PTZ IP Cameras
PTZ IP Cameras have pan, tilt and zoom functionality that allows you to remotely control exactly what the camera views.
£4,677.35 Incl VAT Excl VAT. £3,897.79
The Axis Q6055-S is a pressurised, marine grade stainless steel PTZ camera giving the camera a high resistance to corrosion, cleaning chemicals and high pressure steam.
£4,150.63 Incl VAT Excl VAT. £3,458.86
The Axis Q6055-C has been designed specifically to provide high quality surveillance in areas with high ambient temperatures and solar radiation. This camera is able to operate in temperatures as high as 75°C thanks to its built-in active cooling system, as well as this the Q6055-C has built-in analytics including; autotracking, active gatekeeper, fence detector, object removed and enter/exit detection.
- Axis T8607 media converter switch - 7m IP66 rated multicable - Installation guide - Windows decoder 1-user license
£2,730.00 Incl VAT Excl VAT. £2,275.00
The Axis Q6055 is an indoor PTZ dome with 1080p resolution, fast & accurate pan/tilt performance and 32x optical zoom. this model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention. it also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilization, two-way audio, I/O ports and 24V AC/DC power.
£3,319.20 Incl VAT Excl VAT. £2,766.00
The Axis Q6055-E is an outdoor PTZ dome with 1080p resolution, fast & accurate pan/tilt performance and 32x optical zoom. This model also features a focus recall setting which allows the camera to instantly focus on predetermined areas without any manual intervention.
It also comes with Axis' Lightfinder (improves low light performance) & Zipstream (condenses video files, reducing storage requirements) technology, as well as Active Gatekeeper, electronic image stabilization, two-way audio, I/O ports and 24V AC/DC power. As an outdoor model it also features an IP66 weatherproof rating and an IK10 vandal-proof rating.
