IP Cameras
IP cameras, also known as Network Cameras, connect directly to your Home or Office IP Network and can easily be viewed or recorded anywhere else on the network or even across the internet.
£260.40 Incl VAT Excl VAT. £217.00
In Stock
The Milesight UI-5D62-FIPCV Pro bullet is equipped with 3rd generation dot matrix IR LEDs providing superior night visibility up to 35m as well as ensuring a long lifespan and energy efficiency. This camera has been designed for outdoor use with an IP66 weatherproof housing to protect the camera against outdoor weather conditions as well as a PTFE membrane with ventilation holes to keep moisture and dust out of the camera whilst allowing air to flow in and out of the device.
Featuring video content analysis to supply users with the most advanced, smart video analytics for Milesight cameras. Milesight VCA has 8 detection modes; - Region entrance and region exiting ~ the two functions are used to alert when people/object enter/exit a specific area. - Advanced motion detection ~ with more intelligent features than traditional motion detection, advanced motion detection can filter out 'noise' such as lighting changes, tree movement etc. Parameters can be set to detect various movements depending on requirements. - Tamper detection ~ triggers an alarm when there is an attempt to move the camera or a suspicious object/person is obstructing the camera view. - Line crossing ~ when enable, an event will be triggered everytime an object crosses the virtual line. - Loitering ~ an alarm is triggered when an object stays in a specified area for a certain length of time. - Human detection ~ this can be used to determine if an object is human or not. - People counting ~ counts how many people enter/exit an area/.
Other camera features include; H.265+ video compression, PoE built-in, a motorised zoom lens and super WDR.
Included accessories: - Quick start guide - Junction Box - Mounting template - Screws - Rawl plugs - Screwdrivers
£219.60 Incl VAT Excl VAT. £183.00
In Stock
The Milesight UI-2A62-FIPCV Pro bullet is equipped with 3rd generation dot matrix IR LEDs providing superior night visibility up to 35m as well as ensuring a long lifespan and energy efficiency. This camera has been designed for outdoor use with an IP66 weatherproof housing to protect the camera against outdoor weather conditions as well as a PTFE membrane with ventilation holes to keep moisture and dust out of the camera whilst allowing air to flow in and out of the device.
£1,140.00 Incl VAT Excl VAT. £950.00
The Milesight UI-2A42-RCV is a Speed Dome Camera with a 360° endless pan and a 0~90° auto flip tilt providing users with fast and precise movement. Designed so that users can easily control lens position via mouse and set up to 255 preset positions for patrolling, this PTZ can provide great coverage of the areas of interest.
As well as that, the UI-2A42-RCV has a 30x optical zoom lens which can zoom in on distant objects without any loss of clarity or quality. Smart PTZ motion detection provides users with extra peace of mind as the camera will automatically pan and tilt to a preset area when motion is detected. The camera will also zoom in on the detected object in the targeted area to provide a clear image before returning back to its previous monitoring position when motion is no longer detected in that area.
With IR LEDs effective up to 200m this speed dome is ideal for outdoor surveillance at night as it is able to provide distinct images over a large distance even at night. It is also equipped with an IP66 weatherproof housing protecting the camera from rain and dust ensuring a stable operation in all weather environments.
£418.80 Incl VAT Excl VAT. £349.00
The Milesight Mini PTZ Bullet camera provides a refreshing take on the traditional PTZ camera with its sleek and aesthetically pleasing bullet design. The UI-5D61-EPCV offers a 360° endless pan and 75° tilt to provide provide coverage to a wide area.
12x optical zoom enables the camera to zoom in on distant object whilst maintaining the image clarity, providing high quality images at all times.
With improved Smart IR II technology the viewing range has increased to up to 100m, the top two IR LEDs work as high beam and the two bottom LEDs work as low beam for better quality even over a large distance. Not only this but the camera has an intelligent White LED that can be turned on as a supplementary light source/warning signal.
Featuring Smart PTZ motion detection users are able to monitor a specific pre-set area clearly when motion has been detected. The UI-5D61-EPCV will automatically pan and tilt to the motion detected area and zoom where needed to provide a clear image of the area and source of motion.
With an IP66 weatherproof rating the camera can be used for both indoor and outdoor applications depending on the need of the user. The camera housing also has a breathable screw-in vent to reduce fogging, condensation, eliminate moisture and improve the lifespan of the product.
Included Accessories: - Junction box - Quick start guide - Mounting template - Waterproof connectors - Screws - Rawl plugs - Screwdriver
£358.80 Incl VAT Excl VAT. £299.00
Out of Stock
The Milesight Mini PTZ Bullet camera provides a refreshing take on the traditional PTZ camera with its sleek and aesthetically pleasing bullet design. The UI-2A61-EPCV offers a 360° endless pan and 75° tilt to provide provide coverage to a wide area.
12x optical zoom enables the camera to zoom in on distant object whilst maintaining the image clarity, providing high quality images at all times. With improved Smart IR II technology the viewing range has increased to up to 100m, the top two IR LEDs work as high beam and the two bottom LEDs work as low beam for better quality even over a large distance. Not only this but the camera has an intelligent White LED that can be turned on as a supplementary light source/warning signal.
Featuring Smart PTZ motion detection users are able to monitor a specific pre-set area clearly when motion has been detected. The UI-2A61-EPCV will automatically pan and tilt to the motion detected area and zoom where needed to provide a clear image of the area and source of motion.
Included Accessories: - Quick start guide - Mounting template - Waterproof connectors - Screws - Rawl plugs - Screwdriver
£345.60 Incl VAT Excl VAT. £288.00
In Stock
The Milesight UI-8E62-FIPC is a 4K bullet camera that delivers ultra high definition video which is effectively four times that of Full HD.
This camera also features High Light Compensation which can identify high light areas and adjust exposure around this area to provide clear distinctive images, this can be used to capture license plates. Its P-Iris lens has a more precise control of the iris to provide a clearer scene with a greater depth of view.
With its IP67 weatherproof housing this camera is ideal for outdoor use as it is protected against rain and dust ensuring stable operation in all weather conditions.
As well as this the 4K camera has an integrated junction box to aid cable management and ease installation, the housing is also IP67 rated to protect the cables from rain and dust. Not only this but the camera has ventilation holes designed to keep moisture and dust out whilst allowing air flow in and out of the device preventing fogging and condensation build up on the camera lens.
Featuring Milesight's 3rd generation dot matrix IR LEDs the UI-8E62-FIPC is able to deliver superior night visibility, this alongside Smart IR II which has upgraded the IR LEDs technology for improved image quality. The two top LEDs work as high beam whilst the bottom two work as low beam, giving a better image clarity, the beams brightness can be adjusted.
£270.00 Incl VAT Excl VAT. £225.00
The Milesight UI-5D51-PCV is a 5 megapixel day and night box camera featuring HLC (High Light Compensation) which can identify the high light spot and adjust the exposure time to compensate for the area around these spots. This can be used to capture license plates under car headlights.
Box camera's have long been popular with users who would like to use a specialist lens as these camera's do not come with lenses so there is many more options in regards to focal lengths. They can also be used to replace an existing box camera when you would still like to keep the same lens.
Often sold for more project based CCTV than home use the Milesight Pro box camera can be used in a wide range of applications, for various different needs.
The base of this camera has a variety of built-in interfaces such as; PTZ control, Alarm I/O, an ethernet port, power connector, microSD card slot, Audio I/O, a reset button and power and error LEDs.
This product is subject to a 3 week lead-time to fetch it from manufacturer's stock/ there may be no UK stock of this model. Please check stock before purchasing.
£210.00 Incl VAT Excl VAT. £175.00
The Milesight UI-2A51-PCV is a 2 megapixel day and night box camera featuring HLC (High Light Compensation) which can identify the high light spot and adjust the exposure time to compensate for the area around these spots. This can be used to capture license plates under car headlights.
£306.00 Incl VAT Excl VAT. £255.00
In Stock
The Milesight UI-5D72-FIPCV Pro range of dome camera's possess many advanced features to suit the needs of a wide range of users. Features include VCA (video content analysis) qualities such as: - Region entrance and region exiting ~ the two functions are used to alert when people/object enter/exit a specific area. - Advanced motion detection ~ with more intelligent features than traditional motion detection, advanced motion detection can filter out 'noise' such as lighting changes, tree movement etc. Parameters can be set to detect various movements depending on requirements. - Tamper detection ~ triggers an alarm when there is an attempt to move the camera or a suspicious object/person is obstructing the camera view. - Line crossing ~ when enable, an event will be triggered everytime an object crosses the virtual line. - Loitering ~ an alarm is triggered when an object stays in a specified area for a certain length of time. - Human detection ~ this can be used to determine if an object is human or not. - People counting ~ counts how many people enter/exit an area/.
Other features include; a motorised focus and zoom lens which comes in options 2.8~12mm, 3~10.5mm or 7~22mm enabling users to choose the lens that really suits their needs to get the most out of the camera. The camera also features a P-Iris lens to control the iris more precisely to eradicate diffraction under strong light giving a clearer scene with depth of view.
The camera has been designed for outdoor use with an IP67 and IK10 rated housing protecting the camera against rain, dust and vandal attempts. Not only this but the camera features a clamshell design which has been created by Milesight with the aim reduce installation issues by making the space to make cable connections larger. The base of the camera has a PoE port to further improve the ease of installation.
Included accessories: - Quick start guide - Mounting template - Waterproof connector - Screws - Rawl plugs - Screwdrivers
Milesight User ManualMilesight Product BrochureMilesight Product Catalogue
Learn More£258.00 Incl VAT Excl VAT. £215.00
In Stock
The Milesight UI-2A72-FIPCV Pro range of dome camera's possess many advanced features to suit the needs of a wide range of users. Features include VCA (video content analysis) qualities such as: - Region entrance and region exiting ~ the two functions are used to alert when people/object enter/exit a specific area. - Advanced motion detection ~ with more intelligent features than traditional motion detection, advanced motion detection can filter out 'noise' such as lighting changes, tree movement etc. Parameters can be set to detect various movements depending on requirements. - Tamper detection ~ triggers an alarm when there is an attempt to move the camera or a suspicious object/person is obstructing the camera view. - Line crossing ~ when enable, an event will be triggered everytime an object crosses the virtual line. - Loitering ~ an alarm is triggered when an object stays in a specified area for a certain length of time. - Human detection ~ this can be used to determine if an object is human or not. - People counting ~ counts how many people enter/exit an area/.
Regular Price: £214.80
Special Price £168.00 Incl VAT Excl VAT. £140.00
In Stock
With many of the same features as the Milesight Mini Bullet camera the UI-5D63-FIPCV has the added extra of a motorised lens. This feature will enable users to remotely zoom between 2.8~12mm depending on what area they wish to cover/how detailed they require certain parts of a scene to be.
Like the fixed mini bullet this camera has an IP67 rated weatherproof housing protecting the camera against water and dust and a sunshield to stop sunlight entering the path of the lens and distorting the image.
The camera also features a 3-axis bracket which ensures ease of installation and has a robust design to protect and conceal power cables.
The P-Iris lens provides a more precise iris control, delivering improved video quality and depth of field by limiting the iris opening to ensure just the right amount of light is let into the lens for optimal image quality.
With features such as H.265+ video compression and video content analysis this camera has many of the newest/most desirable features on the market making it a go to choice for users from all backgrounds.
Included Accessories: - Quick start guide - Screws - Rawl plugs - Screwdriver
£146.40 Incl VAT Excl VAT. £122.00
Regular Price: £168.00
Special Price £152.40 Incl VAT Excl VAT. £127.00
In Stock
With many of the same features as the Milesight Mini Bullet camera the UI-2A63-FIPCV has the added extra of a motorised lens. This feature will enable users to remotely zoom between 2.8~12mm depending on what area they wish to cover/how detailed they require certain parts of a scene to be.
Like the fixed mini bullet this camera has an IP67 rated weatherproof housing protecting the camera against water and dust and a sunshield to stop sunlight entering the path of the lens and distorting the image. The camera also features a 3-axis bracket which ensures ease of installation and has a robust design to protect and conceal power cables.
£138.00 Incl VAT Excl VAT. £115.00
Special Price £134.40 Incl VAT Excl VAT. £112.00
In Stock
With a unique housing design the Milesight UI-5D63-PCV mini bullet camera effectively blocks the sun from entering the lens path due to the sunshield almost encompassing the camera, not only this but the housing also offers thermal insulation and is IP67 weatherproof protecting the camera against harsh outdoor weather.
The camera's mounting bracket tightly conceals the cable to make sure it is well protected from dust, water and even shock damages as well as this the bracket has a 3-axis design to enable users to easily angle the camera to find the perfect spot for surveillance.
Other impressive features include; Super WDR (wide dynamic range) which is a sensor based technology used to balance out the colour representation in areas with extreme back light and high contrast conditions to produce true colour images and H.265+ video compression to reduce bandwidth by 70-80% compared to H.264.
Also included with this camera is VCA (video content analysis) which allows users access to even more advanced options such as; region entrance, region exiting, advanced motion detection, line crossing, loitering and people counting.
Focal length options are: - 4mm ~ 62.8° FOV - 6mm ~ 44° FOV
£1,442.82 Incl VAT Excl VAT. £1,202.35
Regular Price: £150.48
Special Price £120.00 Incl VAT Excl VAT. £100.00
In Stock
With a unique housing design the Milesight UI-2A63-PCV mini bullet camera effectively blocks the sun from entering the lens path due to the sunshield almost encompassing the camera, not only this but the housing also offers thermal insulation and is IP67 weatherproof protecting the camera against harsh outdoor weather. The camera's mounting bracket tightly conceals the cable to make sure it is well protected from dust, water and even shock damages as well as this the bracket has a 3-axis design to enable users to easily angle the camera to find the perfect spot for surveillance.
This camera also features Milesight's starlight technology which enables the camera to provide incredibly detailed colour images even in very low light environments without any extra added lighting. Other impressive features include; Super WDR (wide dynamic range) which is a sensor based technology used to balance out the colour representation in areas with extreme back light and high contrast conditions to produce true colour images and H.265+ video compression to reduce bandwidth by 70-80% compared to H.264.
This camera comes in a choice of two focal lengths: - 4mm ~ 78.8° FOV - 6mm ~ 53.8° FOV
In Stock
The Milesight UI-5D73-PCV Vandal Resistant Mini Dome camera has been designed specifically for outdoor use with its IP67 weatherproof housing protecting the camera against dust, rain and other temperature fluctuations. Not only that but the camera has a vandal resistant metal base and polycarbonate cover to withstand high impact force and shock and still provide and maintain stable and reliable footage. Being both weatherproof and vandal resistant makes this camera ideal for use outdoors in harsh climate conditions and in high risk environments.
The camera also features Milesight's latest IR LED technology providing superior images at night effective up to 20m and HLC (high light compensation) which can identify any overexposure on an image and combat this to improve the overall image even enabling users to be able to identify license plates under car headlights. This feature proves to be very popular with users from varying backgrounds with different needs including home owners to identify vehicles near their houses and business owners wanting to keep an eye on cars in the staff car park etc.
Other desirable features of this camera include; H.265+ video compression which reduces bandwidth by 70-80% compared to H.264 also reducing storage costs for users meaning they can get more out of their chosen storage method; either microSD card if you would like to utilise the on board storage feature or HDD if you are recording your system using an NVR.
There is also a choice of focal length so users can find the perfect angle for their application, focal length options are; - 2.8mm ~ 103° FOV - 3.2mm ~ 96° FOV - 3.6mm ~ 80° FOV - 6mm ~ 43.4° FOV
£150.48 Incl VAT Excl VAT. £125.40
In Stock
The Milesight UI-2A73-PCV Vandal Resistant Mini Dome camera has been designed specifically for outdoor use with its IP67 weatherproof housing protecting the camera against dust, rain and other temperature fluctuations. Not only that but the camera has a vandal resistant metal base and polycarbonate cover to withstand high impact force and shock and still provide and maintain stable and reliable footage. Being both weatherproof and vandal resistant makes this camera ideal for use outdoors in harsh climate conditions and in high risk environments.
Other desirable features of this camera include; H.265+ video compression which reduces bandwidth by 70-80% compared to H.264 also reducing storage costs for users meaning they can get more out of their chosen storage method; either microSD card if you would like to utilise the on board storage feature or HDD if you are recording your system using an NVR. There is also a choice of focal length so users can find the perfect angle for their application, focal length options are; - 2.8mm ~ 109.4° FOV - 3.6mm ~ 84.6° FOV - 6mm ~ 52.7° FOV
Learn More£1,897.82 Incl VAT Excl VAT. £1,581.52
£1,290.00 Incl VAT Excl VAT. £1,075.00
£1,694.30 Incl VAT Excl VAT. £1,411.92
£1,209.46 Incl VAT Excl VAT. £1,007.88
£560.28 Incl VAT Excl VAT. £466.90
£220.31 Incl VAT Excl VAT. £183.59
£150.00 Incl VAT Excl VAT. £125.00
£4,677.35 Incl VAT Excl VAT. £3,897.79
The Axis Q6055-S is a pressurised, marine grade stainless steel PTZ camera giving the camera a high resistance to corrosion, cleaning chemicals and high pressure steam.
£1,148.40 Incl VAT Excl VAT. £957.00
The Axis P1368-E is a 4K Ultra HD outdoor box network camera built specifically for all weather conditions with a quick and easy installation in mind also featuring Axis Zipstream technology to save bandwidth and storage whilst maintaining video quality.
£996.00 Incl VAT Excl VAT. £830.00
In Stock
The Axis P1367-E is a 5 megapixel outdoor network camera providing great video quality with a high level of detail.
£769.04 Incl VAT Excl VAT. £640.87
The Axis P1367 is a 5 megapixel network camera that features; P-Iris to provide optimal image clarity in complex lighting and even in the dark and a CS mount to give flexibility to change lenses for different situations.
£392.23 Incl VAT Excl VAT. £326.86
The Axis P1275 is a discreet varifocal dome network camera that has been designed specifically for indoor surveillance in stores, offices and banks.
The Mobotix Mx-v26A-6 is 6 megapixel indoor mini dome camera black.
The Mobotix Mx-v26A-6 is 6 megapixel indoor mini dome camera.
As low as: £512.00
The Mobotix Mx-p26A-AU-6 is a 6 megapixel camera with audio designed for flexible indoor applications.
As low as: £479.00
The Mobotix Mx-p26A-6 is a 6 megapixel camera designed for flexible indoor applications.
£644.40 Incl VAT Excl VAT. £537.00
The Mobotix Mx-i26A is a 6 megapixel camera designed for unobtrusive indoor applications.
£608.40 Incl VAT Excl VAT. £507.00
£559.20 Incl VAT Excl VAT. £466.00
£546.00 Incl VAT Excl VAT. £455.00
The Mobotix Mx-c26A-AU is a 6 megapixel camera designed for unobtrusive indoor applications.
£544.80 Incl VAT Excl VAT. £454.00
The Mobotix Mx-c26A is a 6 megapixel camera designed for unobtrusive indoor applications.
£179.92 Incl VAT Excl VAT. £149.93
The Axis FA4115 is a compact varifocal dome sensor unit designed for discreet indoor surveillance applications in areas such as banks, in stores and offices.
This sensor unit supports Forensic WDR, enabling details to be visible even in high contrast lighting conditions. The sensor unit along with the main unit prioritises the darker areas of such a scene, enabling colours and details to be clearly visible.
£147.31 Incl VAT Excl VAT. £122.76
The Axis FA1105 is ideal for highly discreet indoor surveillance applications such as in stores and banks etc.
£478.80 Incl VAT Excl VAT. £399.00
The Axis FA54 supports up to four FA sensor units, enabling cost-effective and highly discreet surveillance of four closely situated areas with one system.
£715.20 Incl VAT Excl VAT. £596.00
The Axis M3048-P is a 12 megapixel mini dome camera which offers 360° overview and dewarped views such as panorama, view area, corridor, corner and quad views.
£501.60 Incl VAT Excl VAT. £418.00
The Axis M3047-P is a 6 megapixel mini dome camera which offers 360° overview and dewarped views such as panorama, view area, corridor, corner and quad views.
£2,673.36 Incl VAT Excl VAT. £2,227.80
