also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilisation, two-way audio, I/O ports and 24V AC/DC power.
    - Smoked dome cover
    Axis Q6052 Installation GuideAxis Q6052 User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  4. AXIS P3707-PE Multisensor Network Camera
    Axis P3707-PE Multisensor Network Camera 0815-001
    £1,210.98 Incl VAT Excl VAT. £1,009.15
    The Axis P3707-PE network camera can capture a combined 8 MP resolution across its 4 independent & varifocal lenses, with this 4-cameras-in-1 design you get the most flexible, cost-effective solution for multi-directional surveillance in large indoor and outdoor areas. Each camera head can be moved along the circular track built into the camera and each can be rotated into Axis' corridor format. Included Accessories: - RJ45 mounting tool - Installation Guide - Windows Decoder 1-user Licence Axis P3707-PE Installation GuideAxis P3707-PE User ManualAxis Assigning IP Address User ManualAxis Product Comparison Table FREE 30-day trial of Axis Camera Station software
    Learn More
  5. AXIS Companion Dome V
    Axis Companion Dome V 0894-001
    £212.40 Incl VAT Excl VAT. £177.00
    The Axis Companion Dome V is an indoor, vandal resistant fixed dome camera that gives high quality video in HDTV 1080p / 2 MP resolution. The plug & go design of the Companion series combined with the domes WDR makes it the perfect starting point for any IP camera novice looking to build a system for their home or small business. It is important to know that Companion products are ONLY compatible with Companion Video Management Software & mobile app.
    Included Accessories: - L-Key Tools - Installation Guide - Windows Decoder 1-user Licence
    Axis Companion Dome V Installation GuideAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  6. AXIS Q3708-PVE Fixed Dome Network Camera
    Axis Q3708-PVE Fixed Dome Network Camera 0801-001
    £2,140.80 Incl VAT Excl VAT. £1,784.00
    The Axis Q3708-PVE is a fixed dome camera with Wide Dynamic Range(WDR) and excellent light sensitivity, Axis call this Forensic Capture as it lets you see much more detail in very low light situations. What really separates this dome from many others on the market is its 3 sensors in 1 design that allows you to see a huge 180 degree panoramic field of view in up to Quad HD resolution.
    Included Accessories: - RJ45 push-pull connector - L-key - Weather shield - Installation guide - Windows decoder 3-user license
    Axis Q3708-PVE User Manual Axis Q3708-PVE Installation Guide Axis Assigning IP Address User Manual Axis Product Guide
    Learn More
  7. AXIS P1254
    Axis P1254 Mini Bullet Camera 0924-001
    £312.40 Incl VAT Excl VAT. £260.33
    The Axis P1254 is a cost-effective and discreet mini bullet style camera. With its rotatable design this camera can be placed in a variety of positions, and with its 102 degree horizontal field of view it is a great camera for smaller indoor spaces.
    Included components:
    - F1004 Bullet Sensor Unit
    - P12 Mk II Main Unit
    - 8m Ethernet cable
    User ManualDimensionsMk II Main Unit Installation GuideF1004 Sensor Unit Installation GuideAxis Assigning IP Address User ManualAxis Product Comparison Table
    Learn More
  8. Axis Q1635-E 2MP Outdoor Network Camera 0674-001
    £1,873.21 Incl VAT Excl VAT. £1,561.01
    Out of Stock
    The Axis Q1635-E is an IP66 and NEMA 4X rated network camera which offers a robust aluminium casing with an included sunshield and wall mount. The camera's arctic temperature control ensures a safe start up in extreme cold.
    - Axis T94Q01A wall mount
    - Sunshield connector kit
    - Resistorx T20 tool
    Axis Q1635-E Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  9. Axis P1365 Mk II Network Camera - 0897-001
    £770.35 Incl VAT Excl VAT. £641.96
    In Stock
    The Axis P1365 Mk II offers outstanding light sensitivity, supporting Lightfinder and WDR - Forensic capture. Optimising video for extreme levels of detail even in low-light and dark environments.
    - Connector kit - Installation guide - Windows decoder 1-user license - Stand
    Axis P1365 Mk II User Manual Axis P1365 Mk II Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  10. Axis P1364 Fixed Network Camera
    Axis P1364 Fixed Network Camera 0689-001
    £681.06 Incl VAT Excl VAT. £567.55
    In Stock
    The Axis P1364 delivers HDTV 720p video at 50fps with reduced noise and motion blur in demanding light conditions. Included Accessories: - Connector kit - Installation guide - Windows decoder 1-user license - Stand
    Axis P1364 Network Camera User Manual Axis P1364 Network Camera Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table
    Learn More
  11. Axis M1125 Network Video Camera 0749-001
    £368.24 Incl VAT Excl VAT. £306.87
    In Stock
    The Axis M1125 is a network video camera delivering HDTV 1080p video in 25 frames per second, reduced bandwidth thanks to Axis' Zipstream technology and WDR - Forensic capture.
    - Axis T91A11 stand white - Installation guide - Windows decoder 1-user license
    Axis M1125 User Manual Axis M1125 Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide
    Learn More
  12. Axis M1124 Network Video Camera 0747-001
    £313.20 Incl VAT Excl VAT. £261.00
    In Stock
    The Axis M1124 is a network video camera delivering HDTV 720p video in 25 frames per second, reduced bandwidth thanks to Axis' Zipstream technology and WDR - Forensic capture.
    Axis M1124 User Manual Axis M1124 Installation Guide Axis Product Comparison Table Axis Product Guide
    Learn More
  13. Axis P3905-RE 2MP Fixed Dome Network Camera
    Axis P3905-RE 2MP Fixed Dome Network Camera 0662-001
    £493.20 Incl VAT Excl VAT. £411.00
    The Axis P3905-RE is part of the Axis P39-R network camera series, which has been specifically designed for video surveillance on buses, trains, tubes and emergency vehicles. This camera has an IP67 rated protection against dust and water and can withstand tough conditions such as; vibrations, shocks, bumps and temperature fluctuations.
    Included Accessories: - Installation and management software CD - Installation guide - Drill hole template - Top cover tool - Lens tool - Allen key resitorx - Windows decoder 1-user license
    Axis P3905-RE User Manual Axis P3905-RE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide FREE 30-day trial of Axis Camera Station software Articles about Axis Network Cameras Learn More
  14. Axis Q2901-E Temperature Alarm Network Camera 19mm 0647-001
    Axis Q2901-E Temperature Alarm Network Camera 9mm 0645-001
    £4,676.40 Incl VAT Excl VAT. £3,897.00
    The Axis Q2901-E can be used where there is a need for temperature monitoring such as power generating facilities, fire hazard areas or industrial processes involving self-igniting materials.
    Included Accessories: - Installation guide - Installation and management software CD - Windows decoder 1-user license - Axis video motion detection 3.0 - Torx T20 screw driver - RJ45 network cable 5m (16ft) - Wall and ceiling mount bracket
    Axis Q2901-E User Manual Axis Q2901-E Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide FREE 30-day trial of Axis Camera Station software Articles about Axis Network Cameras Learn More
  15. Axis Q2901-E Temperature Alarm Network Camera 19mm 0647-001
    £4,478.23 Incl VAT Excl VAT. £3,731.86
    Axis Q2901-E User Manual Axis Q2901-E Installation Guide Axis Product Comparison Table Axis Product Guide FREE 30-day trial of Axis Camera Station software Articles about Axis Network Cameras Learn More
  16. Axis P8535 Eye Level Network Camera
    Axis P8535 Eye Level Network Camera 0714-001 ~ Black Metric
    £717.60 Incl VAT Excl VAT. £598.00
    The Axis P8535 is an eye-level, pinhole camera installed in a pipe or height strip housing for discreet, indoor video surveillance. This camera is ideal for use in retail, hotel and banking environments.
    Included Accessories: - Installation guide - Installation and management software CD - Windows decoder 1-user license - AVHS authentication key
    Axis P8535 Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  17. Axis P8535 Eye Level Network Camera
    Axis P8535 Eye Level Network Camera 0713-001 ~ Silver Metric
  18. Axis P8535 Eye Level Network Camera
    Axis P8535 Eye Level Network Camera 0712-001 ~ Black Imperial
  19. Axis P8535 Eye Level Network Camera
    Axis P8535 Eye Level Network Camera 0711-001 ~ Silver Imperial
  20. Axis Q8414-LVS Corner Mount Stainless Steel Network Camera White 0710-001
    £1,120.90 Incl VAT Excl VAT. £934.08
    Axis Q8414-LVS network camera features vandal resistant stainless steel anti-ligature casing and built-in invisible IR LED for high quality indoor video surveillance even in complete darkness.
    Included Accessories: - Installation guide - Installation and management software CD - Windows decoder 1-user license - AVHS authentication key - Resitorx 20 bit - Connector kit - Washers - Mounting tool for RJ45
    Axis Q8414-LVS User Manual Axis Q8414-LVS Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  21. Axis Q8414-LVS Corner Mount Stainless Steel Network Camera Metal 0709-001
    £1,116.50 Incl VAT Excl VAT. £930.42
  22. Axis F1035-E 2MP Fisheye Sensor Unit 12M 0736-001
    £227.98 Incl VAT Excl VAT. £189.98
    In Stock
    The Axis F series provides, flexible, high-performance 1080p cameras for extremely discreet indoor, outdoor and mobile surveillance applications. They are ideal for use in ATMs, banks, stores, hotels, as well as rugged environments such as emergency vehicles, buses and trains. *This sensor unit is supplied with a 12 metre cable* *Main unit sold separately*
    F1035-E
    Included Accessories: - Installation guide - Axis F8201 vari-angle mounting bracket
    Axis F1035-E 12M Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  23. Axis F1035-E 2MP Fisheye Sensor Unit 3M 0737-001
    £222.54 Incl VAT Excl VAT. £185.45
    In Stock
    The Axis F series provides, flexible, high-performance 1080p cameras for extremely discreet indoor, outdoor and mobile surveillance applications. They are ideal for use in ATMs, banks, stores, hotels, as well as rugged environments such as emergency vehicles, buses and trains. *This sensor unit is supplied with a 3 metre cable* *Main unit sold separately*
    F1035-E
    Axis F1035-E 3M Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  24. Axis F1015 2MP Sensor Unit 12M 0678-001
    £274.57 Incl VAT Excl VAT. £228.81
    In Stock
    The Axis F Series provides users with flexible, high performance cameras that support wide dynamic range and HDTV 1080p for superb image detail in extremely discreet indoor, outdoor and mobile surveillance applications. This camera series is ideal for use in ATMs (automated teller machines), banks, stores, hotels along with rugged environments such as emergency vehicles. *This sensor unit is supplied with a 12 metre cable* *Main unit sold separately*
    F1015
    Axis F1015 12M Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  25. Axis F1015 2MP Sensor Unit 3M 0677-001
    £237.46 Incl VAT Excl VAT. £197.88
    In Stock
    The Axis F Series provides users with flexible, high performance cameras that support wide dynamic range and HDTV 1080p for superb image detail in extremely discreet indoor, outdoor and mobile surveillance applications. This camera series is ideal for use in ATMs (automated teller machines), banks, stores, hotels along with rugged environments such as emergency vehicles. *This sensor unit is supplied with a 3 metre cable* *Main unit sold separately*
    F1015
    Axis F1015 3M Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  26. Axis M1145-L 2 Megapixel Network Camera 0591-001
    £466.25 Incl VAT Excl VAT. £388.54
    In Stock
    The Axis M1145-L has been specifically designed for easy and discreet surveillance providing a small and compact professional fixed camera for day and night surveillance making it ideal for a wide range of professional applications including; boutiques, restaurants, hotels and offices.
    - Stand - Installation guide - Installation and management software CD - Windows decoder 1-user license
    Axis M1145-L User Manual Axis M1145-L Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide
    Learn More
  27. Axis M1145 2 Megapixel Network Camera 0590-001
    £436.80 Incl VAT Excl VAT. £364.00
    Due 29 Jan 2018
    The M1145 network camera has been designed specifically designed for easy and discreet surveillance making them ideal for a wide range of professional applications such as; retail stores, service stations, libraries etc.
    Included Accessories: - Installation guide - Installation and management software CD - Windows decoder 1-user license - Stand
    Axis M1145 User Manual Axis M1145 Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide
    Learn More
  28. Axis M3027-PVE 5MP Fixed Mini Dome Camera 0556-001
    £673.20 Incl VAT Excl VAT. £561.00
    In Stock
    The Axis M3027-PVE is a 5 megapixel fixed mini dome camera which can provide a 360° view when mounted on a ceiling or soffit and a 180° view when wall mounted. This camera has an IP66 and IK10 rated housing to protect the camera from both harsh outdoor weather conditions and vandal attempts.
    Included Accessories: - Installation guide - Installation and management software CD - Windows decoder 1-user license - Drill hole template - Resitorx L-key - Terminal block connector
    Axis M3027-PVE User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  29. Axis P1224-E Miniature HDTV Network Camera 0654-001
    £447.60 Incl VAT Excl VAT. £373.00
    In Stock
    The Axis P1224-E is an exceptionally discreet network camera that is ideal for installation in banks, stores, hotels, architectural buildings offices and at ATMs. This camera is IP66 rated and has protection against dust, rain, snow and ice.
    Installation Accessories: - Mounting kit - Installation guide - Installation and management software CD - Windows decoder 1-user license - AVHS authentication key
    Axis P1224-E User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  30. Axis M3026-VE 3MP Outdoor Ready Fixed Mini Dome Network Camera
    Axis M3026-VE 3MP Outdoor Ready Fixed Mini Dome Network Camera 0547-001
    £583.20 Incl VAT Excl VAT. £486.00
    In Stock
    The Axis M3026-VE is 3 megapixel, wide angle, light sensitive camera that is part of the Axis M30 series of affordably priced, vandal-resistant HDTV fixed mini domes. The M3026-VE is ideal for installation inside or outside the entrance of hotels, boutiques, restaurants, offices and schools.
    Included Accessories: - Drill hole template - Resitorx L-key - Terminal block connector - Installation guide - Installation and management software CD - Windows decoder 1-user license
    Axis M3026-VE User Manual Axis M3026-VE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  31. Axis P1214-E
    Axis P1214-E Miniature HDTV Network Camera 0533-001
    £425.12 Incl VAT Excl VAT. £354.27
    In Stock
    The Axis P1214-E is a small, high performance network camera that is ideal for discreet indoor and outdoor applications.
    - Mounting Kit - Installation Guide - Axis Warranty Document - AVHS Authentication Key - Installation and Management Software CD - Windows Decoder 1-User License
    Axis P1214-E User Manual Axis P1214-E Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide
    Learn More
  32. Axis P1214
    Axis P1214 Miniature HDTV Network Camera 0532-001
    £420.32 Incl VAT Excl VAT. £350.27
    In Stock
    The Axis P1214 is a small, high performance network camera that is ideal for discreet indoor applications.
    Included Accessories: - Mounting Kit - Installation Guide - Axis Warranty Document - AVHS Authentication Key - Installation and Management Software CD - Windows Decoder 1-User License
    Axis P1214 User Manual Axis P1214 Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  33. Axis P3367-V Dome Network Camera
    Axis P3367-V Dome Network Camera 0406-001
    £897.60 Incl VAT Excl VAT. £748.00
    In Stock
    The Axis P3367-V is an indoor vandal-resistant fixed dome network camera with an IK10 impact-resistant aluminium casing. This camera is ideal for unobtrusive video surveillance and can cover a large are with exceptional detail and light sensitivity. This camera also has a unique pixel counter feature which allows the installer to easily verify that the camera installationfulfills any reglatory or specific customer requirements.
    Included Accessories: - Mounting and connector kits - Installation guide - CD with installation tools - Recording software - User manual - Windows decoder 1-user license - Smoked transparent cover
    Axis P3367-V User Manual Axis P3367-V Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
Grid  List
