IP Cameras
IP Cameras from use-IP
Sidebar
IP Cameras
IP cameras, also known as Network Cameras, connect directly to your Home or Office IP Network and can easily be viewed or recorded anywhere else on the network or even across the internet.
Grid  List
  1. Hikvision DS-2CD2455FWD-IW | 2.8mm 5MP Cube Network Camera
    The Hikvision DS-2CD2455FWD-IW is a 5MP (2944 x 1656) internal cube camera with a 2.8mm fixed lens. This camera comes with EXIR IR LEDs that are effective up to 10m. With a built in bracket that can be adjusted easily for ceiling and wall mounting - or just used as a stand - the DS-2CD2455FWD-IW is ideal for inside houses and offices. This cube camera comes with built-in wifi and two way audio meaning that it is easy to speak and listen through the camera without any external accessories needed. The DS-2CD2455FWD-IW uses wide dynamic range (WDR), back light compensation (BLC) and 3D digital noise reduction (3D DNR) technology to enhance images as much as possible. These features along with other smart features such as motion detection, line crossing detection and intrusion detection ensure that this camera provides the highest quality security inside the home. This cube camera features an SD card slot for on board storage which can be fully utilised with the use of H.265+ video compression. It can be powered with either a 12VDC power supply or by PoE and can be accessed remotely via a web browser or via the Hik-Connect app.
    cube banner
    Hikvision Product CatalogueHikvision Quick GuideUser ManualCube Quick Start Manual Learn More
  2. Axis P3367-VE Dome Network Camera
    Axis P3367-VE Dome Network Camera 0407-001
    £1,077.60 Incl VAT Excl VAT. £898.00
    In Stock
    The Axis P3367-VE is an outdoor-ready vandal resistant fixed dome network camera. The camera is ideal for unobtrusive video surveillance in exposed areas such as airports, subways, retail stores, schools and university campuses. This 5 megapixel model can cover a large area with exceptional detail and light sensitivity, can operate in extreme temperatures from -40°C to 55°C and has an IP66- and NEMA 4X-rated, IK10 impact-resistant aluminium casing with integrated dehumidifying membrane.
    Included Accessories: - Mounting and connector kits - Installation guide - CD with installation tools - Recording software - User manual - Windows decoder 1-user license - Smoked transparent cover - Mounting bracket - Weather shield - 5m network cable with premounted gasket
    Axis P3367-VE User Manual Axis P3367-VE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
  3. Axis P3367-V Dome Network Camera
    Axis P3367-V Dome Network Camera 0406-001
    £897.60 Incl VAT Excl VAT. £748.00
    In Stock
    The Axis P3367-V is an indoor vandal-resistant fixed dome network camera with an IK10 impact-resistant aluminium casing. This camera is ideal for unobtrusive video surveillance and can cover a large are with exceptional detail and light sensitivity. This camera also has a unique pixel counter feature which allows the installer to easily verify that the camera installationfulfills any reglatory or specific customer requirements.
    Axis P3367-V User Manual Axis P3367-V Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table Axis Product Guide Learn More
Grid  List
