Indoor IP Cameras
Sidebar
Indoor IP Cameras
Grid  List
  1. Hikvision DS-2CD4625FWD-IZS 2MP Vandalproof IR Bullet Network Camera
    Hikvision DS-2CD4625FWD-IZS 2MP Lightfighter Vandalproof IR Bullet Network Camera
    The Hikvision DS-2CD4625FWD-IZS is a 2MP smart bullet camera with a 2.8mm-12mm lens which provides a 113°-33.8° horizontal viewing angle. This camera is perfect for outdoor applications as it is fitted with both IP66 rated weatherproof housing and IK10 vandal resistant housing. The DS-2CD4625FWD-IZS has built-in infra-red LEDs that are effective up to 50m and is also fitted with a range of features that make this camera effective at handling areas of interest with intense light levels. Image distortion correction, digital wide dynamic range (DWDR), defog and back light/highlight compensation (BLC/HLC) all ensure that the image is enhanced to the best ability. This camera also comes fitted with a range of smart features to improve security even further such as motion detection, line crossing detection and intrusion detection. The DS-2CD4625FWD-IZS also supports 6 behavior analysis and 4 exception detections. This camera can be powered by 24V AC power supply and also by a PoE+ injector. Remote access is made possible through the Hik-Connect app or through a web browser.
    Hikvision Product Catalogue Hikvision Quick Guide 4 Line Guide User Manual
    Learn More
  2. Hikvision DS-2CD4125FWD-IZ 2MP Vandalproof Network Dome Camera
    Hikvision DS-2CD4125FWD-IZ 2MP Lightfighter Vandalproof Indoor Network Dome Camera
    The Hikvision DS-2CD4125FWD-IZ is a dome camera that comes fitted with a 2.8mm-12mm varifocal lens. This camera is great for internal applications where vandalism may be a concern as it is protected by IK10 vandal resistant housing. There are also infra-red LEDs within the camera that are effective up to 30m. The DS-2CD4125FWD-IZ is a Lightfighter camera which is specifically designed to cope with heavily back-lit applications and uses a range of features to improve these images: digital wide dynamic range (DWDR), defog, 3D digital noise reduction technology (3D DNR) and back light/highlight compensation (BLC/HLC).b This camera also uses a range of smart features to further improve security such as motion detection, line crossing detection and intrusion detection. The DS-2CD4125FWD-IZ has a micro SD card slot for on board storage and can be powered with either a 12V DC power supply or by PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    Learn More
  3. Hikvision DS-2CD4126FWD-IZ 2MP Outdoor Darkfighter Dome Network Camera
    Hikvision DS-2CD4126FWD-IZ 2MP Indoor Darkfighter Dome Network Camera
    The Hikvision DS-2CD4126FWD-IZ is a 2MP dome camera with a motorized, vari-focal 2.8mm-12mm lens. This camera is a great choice for internal applications where a vandal resistant camera is necessary as it comes protected by IK10 rated housing. The DS-2CD4126FWD-IZ uses infra-red LEDs that are effective up to 30m along with a range of image enhancing features which make it specifically helpful for ultra-low light applications. This camera uses wide dynamic range (WDR), back light/highlight compensation (BLC/HLC), 3D digital noise reduction (3D DNR), region of interest (ROI), defog and electronic image stabilization (EIS) to achieve this. A smart feature set is used within the camera to further improve security. Features include: motion detection, line crossing detection, intrusion detection and many more. The DS-2CD4126FWD-IZ has a built-in micro SD card slot for on board storage and can be powered by a 12V DC power supply or PoE. Remote access is possible through the Hik-Connect app or through a web browser.
    Learn More
  4. Hikvision DS-2CD4626FWD-IZHS 2MP Darkfighter Vandal-proof IR Array Bullet Network Camera
    Hikvision DS-2CD4626FWD-IZS 2MP Darkfighter Vandal-proof IR Array Bullet Network Camera
    The Hikvision DS-2CD4626FWD-IZS is a 2MP bullet camera from Hikvision with a 2.8mm-12mm lens which provides a 92°~32° viewing angle. This camera is a great choice for external applications as it uses both IP66 rated weatherproof housing and IK10 vandal resistant housing. The DS-2CD4626FWD-IZS has built-in infra-red LEDs that are effective up to 50m and a range of image enhancing features which ensure the camera works in ultra low light environments: 120dB wide dynamic range (WDR), defog, 3D digital noise reduction technology (3D DNR), region of interest (ROI), back light compensation (BLC) and electronic image stabilization (EIS). This camera also uses a range of smart features to improve security even further such as motion detection, line crossing detection, region entrance/exit and object removal detection. There is also the option to connect a microphone/speaker to the audio I/O if audio is a function you require. The DS-2CD4626FWD-IZS features a micro SD card slot and can be powered by either a 24V AC power supply or by a PoE+ injector. Remote access is possible by using the Hik-Connect app or by using a web browser.
    Learn More
  5. Hikvision DS-2DF8223I-AEL 2MP Smart PTZ Outdoor Network Camera
    Hikvision DS-2DF8223I-AEL 2MP 23x Smart PTZ Camera
    The Hikvision DS-2DF8223I-AEL is a 2MP PTZ IP camera with 23x optical zoom (5.9mm - 135.7mm) and a host of smart detection and and tracking features. It is part of Hikvision's Darkfighter series, which provides full colour images up to 0.005 lux, and black and white images up to 0.0005 lux with no additional illumination. It also comes with in-built IR LEDs to provide up to 200m illumination in 0 lux environments. The DS-2DF8223I-AEL provides full 360° pan function with -15° - 90° tilt range, giving a very wide range of view. It also comes with support for face, intrusion, line-crossing, audio exception, and motion detection, as well as 8 programmable patrols with up to 300 presets. The camera supports an internal micro SD/SDHC/SDXC card for use with Hikvision's Edge recording, allowing the camera to continue recording to this card even if the network drops for any reason. This ensures you never lose any data and your property remains secure. This camera can be powered by 60W PoE or a 24VAC power supply and can be accessed remotely through a web browser or through the Hik-Connect app.
    Hikvision Product CatalogueHikvision Quick GuideHikvision Dark Fighter CatalogueUser Manual Learn More
Grid  List
