IP Cameras
IP cameras, also known as Network Cameras, connect directly to your Home or Office IP Network and can easily be viewed or recorded anywhere else on the network or even across the internet.
£220.31 Incl VAT Excl VAT. £183.59
£150.00 Incl VAT Excl VAT. £125.00
£138.00 Incl VAT Excl VAT. £115.00
£2,673.36 Incl VAT Excl VAT. £2,227.80
£744.00 Incl VAT Excl VAT. £620.00
£208.08 Incl VAT Excl VAT. £173.40
£1,632.79 Incl VAT Excl VAT. £1,360.66
£276.00 Incl VAT Excl VAT. £230.00
£558.00 Incl VAT Excl VAT. £465.00
"This product may not be immediately available from UK stock, in which case it will take 7 days to fetch it from their European warehouse"
£616.80 Incl VAT Excl VAT. £514.00
£333.95 Incl VAT Excl VAT. £278.29
£373.33 Incl VAT Excl VAT. £311.11
£626.82 Incl VAT Excl VAT. £522.35
£396.24 Incl VAT Excl VAT. £330.20
£533.00 Incl VAT Excl VAT. £444.17
£580.98 Incl VAT Excl VAT. £484.15
£555.60 Incl VAT Excl VAT. £463.00
The Wisenet XND-6080 is an indoor 2MP vari-focal network dome camera that is part of the Wisenet X series of cameras with improved features such as; loitering detection, WiseStrem II support, lens distortion correction and motion detection.
The XND-6080R also has built-in infra-red LED's capable of capturing images up to 30m in the dark.
£521.57 Incl VAT Excl VAT. £434.64
£312.48 Incl VAT Excl VAT. £260.40
£291.60 Incl VAT Excl VAT. £243.00
£413.45 Incl VAT Excl VAT. £344.54
The Hikvision DS-2DE4220IW-DE is a 2MP PTZ camera which is able to capture high quality images in low light environment with its black anti-reflective glass. With a 4.7mm - 94mm focal length the DS-2DE4220IW-DE offers 20x optical zoom. This camera also offers 100m IR range and audio I/O's allowing the user to connect external microphones or speakers. The DS-2DE4220IW-DE uses a range of features to enhance images such as Dynamic Wide Dynamic Range (DWDR), 3D Digital Noise Reduction (3D DNR) and Highlight/Back Light Compensation (HLC/BLC). This PTZ supports 300 presets, 4 pattern scans and 8 patrols. It also includes smart features such as intrusion detection, line crossing detection and motion detection. The DS-2DE4220IW-DE can be powered by 12VDC power supply or 15W PoE and has a built in micro SD card slot. This PTZ can be accessed and controlled remotely through a browser or the Hik-Connect app.
£364.80 Incl VAT Excl VAT. £304.00
Quick Start GuideGeovision BrochureGeovision Mount Guide
Learn More£492.00 Incl VAT Excl VAT. £410.00
£444.00 Incl VAT Excl VAT. £370.00
£4,150.63 Incl VAT Excl VAT. £3,458.86
The Axis Q6055-C has been designed specifically to provide high quality surveillance in areas with high ambient temperatures and solar radiation. This camera is able to operate in temperatures as high as 75°C thanks to its built-in active cooling system, as well as this the Q6055-C has built-in analytics including; autotracking, active gatekeeper, fence detector, object removed and enter/exit detection.
- Axis T8607 media converter switch - 7m IP66 rated multicable - Installation guide - Windows decoder 1-user license
£1,444.80 Incl VAT Excl VAT. £1,204.00
£264.00 Incl VAT Excl VAT. £220.00
£372.00 Incl VAT Excl VAT. £310.00
£228.00 Incl VAT Excl VAT. £190.00
£414.00 Incl VAT Excl VAT. £345.00
£408.00 Incl VAT Excl VAT. £340.00
£192.00 Incl VAT Excl VAT. £160.00
£376.80 Incl VAT Excl VAT. £314.00
The Geovision GV-EVD2100 is a 2MP dome camera with a vari-focal 3mm~9mm lens and intelligent IR LEDs effective up to 50m. Fitted with IP67 rated weatherproof housing and IK10 vandal resistant housing, this camera is a sturdy choice for outdoor applications. The GV-EVD2100 has a 3-axis mechanism for precise set up ensuring any area of interest can be easily covered. This camera also supports two way audio for the connection of an external microphone and speaker. With a range of image enhancers such as wide dynamic range, back light compensation, 3D noise reduction and image configuration such as contrast, brightness and saturation, the GV-EVD2100 can provide excellent video quality day or night. Security is further improved with the use of motion detection, tampering alarm and privacy mask. This camera supports on board storage and H.264 compression. It can be powered by a 12VDC power supply or by PoE and remote access is possible through internet explorer or the GV-Eye app.
Vandal Resistant Dome Quick Start GuideGeovision Brochure
Geovision Mount Guide Learn More£338.40 Incl VAT Excl VAT. £282.00
£2,714.40 Incl VAT Excl VAT. £2,262.00
The B934 is a 2 megapixel speed dome camera that offers 1080p HD resolution, it features a 30x zoom lens with extreme WDR that helps it perform incredibly well in very low light situations, day or night. It also includes auto focus, endless pan & tilt, PTZ auto tracking, vandal resistant casing (IK09) and it is also fully compatible with ACTi software.
£1,443.60 Incl VAT Excl VAT. £1,203.00
In Stock
The Axis Q3505-SVE Mk II is an outdoor ready vandal resistant fixed dome with 1080p resolution at up to 60fps with WDR on (can record up to 120fps if set to 720p and with WDR off). This model is varifocal and comes in 2 different focal lengths (3~9mm / 9~22mm) this makes the camera very flexible to different set-up environments.
As already mentioned this camera feature WDR, but it also feature Lightfinder technology which combined with the WDR makes it excellent in low light situations, its smart conduit design makes very easy to install and the inclusion of remote zoom and focus eliminates the need for hands-on fine tuning.
This model features a stainless steel marine-grade casing and is rated IK10+ which means the camera can handle impact forces as high as 50 joules, it is also rate IP69 for weatherproofing, it is the ideal camera for identifying people and other movement in harsh environments like work sites, large factories and detention centre.
- Installation Guide
- Mounting bracket
- Drill hole template
- Cable gaskets
- I/O connector
- Connector guard
- Axis U-shape conduit adapter
- Stainless steel Resistorx® TR20 screw bit
- AXIS T94U02S Mounting Bracket
- Wall gasket
£235.48 Incl VAT Excl VAT. £196.23
In Stock
£308.44 Incl VAT Excl VAT. £257.03
In Stock
£351.60 Incl VAT Excl VAT. £293.00
Hikvision Product CatalogueHikvision Quick GuideUser Manual Learn More
The Hikvision DS-2DE5220IW-AE is a 2MP PTZ Dome Camera is able to capture high quality images in low light environment with its black anti-reflective glass. With a 4.7mm - 94mm focal lens this camera offers a 58.3° to 3.2° viewing angle and 20x optical zoom. The DS-2DE5220IW-AE has infra-red LEDs that are effective up to 150m along with Audio/Alarm I/Os. This camera uses a range of features to improve images day and night such as digital wide dynamic range (DWDR), 3D digital noise reduction (3D DNR) and Highlight/Backlight comepnsation (HLC/BLC). This PTZ camera supports 300 presets, 8 patrols and a variety of scheduled tasks. It also supports a range of smart features such as intrusion detection, line crossing detection and motion detection. The DS-DE5220IW-AE has a built-in micro SD card slot and can be powered by a 24VAC power supply or by PoE plus (30W). Remote access is possible through a browser or through the Hik-Connect app.
£282.48 Incl VAT Excl VAT. £235.40
The Axis M1065-L is a 1080p cube camera with built-in microphone for recording audio, a mini speaker for playing pre-recorded messages and a PIR motion sensor for detecting movement even in dark conditions. The camera can perform well day or night because of its IR cut filter and built-in IR illumination that allow it to see up to 10m in complete darkness, with its 110° horizontal field of view you can cover a large space with minimal devices and it can also be discreetly installed with the included bracket. other features include PoE, WDR and support for micro SD & Edge storage.
In Stock
£237.60 Incl VAT Excl VAT. £198.00
£248.04 Incl VAT Excl VAT. £206.70
£141.60 Incl VAT Excl VAT. £118.00
