IP Cameras
IP Cameras from use-IP
Sidebar
IP Cameras
IP cameras, also known as Network Cameras, connect directly to your Home or Office IP Network and can easily be viewed or recorded anywhere else on the network or even across the internet.
Grid  List
  1. Wisenet XNO-6020R/INT 2MP Intrusion Pro Bullet Camera
    Wisenet XNO-6020R/INT 2MP AI-Intrusion Pro Bullet Camera
    £691.73 Incl VAT Excl VAT. £576.44
    Due 30 Jul 2018
    The Wisenet XNO-6020R/INT is an out-of-box solution that allows users to intelligent video analytics from A.I. Tech to reliably detect any activity occurring in prohibited zones. Wisenet and A.I. Tech have worked together to product this advanced application, which is suitable for use both indoors and outdoors in environments that require an intelligent security solution. The XNO-6020R/INT is a 2 megapixel network IR bullet camera that is part of the the Wisenet X series of cameras with improved features such as; people counting, queue management, loitering and directional detection. The camera also benefits from built-in infra-red LED's that enable it to see up to 30m in the dark. Alarm events picked up by the smart A.I. Tech technology built in to the XNO-6020R/INT can be sent to Wisenet NVR's and is supported by Wisenet WAVE and Wisenet SSM VMS. It is also supported by third party VMS, including Milestone Xprotect. XRN-1610S banner
    This product may not be immediately available from UK stock, in which case there will be a 7 day lead time to fetch from their European warehouse. Intrusion Detection Solution Brochure A.I. Tech Brochure
    Learn More
  2. Axis Q1647-LE 5MP Network Camera with i-CS Lens 01052-001
    £1,820.40 Incl VAT Excl VAT. £1,517.00
    The Axis Q1647-LE is an outdoor network camera engineered for light sensitivity that's second to none. This camera is sharp in more ways than one; delivering high-resolution video at full frame rate for crystal clear image and OptimisedIR ensures high-quality, low noise video even in complete darkness.
    The robust aluminium casing means the Q1647-LE is able to handle temperatures as low as -40°C and as high as 60°C, not only this but the housing is IP66, IP67, NEMA 4X and IK10 rated so users can be sure the camera is resistant to both harsh weather conditions and impact.
    This camera is packed full of intelligent features that facilitate smart decision making, enhanced security, first class image usability and fast, easy installation. Pre-installed with Axis Motion Guard, Axis Fence Guard and Axis Loitering Guard analytics for proactive surveillance and saved resources.
    Included Accessories: - Axis T94Q01A Wall Mount - Axis T92G20 Outdoor Housing - Connector kit - Resitorx T20 tool - Installation guide - Windows decoder 1-user license
    Please contact us for stock levels, this camera may have a 10-14 day lead time for delivery.
    Axis Q1647-LE User Manual
    Axis Q1647-LE Installation Guide
    Axis Assigning IP Address User Manual Axis Product Comparison Table Autumn 2016 Axis Product Guide
    Learn More
  3. Hikvision DS-2CD2H35FWD-IZ 3MP Vari-focal Turret Network Camera
    *SPECIAL OFFER* Hikvision DS-2CD2H35FWD-IZS 3MP Motorised Zoom Turret Network Camera *OPEN BOX*
    OPEN BOX ~ Only 1 Available!
    The Hikvision DS-2CD2H35FWD-IZS is a 3MP (2048 x 1536) turret camera that uses a motorised zoom lens with a 2.8mm to 12mm focal length. It also has inbuilt infra-red LEDs that have a maximum distance of 30m along with IK10 vandal resistant housing and IP67 weatherproof housing making it a great choice for outdoor applications, day or night. With the DS-2CD2H35FWD-IZS's 3-axis adjust-ability, choice of mounting options and zoom lens, any area of interest can be easily covered making this camera really versatile and a popular choice for many of our customers. This turret camera utilises a range of Hikvision's features to enhance images and security, for example, back light compensation (BLC), 3D digital noise reduction (3D DNR) and region of interest (ROI). Along with this, the DS-2CD2H35FWD-IZS also uses a range of smart features such as line crossing detection, intrusion detection and object removal detection. As with all cameras in the EasyIP 3.0 family, H.265+ video compression offers up to a 70% saving on storage and bandwidth over H.264 with minimal effects to image quality. This saving means that the DS-2CD2H35FWD-IZS's SD card slot can be utilised without reaching maximum capacity too quickly. This turret can be powered by PoE or a 12VDC power supply and has the ability to be accessed remotely via web browser or by using the Hik-Connect app.
    Hikvision DS-2CD2H35FWD-IZ banner
  4. Axis Q1645-LE 2MP Network Camera 01223-001
    Axis Q1645-LE 2MP Network Camera with i-CS Lens 01223-001
    £1,605.60 Incl VAT Excl VAT. £1,338.00
    The Axis Q1645-LE is an outdoor network camera engineered for light sensitivity that's second to none. This camera is sharp in more ways than one; delivering high-resolution video at full frame rate for crystal clear image and OptimisedIR ensures high-quality, low noise video even in complete darkness.
    The robust aluminium casing means the Q1645-LE is able to handle temperatures as low as -40°C and as high as 60°C, not only this but the housing is IP66, IP67, NEMA 4X and IK10 rated so users can be sure the camera is resistant to both harsh weather conditions and impact.
    Axis Q1645-LE User Manual
    Axis Q1645-LE Installation Guide
    Learn More
  5. Vivotek MS9390-HV Multi-Sensor 8MP Dome Camera
    £744.00 Incl VAT Excl VAT. £620.00
    The Vivotek MS9390-HV is an 8MP panoramic dome camera that uses two wide angle lenses and electronic image stitching to create a 180° image. The MS9390-HV captures a higher vertical field of view than most multi-sensor panoramic cameras, allowing the user to capture a larger area. This camera can capture up to 30fps and its built-in infra-red illuminators allow it to continue capturing 180° footage up to 20m in the dark, making it a 24/7 solution. The MS9390-HV also benefits from an IP66 weatherproof-rated and IK10 vandal resistant-rated housing meaning it can be used both indoors and outdoors. The MS9390-HV comes with a sunshield included and doesn't need any other accessories as it can be mounted directly on to a wall thanks to its 20° of internal tilt adjustment which allows users to get the exact angle that they desire.
    This item is a special order product and may not be available for immediate delivery. Please check with us before purchasing as it could take 10-14 days to fetch from Vivotek.
    User Manual Quick Installation Guide Learn More
  6. Vivotek FD8169A 2MP IR Dome Camera
    £152.40 Incl VAT Excl VAT. £127.00
    The Vivotek FD8169A is an affordable 2MP indoor dome camera with built-in infra-red LED's meaning it can see up to 20m in the dark. The removable IR-cut filter also allows the FD8169A to adapt to changing lighting conditions so the user can capture high quality images in all lighting situations. This camera also benefits from a built-in MicroSD/SDHC/SDXC card slot for on-board storage. The built-in 2.8mm lens can capture a 114° horizontal field of view and as the camera is only 129mm wide, it is perfect for compact applications that require a discreet solution.
    This item may not be available for immediate delivery. Please check with us before purchasing as it could take 10-14 days to fetch from Vivotek.
    User Manual Quick Installation Guide Accessories Chart Learn More
  7. Vivotek FE9382-EHV 5MP Outdoor Fisheye Camera
    £799.73 Incl VAT Excl VAT. £666.44
    The FE9382-EHV is a unique 5MP fisheye camera from Vivotek, with built-in infra-red illuminators allowing it to see up to 20m in the dark. The fisheye lens allows it to cover 180° panoramic view when wall mounted or 360° surround view when ceiling/floor mounted, with zero blind spots. The Vivotek FE9382-EHV has a vandal-proof IK10-rated and weather-proof IP66-rated housing making it suitable for use both indoors or outdoors in a wide range of applications such as airports, shopping centres and retail shops.
  8. Vivotek FD8167A 2MP Vari-Focal Indoor Dome Camera
    £205.85 Incl VAT Excl VAT. £171.54
    The Viviotek FD8167A is a 2MP indoor vari-focal dome camera that is designed to be companct but still capable of capturing up to 30fps and thanks to its built-in infra-red LED's it can see up to 20m in the dark. If needed, the FD8167A has on-board storage meaning it can record strait to a MicroSD/SDHC/SDXC card. Powered by PoE, this camera utilises Vivotek's Smart Stream II technology to reduce the bandwidth usage whilst still delivering high quality images. User Manual Quick Installation Guide Learn More
  9. Vivotek FD8382-ETV 5MP Vari-Focal Extreme Weather Dome Camera
    £444.68 Incl VAT Excl VAT. £370.57
    The Vivotek FD8382-ETV is a 5MP vari-focal dome camera with built-in infra-red LED's and two-way audio. The housing is IP66-rated and IK-10 rated meaning the camera can be used both indoors and outdoors in extreme weather conditions. This camera comes ready for changing environments, with wide dynamic range for improved visibility in bright and dark situations. The FD8382-ETV also benefits from video rotation through its corridor view.
  10. Vivotek IB8382-ET 5MP Vari-focal Extreme Weather Bullet Camera
    The IB8382-ET is a 5MP vari-focal bullet camera from Vivotek that is suitable for use both indoors and outdoors thanks to its IP66, IK10 rated housing. This camera can also be subject to extreme weather conditions of -50°C ~ 50°C thanks to a built-in heater. The Vivotek IB8382-ET also benefits from built-in infra-red illuminators that allow you to capture images in the dark up to 30m away. Wide dynamic range and 3D noice reduction mean the IB8382-ET is capable of capturing high quality images in extremely bright or dark conditions.
  11. Vivotek FD9371-EHTV 3MP Vari-Focal  Dome Camera
    £510.00 Incl VAT Excl VAT. £425.00
    The Vivotek FD9371-EHTV is a 3MP vari-focal dome camera that is both IP66 and IK10-rated meaning it can be used either indoors or outdoors plus, this model is suitable for use in extreme weather conditions of -50°C ~ 50°C and humidity levels of 90%. The FD9371-EHTV benefits from a range of alarm and event triggers including motion detection, tampering detection and audio detection. By using H.265 compression you can capture quality images but use less storage space.
    User Manual Quick Installation Guide Accessory Guide Learn More
  12. Wisenet XNV-6022RM Vandal-Resistant Vibration-Resistant Flat Dome Camera
    £422.62 Incl VAT Excl VAT. £352.18
    The XNV-6022RM is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. This camera has the added benefit of built-in infra-red LED's allowing it to capture images in the dark up to 15m. It also includes a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. The XNV-6022RM is vibration resistant and has a M12 connector, making it suitable for use in situations where vibrations may occur such as in transport environments. This camera is fitted with a 3.6mm lens which can capture a wide angle to cover 94.8° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
  13. Wisenet XNV-6022R Vandal-Resistant IR Flat Dome Camera
    £422.40 Incl VAT Excl VAT. £352.00
    The XNV-6022R is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. The XNV-6022R has the added benefit of built-in infra-red LED's allowing it to capture images in the dark up to 15m. It also includes a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. This camera is fitted with a 3.6mm lens which can capture a wide angle to cover 94.8° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
  14. Wisenet XNV-6013M 2MP Vandal-Resistant Vibration-Resistant Dome Camera
    £384.00 Incl VAT Excl VAT. £320.00
    The XNV-6013M is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. This camera benefits from a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. The XNV-6013M is vibration resistant and has a M12 connector, making it suitable for use in situations where vibrations may occur such as in transport environments. The XNV-6013M is fitted with a 2.8mm lens which can capture a wide angle to cover 107.4° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
  15. Wisenet XNV-6012M 2MP Vandal-Resistant Vibration-Resistant Flat Dome Camera
    £402.60 Incl VAT Excl VAT. £335.50
    The XNV-6012M is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. The key difference between the XNV-6012M and the XNV-6012 is that the XNV-6012M is vibration resistant and has a M12 connector, making it suitable for use in situations where vibrations may occur such as in transport environments. This camera benefits from a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. The XNV-6012M is fitted with a 2.4mm lens which can capture a wide angle to cover 135.4° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
  16. Wisenet XNV-6012 2MP Vandal-Resistant Flat Dome Camera
    £378.60 Incl VAT Excl VAT. £315.50
    The XNV-6012 is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. This camera benefits from a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. The XNV-6012 is fitted with a 2.4mm lens which can capture a wide angle to cover 135° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
  17. Axis P1290 Thermal Network Camera 01168-001
    £909.60 Incl VAT Excl VAT. £758.00
    The Axis P1290 is a cost effective indoor thermal camera with a 208 x 156 resolution and a 35° field of view. Thermal technology ensures a reliable detection with low rate of false alarms. The camera is protected in a fixed dome enclosure and can be used for surveillance in both retail and residential applications. The P1290 can be used as a sensor to avoid compromising privacy; for example schools and care homes thermal imaging detects incidents without revealing personal details of the people in the image. Used with Axis analytics the thermal camera can trigger alerts or alarms in response to patient or resident falls, which allows staff to take immediate action. Included Accessories: - Installation guide - Windows decoder 1-user license - AVHS Authentication key - Rotation tool
    Axis P1290 User Manual Axis Assigning IP Address User Manual Axis Product Comparison Table Autumn 2016 Axis Product Guide
    Learn More
  18. Milesight UI-5D62-EPCV 5MP 12x Pro Remote Focus and Zoom Bullet Camera
    £348.00 Incl VAT Excl VAT. £290.00
    The Milesight UI-5D62-EPCV is a bullet style IP network camera featuring a 12x AF lens which can zoom into distant subjects whilst maintaining clarity to provide high quality video. 3rd generation dot matrix IR LEDs allow the camera to provide superior night visibility guaranteeing excellent image quality even at night. The six LEDs at the top of the camera work as high beam and the two LEDs at the bottom as low beam, enabling better image clarity and quality regardless of objects distance. The brightness of high and low beam can be adjusted manually or automatically on the basis of the zoom ratio. Video Content Analysis has 8 detection modes providing advanced, accurate smart video analysis for Milesight network cameras. Detection modes include: Region entrance and region exiting ~ the two functions are used to alert when people/object enter/exit a specific area. Advanced motion detection ~ with more intelligent features than traditional motion detection, advanced motion detection can filter out 'noise' such as lighting changes, tree movement etc. Parameters can be set to detect various movements depending on requirements. Tamper detection ~ triggers an alarm when there is an attempt to move the camera or a suspicious object/person is obstructing the camera view. Line crossing ~ when enable, an event will be triggered every time an object crosses the virtual line. Loitering ~ an alarm is triggered when an object stays in a specified area for a certain length of time. Human detection ~ this can be used to determine if an object is human or not. People counting ~ counts how many people enter/exit an area.
    Included accessories: - Quick start guide - Junction Box - Mounting template - Screws - Rawl plugs - Screwdrivers
    Milesight User ManualMilesight Product BrochureMilesight Product Catalogue Learn More
  19. Wisenet XNO-6120R/FNP 2MP ANPR Varifocal Bullet Camera
    £1,296.35 Incl VAT Excl VAT. £1,080.29
    The Wisenet XNO-6120R/FNP is a 2MP varifocal bullet camera that is ANPR ready and is capable of capturing number plates in many situations including multi-lane roads and at entrance ways. Wisenet have worked with analytics experts FF Group to create this advanced solution that is able to accurately pick up all European number plates and record events including entry/exit logs, black/white list management and direction detection. The XNO-6120R/FNP can read the plates of vehicles travelling at speeds of up to 80kmph on two lanes or at night-time and up to 150 kmph on a single lane during daylight hours. The camera also benefits from all the standard smart analytics functions from Wisenet's X series of cameras
    XRN-1610S banner
    User ManualInstallation GuideXNO-6120R (non ANPR) DatasheetWisenet Group ANPR Brochure Learn More
  20. Hikvision DS-2DF6A236X-AEL 2MP 36X PTZ Camera
    The Hikvision DS-2DF6A236X-AEL is a 2MP PTZ camera with a 5.7mm - 205.2mm lens that can provide up to 36x optical zoom and 16x digital zoom. This camera is perfect for external applications with IK10 rated vandal proof housing and IP67 rated weatherproof housing. The DS-2DF6A236X-AEL is equipped with a variety of image enhancing features which make it perfect for low light environments: 120dB wide dynamic range (120dB), 3D digital noise reduction (3D DNR), highlight/back light compensation (HLC/BLC), defog, electronic image stabilization (EIS). With the help of these features the DS-2DF6A236X-AEL is effective in colour at 0.002 lux and black and white at 0.0002 lux. This camera also uses a range of smart features in improve security such as intrusion detection, line crossing detection, face detection and many more. It also uses the latest technology in auto tracking and can track specific target types such as humans or vehicles. The DS-2DF6A236X-AEL supports 300 presets, 8 patrols and 4 pattern scans. IT also supports H.265+ video compression which offers a huge saving on bandwidth and storage usage meaning that the on-board SD card slot can be used more effectively. This PTZ can be powered by a 24V AC power supply or by 50W PoE injector and can be accessed remotely through a browser or through the Hik-Connect app.
    Hikvision Product Catalogue Hikvision Quick Guide Learn More
  21. Hikvision DS-2DE7232IW-AE 2MP 32x PTZ Camera
    The DS-2DE7232IW-AE is a 2MP PTZ camera from Hikvision with a 4.8mm-153mm lens providing 32x optical zoom. This camera is a great choice for external applications with an audio/alarm I/O, IP66 rated weatherproof housing and infra-red LEDs that are effective up to 150m. The DS-2DE7232IW-AE also performs really well in low light environments by using a range of image enhancing features such as wide dynamic range (WDR), highlight/back light compensation (HLC/BLC), 3D digital noise reduction (3D DNR), defog, electronic image stabilization (EIS) and regional exposure/focus. Along with image enhancing, the DS-2DE7232IW-AE also features improved security by using smart features such as motion detection, intrusion detection, line crossing detection object removal detection and more. This camera also supports a range of PTZ functions such as 300 presets, 8 patrols and 4 pattern scans. The DS-2DE7232IW-AE uses H.265+ video compression which dramatically reduces bandwidth and storage usage. This camera supports on board storage and can be powered by either a 24V AC power supply or by a 40W hi-poe injector. Remote access is possible through a browser or via the Hik-Connect app.
    Hikvision E Series Network Speed Dome User ManualHikvision Product CatalogueHikvision Quick Guide Learn More
  22. Hikvision DS-2DE5225IW-AE 2MP 25x PTZ Camera
    The DS-2DE5225IW-AE is a 2MP PTZ camera from Hikvision with a 4.8mm - 120mm lens offering 25x optical zoom. With IP66 rated weatherproof housing and infra-red LEDs effective up to 150m, this PTZ is a great choice for outdoor applications where clear nighttime images over long distances are important. The DS-2DE5225IW-AE is also fitted with a range of image enhancing features that help the camera to provide impressive quality in low light environments: wide dynamic range (WDR), highlight/back light compensation (HLC/BLC), 3D digital noise reduction (3D DNR), defog, electronic image stabilization (EIS) and regional exposure/focus. Along with image enhancing features, this camera also supports a range of smart features to improve security further such as motion detection, intrusion detection, line crossing detection and many more. The DS-2DE5225IW-AE also supports 300 presets, 8 patrols and 4 pattern scans. This PTZ also supports H.265+ compression which means that the on board SD card slot can be utilised without concern of reaching maximum capacity so quickly. It can be powered by both 24V AC power supply and a 30W PoE injector. The DS-2DE5225IW-AE can be accessed remotely though the Hik-Connect app or through a browser.
  23. Hikvision DS-2DE4225IW-DE 2MP 25x PTZ Camera
    The Hikvision DS-2DE4225IW-DE is a 2MP PTZ camera with a 4.8mm - 120mm lens that allows optical zooming up to 25x. This camera has infra-red LEDs that are effective up to 100m and also works in ultra low light environments by using a range of image enhancing features: wide dynamic range (WDR), highlight/back light compensation (HLC/BLC), 3D digital noise reduction technology (3D DNR) and electronic image stabilization (EIS). The DS-2DE4225IW-DE is suitable for external applications with IP66 rated weatherproof housing and the option to connect external microphones or speakers. It is also fitted with a range of smart features to further improve security such as motion detection, intrusion detection, line crossing detection and object removal detection. This PTZ supports up to 300 presets, 8 patrols and 4 pattern scans. It also utilises H.265+ compression which offers a huge saving on bandwidth and storage usage. Impressive compression means that the on board SD card slot can be utilised without the worry of reaching maximum capacity too quickly. The DS-2DE4225IW-DE can be powered with either a 12VDC power supply or PoE+ injector can can be accessed remotely though the Hik-Connect app or through a web browser.
  24. Hikvision DS-2DE4A225IW-DE 2MP IR Mini PTZ Camera
    Hikvision DS-2DE4A225IW-DE 2MP 25x Mini PTZ Camera
    The DS-2DE4A225IW-DE is a mini PTZ from Hikvision with 2MP resolution and a 25fps max frame rate. With a 4.7mm-94mm focal length this camera offers 25x optical zoom and built in IR LEDs that provide clear night-time images up to 50m. The DS-2DE4A225IW-DE is fitted with IP66 rated weatherproof housing and audio/alarm I/Os. It also utilises a range of features to improve image quality such as wide dynamic range (WDR), back light compensation (BLC) and 3D digital noise reduction (3D DNR). This camera supports 300 presets, 8 patrols and 4 patterns with access for up to 32 users. The DS-2DE4A225IW-DE has a built-in micro SD card slot and can be powered through a 12VDC power supply or 18W PoE injector. Remote access is possible through a browser or through the Hik-Connect app.
    Hikvision Product CatalogueHikvision Quick GuideUser Manual Learn More
  25. Wisenet XNP-6320HS 2MP Stainless Steel PTZ Dome Camera
    £3,430.44 Incl VAT Excl VAT. £2,858.70
    The Wisenet XNP-6320HS is a stainless steel version of the SNP-6320H. The XNP-6320HS offers a robust IP67, IP66, NEMA4X and IK10 rated solution for applications that need a secure and reliable camera. This PTZ come camera has the ability to zoom in perfect clarity at an incredible speed allowing you to track your evidence while continuing to capturing smooth video. This camera benefits from smart technologies including loitering detection, audio detection, face detection and motion detection, plus has built-in bi-directional audio. There are also a range of mounting accessories available in stainless steel to complete this versatile solution.
    XRN-1610S banner
    Learn More
  26. Hikvision DS-2DE4A204IW-DE 2MP Low Light Network PTZ Camera
    Hikvision DS-2DE4A204IW-DE 2MP 4X Mini PTZ Camera
    The Hikvision DS-2DE4A204IW-DE is a 2MP PTZ with a 2.8mm-12mm lens that offers 4x optical zoom and 16x digital zoom. This PTZ is designed to work well in low light environments with the use of image enhancers such as wide dynamic range (WDR), back light compensation (BLC) and 3D digital noise reduction (3D DNR) technology. Built-in IR LEDs allow recording in complete darkness up to 50m. The DS-2DE4A204IW-DE is a great choice for external applications with IP66 rated weatherproof housing and the option for external microphones/speakers to be connected. This PTZ supports 300 presets, 8 patrols and 4 pattern scans. It is also loaded with a range of smart features to improve security such as intrusion detection, line crossing detection and region entrance/exit detection. There is an on-board SD card slot which can be utilised along with H.265+ compression; offering a huge saving on bandwidth and storage usage. This camera can be powered via a 12VDC power supply or a PoE+ injector. Remote access is possible through the Hik-Connect app or via a browser.
  27. Hikvision DS-2CD4B36FWD-IZS 3MP Low Light Smart Bullet Camera
    Hikvision DS-2CD4B36FWD-IZS 3MP Darkfighter Smart Bullet Camera
    The Hikvision DS-2CD4B36FWD-IZS is a 3MP bullet camera with a 2.8mm-12mm motorised zoom lens which provides a 88.5° to 32.8° horizontal field of view. This camera has built in IR LEDs that are effective up to 30m, an audio/alarm I/O and uses IP67 rated weatherproof housing to ensure that the camera can be mounted externally without any concerns. The DS-2CD4B36FWD-IZS is designed for low light applications with 0.005 lux (color), or 0.0005 lux (B/W) minimum illumination with IR off and a range of imaging enhancing features: Wide dynamic range (WDR), back light/highlight compensation (BLC/HLC), electronic image stabilization (EIS) and Defog.This camera also comes with a range of smart features such as motion detection, line crossing detection, intrusion detection, object removal detection and more. The DS-2CD4B36FWD-IZS has 3-axis adjustment which means that any area of interest can be covered easily and an optional on board SD card slot for recording ease if preferred. H.265+ video compression can be used to dramatically reduce storage and bandwidth needs. This camera can be powered with either a 12V DC power supply or a PoE injector and can be accessed remotely through a browser or through the Hik-Connect app.
  28. Hikvision DS-2CD2155FWD-I/B | 2.8mm 5MP Black Dome Network Camera
    The DS-2CD2155FWD-I/B is a black 5MP (2560 x 1920) dome camera with the choice of either a 2.8mm, 4mm or 6mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2155FWD-I/B has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2155FWD-I/B can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  29. Hikvision DS-2CD2735FWD-IZS/G Grey 3MP Motorised Zoom Dome Network Camera
    The Hikvision DS-2CD2735FWD-IZS/G is a grey 3MP dome camera with a 2.8mm - 12mm motorised zoom lens and built-in infra-red LEDs that are effective up to 30m. This camera is fitted with IP67 weatheproof housing and IK10 vandal resistant housing making it a great choice for outdoor applications. The DS-2CD2735FWD-IZS/G can cover a wide area of interest with 3-axes adjust-ability and optional wall mount. A range of features are used to improve mage quality: back light compensation (BLC), 3D digital noise reduction technology (3D DNR), wide dynamic range (WDR) and region of interest (ROI). Furthermore, a range of built-in smart features are used to imrprove security even further: motion detection, line crossing detection intrusion detection and more. The DS-2CD2735FWD-IZS/G has an optional SD card slot and uses H.265+ compression to greatly reduce bandwidth and storage needs. This camera can be powered with a 12VDC power supply or by PoE. It can be accessed remotely via a web browser or the Hik-Connect app.
    Hikvision H.265+ banner
  30. Hikvision DS-2CD2335FWD-I/G | 4mm 3MP Grey Turret Network Camera
    The Hikvision DS-2CD2335FWD-I/G is a grey 3MP (2560 x 1920) turret camera with a 4mm fixed lens. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2335FWD-I/G is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2335FWD-I/G also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2335FWD-I/G has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
    Learn More
  31. Axis Q6125-LE PTZ Network Camera 01233-003
    £3,213.60 Incl VAT Excl VAT. £2,678.00
    Ideal for discreet surveillance 24/7, the Axis Q6125-LE is a full featured PTZ camera with built-in IR effective up to 200m making this camera perfect for unlit or low light areas such as parks, harbours, alleys and car parks. OptimisedIR means the camera's IR LEDs are able to automatically adjust to suit the exact degree of zoom, enabling users to see exactly what they want to. With Sharpdome Technology the Q6125-LE is able to see as much as 20° above the horizon at the same sharp image quality as the view below the horizon. HDTV 1080p, 30x optical zoom and fast, precise pan-tilt-zoom action gives both a wide area of coverage and great detail. Pre-installed with Axis Guard Suite analytics, including; Axis Fence Guard, Axis Motion Guard and Axis Loitering Guard for detecting motion, intrusion and loitering. Included Camera Accessories: - IP66 rated RJ45 connector kit - Axis High PoE 60W SFP Midspan - Installation Guide - Windows decoder 1-user license
    This may be on the Axis list of products with long lead times, please contact us for stock levels.
    Axis Q6125-LE User Manual
    Axis Q6125-LE Installation Guide
    Learn More
  32. Axis M3058-PLVE 12MP Dome Camera 01178-001
    The Axis M3058-PLVE is the ideal solution for users who need a both great day and night time performance. With OptimisedIR, Forensic WDR and Lightfinder technology this camera delivers sharp images in any light condition. Featuring a stereographic lens the M3058-PLVE achieves a higher resolution around the outer area of view than in the center, enabling objects located at distance in the camera's peripheral view to be captured more clearly. This feature can be particularly useful if the camera is facing down. This camera has built-in I/O ports allowing users to connect a sensor or detector to trigger alarms or actions and to control devices or relays to open/close doors, turn on/off lights etc. With its flat, vandal resistant design the M3058-PLVE is ideal for use in shops, hotels, offices, banks, schools and hospitals. Included Camera Accessories: - Installation guide - Windows decoder 1-user license - Drill hole template - Cable gaskets - Connector guard - I/O connector - Resistorx T20 L-key - Mounting bracket - Cable hole lid - View protector
    Axis M3058-PLVE User Manual
    Axis M3058-PLVE Installation Guide
    Learn More
  33. Axis M3057-PLVE 6MP Dome Camera 01177-001
    £694.80 Incl VAT Excl VAT. £579.00
    The Axis M3057-PLVE is an IP66 rated dome camera that can be mounted in both indoor or outdoor environments for around the clock security. Its IK10 housing protects the camera against vandalism and the IP66 rating shelters the M3057-PLVE from dust and water. Users are able to stream a complete 360° overview meaning you can record everything with no blind spots with the video management software enabling you to use that stream to produce any dewarped views you'd like as well as being able to digitally pan, tilt and zoom in on areas of interest in up to four areas simultaneously. This camera has been designed to product sharp images in any level of light, the OptimisedIR enabled great images even in the dark. Equipped with Forensic WDR the M3057-PLVE allows visibility when there are both dark and light areas in the same scene. Axis Zipstream technology analyses video stream in real time to identify areas of interest, this technology will them preserve important details in full video quality and compress other areas which reducing storage and bandwidth by up to 50%. Resulting in high image quality at significant savings. Included Camera Accessories: - Installation guide - Windows decoder 1-user license - Drill hole template - Cable gaskets - Connector guard - I/O connector - Resistorx T20 L-key - Mounting bracket - Cable hold lie - View protector
    Axis M3057-PLVE User Manual
    Axis M3057-PLVE Installation Guide
    Learn More
  34. Axis Q1647 5MP Network Camera with i-CS Lens 01051-001
    £1,498.80 Incl VAT Excl VAT. £1,249.00
    The Axis Q1647 is a full featured network camera delivering high resolution video at full frame rate producing crystal clear images even under tough lighting conditions. With full resolution, full frame rate and superior light sensitivity; this camera shows users the difference between a sharp image and a razor sharp image! Featuring; electronic image stabilisation, Forensic WDR and Lightfinder this camera is able to provide outstanding image in a variety of different lighting environments. The Q1647 comes pre-installed with Axis Motion Guard, Axis Fence Guard and Axis Loitering Guard analytics enabling the facilitation of enhanced security, first class image usability and fast and easy installation. Not only this but the i-CS lens technology further minimises time and money spent on installation as users can set zoom remotely and the camera automatically sets the focus. Users can choose between three scene profiles, all of which will automatically optimise exposure time, white balance, aperture sharpness, contrast and noise for all cameras in the solution to suit the scenario. Choices are: - Forensic profile, for general surveillance and capturing details - Live profile, for more vivid colours and higher contrast - Traffic overview profile, optimised for traffic surveillance Included Camera Accessories: - Stand - Connector kit - Resistorx T20 tool - Installation guide - Windows decoder 1-user license
    Axis Q1647 User Manual
    Axis Q1647 Installation Guide
    Learn More
  35. Axis Q1645 Network Camera with i-CS Lens 01222-001
    Axis Q1645 2MP Network Camera with i-CS Lens 01222-001
    £1,285.20 Incl VAT Excl VAT. £1,071.00
    The Axis Q1645 network camera has been designed for light sensitivity second to none. This camera is sharp is many ways including; delivering high resolution video at high speed for crystal clear images and built-in analytics to help users make decisions about operations and resource allocations. Packed with intelligent features such as Axis Motion Guard, Axis Fence Guard and Axis Loitering Guard analytics this camera is able to facilitate smart decision-making, enhanced security, first class image usability and fast and easy installation. Not only this but i-CS lens technology enables fast and easy installation and adjustment, with the ability to adjust the zoom remotely and the camera automatically setting the focus time and money spent on installation can be minimised. The Q1645 has three scene profiles for users to choose between. With each profile the camera will automatically optimise exposure time, white balance, aperture, sharpness, contrast and noise to suit each specific scenario. Users can choose between: - Forensic profile, for general surveillance and capturing details - Live profile, for more vivid colours and higher contrast - Traffic overview profile, optimised for traffic surveillance Included Camera Accessories: - Stand - Connector kit - Resistorx T20 tool - Installation guide - Windows decoder 1-user license
    Axis Q1645 User Manual
    Axis Q1645 Installation Guide
    Learn More
  36. Hikvision DS-2CD2355FWD-I | 2.8mm 5MP Turret Network Camera
    Hikvision DS-2CD2355FWD-I/G | 2.8mm 5MP Grey Turret Network Camera
    The Hikvision DS-2CD2355FWD-I/G is a grey 5MP (2560 x 1920) turret camera with a 2.8mm fixed lens. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2355FWD-I/G is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2355FWD-I/G also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2355FWD-I/G has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
    Learn More
  37. Vivotek FE9391-EV 12MP 360° Panomorph Outdoor Fisheye Camera
    £836.40 Incl VAT Excl VAT. £697.00
    The Vivotek FE9391-EV is a 12MP outdoor fisheye camera that used the latest 360° panomorph lens technology to eradicate blind spots making it the perfect solution for use in open spaces such as shopping centres, car parks and airports. The FE9391-EV is IP66 weatherproof-rated and IK10 vandal-resistant making it suitable for use outdoors and in areas where it may be exposed to vandals. This model also has built-in infra-red LED's meaning it can capture better images up to 20m in the dark. This product may not be immediately available from UK stock, in which case it may take 10-14 days to fetch it from their European warehouse. Accessory Guide Quick Installation Guide User Manual Learn More
  38. Vivotek FE9191 12MP 360° Panomorph Fisheye Camera
    £638.40 Incl VAT Excl VAT. £532.00
    The Vivotek FE9191 is a 12MP 360° fisheye camera, using the latest panomorph technology for 180° panoramic view (when wall mounted) or 360° surround view (when ceiling/wall/floor mounted) with no blind spots, making it the idea solution for open areas like airports, car parks and retail outlets. This product may not be immediately available from UK stock, in which case it may take 10-14 days to fetch it from their European warehouse. Quick Installation Guide User Manual Learn More
  39. Vivotek IP9191-HP 8MP Box Camera
    £825.34 Incl VAT Excl VAT. £687.78
    Vivotek IP9191-HP is an 8MP, professional box camera, capable of capturing up to 30fps and thanks to 4K compression it still keeps your bandwidth down, therefore reducing your storage needs. The latest SNV and WDR Pro technology from Vivotek allows the IP9191-HP to capture high quality images in both low light and high contrast environments. This camera can be combined with the AE-23E enclosure to make it suitable for use outdoors.
    This item is a special order product and is not available for immediate delivery. Please check with us before purchasing as it could take 4-6 weeks to fetch from Vivotek.
    Quick Installation Guide User Manual Accessories Guide Learn More
  40. Hikvision DS-2CD2555FWD-I 5MP Mini Dome Network Camera
    Hikvision DS-2CD2555FWD-IS 5MP Mini Dome Network Camera
    The DS-2CD2555FWD-IS is a 5MP (2944 x 1656) mini dome camera with a 2.8mm or 4mm fixed lens. It is the most compact of all of Hikvision's cameras with a total diameter of 110mm making it a great choice for discreet applications. It also has built in infra-red LEDs that reach a maximum distance of 10m meaning it can be used in applications where a camera is needed near a front door without making the person/object of interest appear white out - This can happen with infra-red that is more powerful. This camera comes fitted with IK08 vandal resistant housing, IP66 weatherproof housing and a lens which can be adjusted on 3-axes. The DS-2CD2555FWD-IS uses wide dynamic range (WDR) , 3D digital noise reduction (3D DNR) and back light compensation (BLC) to ensure that the best possible image is always captured. On top of these features, the DS-2CD2555FWD-IS utilises smart features such as motion detection. intrusion detection and line crossing detection to further improve security. This camera also comes with a built-in microphone. H.265+ reduces and bandwidth and storage usage up to 70% when compared to H.264 so the on board SD card slot can be used without reaching maximum capacity so quickly. This camera can be powered with either a 12VDC power supply or PoE and can be accessed remotely through a browser or via the Hik-Connect app.
    Hikvision Product CatalogueHikvision Quick GuideUser ManualMini Dome Quick Start Manual Learn More
  41. Hikvision DS-2CD2535FWD-I 3MP Mini Dome Network Camera
    Hikvision DS-2CD2535FWD-IS 3MP Mini Dome Network Camera
    The DS-2CD2535FWD-IS is a 3MP (2048 x 1536) mini dome camera with a 2.8mm fixed lens. It is the most compact of all of Hikvision's cameras with a total diameter of 110mm making it a great choice for discreet applications. It also has built in infra-red LEDs that reach a maximum distance of 10m meaning it can be used in applications where a camera is needed near a front door without making the person/object of interest appear white out - This can happen with infra-red that is more powerful. This camera comes fitted with IK08 vandal resistant housing, IP66 weatherproof housing and a lens which can be adjusted on 3-axes. The DS-2CD2535FWD-IS uses wide dynamic range (WDR) , 3D digital noise reduction (3D DNR) and back light compensation (BLC) to ensure that the best possible image is always captured. On top of these features, the DS-2CD2535FWD-IS utilises smart features such as motion detection. intrusion detection and line crossing detection to further improve security. This camera also comes with with a built-in microphone. H.265+ reduces and bandwidth and storage usage up to 70% when compared to H.264 so the on board SD card slot can be used without reaching maximum capacity so quickly. This camera can be powered with either a 12VDC power supply or PoE and can be accessed remotely through a browser or via the Hik-Connect app.
    Hikvision DS-2CD2535FWD-I key features banner
  42. Vivotek CC8371-HV 3MP 180° Panoramic Fisheye Camera
    £412.72 Incl VAT Excl VAT. £343.93
    The Vivotek CC8371-HV is a 3MP 180° Panoramic vandal-resistant fisheye camera with a unique design making suitable for a wide range of applications, including shops, schools, residential homes and prisons. The CC8371-HV also has a built-in microphone and infra-red illuminators to capture footage in the dark up to 15 meters. In addition, the latest SNV technology from Vivotek produces high quality images in both dark and bright conditions.
  43. Wisenet QNP-6230H 2MP Vandal Resistant PTZ Dome Camera
    £833.78 Incl VAT Excl VAT. £694.82
    The Wisenet QNP-6230H is a 2MP PTZ Dome Camera suitable for use outdoors thanks to its IP66 weatherproof-rated and IK10 vandal-resistant housing. The QNP-6230H can be combined with a wide range of mounting accessories meaning you can create a solution to meet your needs. Banner
    This product may not be immediately available from UK stock, in which case it may take 7-10 days to fetch it from their European warehouse.
  44. Wisenet QNP-6230 2MP Outdoor PTZ Dome Camera
    £735.78 Incl VAT Excl VAT. £613.15
    The Wisenet QNP-6230 is a 2MP PTZ Dome Camera suitable for use outdoors thanks to its IP66 weatherproof-rated housing. With the addition of the SHP-3701H housing this camera can also be made vandal resistant. The QNP-6230 can be combined with a wide range of mounting accessories meaning you can create a solution to meet your needs. Banner
  45. Axis M3016 Recessed Mount Mini Dome Camera 01152-001
    £394.80 Incl VAT Excl VAT. £329.00
    The Axis M3016 is a very discreet indoor dome camera that has been designed specifically for recessed mounting. The camera has 3-axis adjustment allowing for leveling and pointing in any direction, making the M3016 ideal for use in a wide range of applications including shops, offices, hotel lobbies etc. The M3016 provides 3MP video at 30fps in maximum resolution and has WDR ensuring visible details in both light and dark environments. Featuring the advanced Axis Zipstream technology to keep bandwidth and storage requirements low. The camera is also equipped with a memory card slot for on board storage. Included Accessories: - Installation guide - Windows decoder 1-user license
    Axis M3016 User Manual
    Axis M3016 Installation Guide
    Learn More
  46. Axis M3015 Recessed Mount Mini Dome 01151-001
    Axis M3015 Recessed Mount Mini Dome Camera 01151-001
    £288.00 Incl VAT Excl VAT. £240.00
    The Axis M3015 delivers HDTV 1080p at full frame rate. With WDR, the camera is able to provide excellent video quality in both the brightest and darkest area of a scene.
    Featuring Axis Zipstream technology keeping storage and bandwidth costs down, allowing users to get more out of their storage. Axis Corridor Format option allows for optimal coverage of isles and corridors.
    This camera has been designed specifically for recessed mounting for an unobtrusive, discreet look. The camera cover is easy to repaint to blend into any background making this camera ideal for a wide range of applications such as; offices, hotel lobbies, shops etc.
    Axis M3015 User Manual
    Axis M3015 Installation Guide
    Axis Assigning IP Address User Manual Axis Product Comparison Table Autumn 2016 Axis Product Guide Learn More
  47. Vivotek IB9367-HT 2MP Vari-focal Outdoor Bullet Camera
    £505.20 Incl VAT Excl VAT. £421.00
    The Vivotek IB9367-H is a professional outdoor 2MP vari-focal bullet camera with two-way audio and a built-in MicroSD/SDHC/SDXC Card Slot. The camera also benefits from a Weather-proof IP66, IP67 and Vandal-proof IK10-rated Housing. The IB9367-H is capable of capturing high quality images in both low light and high contrast situations and with built-in infra-red LED's it can capture footage at night time up to 30m away.
    Accessory Chart Quick Installation Guide User Manual Learn More
  48. Vivotek IB9367-H 2MP Outdoor Bullet Camera
    £507.49 Incl VAT Excl VAT. £422.91
    The Vivotek IB9367-H is a professional outdoor 2MP bullet camera with two-way audio and a built-in MicroSD/SDHC/SDXC Card Slot. The camera also benefits from a Weather-proof IP66, IP67 and Vandal-proof IK10-rated Housing. The IB9367-H is capable of capturing high quality images in both low light and high contrast situations and with built-in infra-red LED's it can capture footage at night time up to 30m away.
  49. Wisenet XNF-8010R 6MP Sensor Fisheye Camera
    Wisenet XNF-8010R 4MP Sensor Fisheye Camera
    £576.00 Incl VAT Excl VAT. £480.00
    The Wisenet XNF-8010R is a 4MP Indoor fisheye camera with built-in infra-red LED's to allow for up to 15m of night time viewing. It has a built-in SD / SDHC / SDXC memory card slot and bi-directional audio and can be used with a wide range of accessories meaning its potential uses are varied. This camera can be used with a wide range of intelligent video analytics including Tampering, Loitering, Enter/Exit, Audio detection, People counting, Heat-mapping and Queue Management.
    XRN-1610S banner
  50. Wisenet XNP-6120H "2MP HD PTZ Dome Camera
    Wisenet XNP-6120H 2MP HD Outdoor PTZ Dome Camera
    £847.06 Incl VAT Excl VAT. £705.88
    The Wisenet XNP-6120H is a 2MP, IP66 weatherproof-rated and IK10 vandal-resistant rated, outdoor PTZ camera. The XNP-6120H is capable of 12x optical zoom and 32x digital zoom and 360˚ endless pan. The camera also benefits from a built-in SD/SDHC/SDXC memory slot and can support bi-directional audio. There are a wide range of compatible accessories for this camera, meaning you can find a solution to meet your needs. XRN-1610S banner
Grid  List
