IP Cameras
IP Cameras from use-IP
Sidebar
IP Cameras
IP cameras, also known as Network Cameras, connect directly to your Home or Office IP Network and can easily be viewed or recorded anywhere else on the network or even across the internet.
Grid  List
  1. Hikvision DS-2CD2155FWD-IS 5MP Dome Network Camera
    The DS-2CD2155FWD-IS is a 5MP (2560 x 1920) dome camera with the choice of either a 2.8mm or 4mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2155FWD-IS has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. There is also an audio/alarm I/O so external accessories such as microphones can be used. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2155FWD-IS can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  2. Wisenet XNO-8080R 5 Megapixel Network IR Bullet Camera
    £765.60 Incl VAT Excl VAT. £638.00
    The Wisenet XNO-8080R is a 5 megapixel network IR bullet camera that is part of the Wisenet X series of cameras with improved features such as; loitering and directional detection. WDR, hallway view, IR LEDs up to 50m and is IP66/67 rated. XRN-1610S banner
    This product may not be immediately available from UK stock, in which case there will be a 7 day lead time to fetch from their European warehouse.
    Accessory ChartUser ManualH.265 BrochureX Series Brochure Learn More
  3. Hikvision DS-2CD2185FWD-I 8MP Dome Network Camera
    The DS-2CD2185FWD-I is a 8MP (3840 x 2160) dome camera with the choice of either a 2.8mm, 4mm or 6mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2185FWD-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2185FWD-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  4. Wisenet XNO-8020R 5 Megapixel IR Bullet Camera
    Wisenet XNO-8020R/XNO-8030R/XNO-8040R | 5 Megapixel IR Bullet Camera
    £480.73 Incl VAT Excl VAT. £400.61
    The Wisenet XNO-80x0R is a 2 megapixel network IR bullet camera that is part of the Wisenet X series of cameras with improved features such as; people counting, queue management, loitering and directional detection. - XNO-8020R = 3.7mm lens - XNO-8030R = 4.6mm lens - XNO-8040R = 7mm lens XRN-1610S banner
    This product may not be immediately available from UK stock, in which case there will be a 7-10 day lead time to fetch from their European warehouse.
  5. Hikvision DS-2CD2155FWD-I 5MP Dome Network Camera
    The DS-2CD2155FWD-I is a 5MP (2560 x 1920) dome camera with the choice of either a 2.8mm, 4mm or 6mm fixed lens. It is fitted with IR LEDs that provide a maximum distance of 30m in darkness, IK10 vandal resistant housing and IP67 rated weatherproof housing making it a great choice for external applications where vandalism may be a concern. The DS-2CD2155FWD-I has 3-axis adjust-ability and a variety of mounting options available helping the user to find the perfect solution to cover their specific areas of interest. It also comes equipped with a range of image enhancing features such as 3D digital noise reduction technology (3D DNR) and back light compensation (BLC). On top of this is a smart feature set including motion detection, line crossing detection and intrusion detection. This camera has a built in SD card slot which can be used to it's full ability thanks to H.265+ video compression which offers up to 70% savings on storage and bandwidth over H.264. The DS-2CD2155FWD-I can be powered via a 12VDC power supply or simply by PoE. Remote access is possible through a browser or the Hik-Connect app.
  6. Wisenet XND-8080RV 5 Megapixel Network IR Dome Camera
    £714.89 Incl VAT Excl VAT. £595.74
    The Wisenet XND-8080R is a 5 megapixel network dome camera that is part of the Wisenet X series of cameras with improved features such as; WiseStream II support, lens distortion correction, loitering and directional detection. XRN-1610S banner
  7. Wisenet XNB-8000 5MP Network Box Camera
    £484.32 Incl VAT Excl VAT. £403.60
    The Wisenet XNB-8000 is part of the Wisenet X series of cameras with improved features such as; H.265, loitering, fog, damage and sound detection and a gyro sensor. XRN-1610S banner
    Samsung Full CatalogueAccessory ChartUser ManualH.265 BrochureX Series Brochure Learn More
  8. Hikvision DS-2CD2355FWD-I 5MP Turret Network Camera
    The Hikvision DS-2CD2355FWD-I is a 5MP (2560 x 1920) turret camera available in 2.8mm, 4mm and 6mm fixed focal lengths. The camera is fitted with IR LEDs with a maximum distance of 30m. The turret's flat faced design tackles the issue of IR reflection, spiders and rain drops meaning that excellent images can be produced day & night. With IP67 rated weatherproof housing, the DS-2CD2355FWD-I is a great choice for any outdoor application. It's 3-axis adjust-ability means that any area of interest can be covered with ease no matter whether the camera is mounted to the wall, on a junction box or with a wall mount arm. Hikvision cameras use a range of features such as wide dynamic range and SD digital noise reduction technology to improve image quality even further. The DS-2CD2355FWD-I also utilizes an impressive range of smart features including line crossing detection and intrusion detection with notifications that can trigger recordings or notify you via your smartphone or tablet. The DS-2CD2355FWD-I has the ability to record using the most efficient video compression: H.265+. This offers a huge saving on bandwidth and storage usage compared to H.264. The use of H.265+ means that you can use the on board SD card slot for recording without the worry of running out of memory too fast. This camera can be powered by PoE or with a 12VDC power supply and can be accessed remotely by smart phone or browser when used alongside Hik-Connect.
  9. Hikvision DS-2CD2T55FWD-I8 5MP Bullet Network Camera
    The DS-2CD2T55FWD-I8 is a 5MP bullet camera with powerful infra-red LEDs that work up to 80m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T55FWD-I8 supports Hikvision's latest H.265+ video compression which dramatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
    Banner for 5MP and 8MP bullet Hikvision Easy IP 3.0 range
  10. Hikvision DS-2CD2T55FWD-I5 5MP Bullet Network Camera
    The DS-2CD2T55FWD-I5 is a 5MP bullet camera with powerful infra-red LEDs that work up to 50m. It is a great choice for outdoor applications with IP67 rated weatherproof housing and a built in bracket that has 3-axis adjustment. An optional junction box can be used to keep connections tidy. This camera uses back light compensation (BLC) and 3D digital noise reduction technology (3D DNR) to improve image quality. It also uses a range of smart features such as motion detection, line crossing detection and intrusion detection to improve security further. The DS-2CD2T55FWD-I5 supports Hikvision's latest H.265+ video compression which dramtatically reduces bandwidth and storage usage. There is also a built-in micro SD card slot. This camera can be powered with either a 12VDC power supply or by PoE. It can be accessed remotely through a browser or by Hik-connect.
    Hikvision Easy IP 3.0 banner for DS-2CD2TX5FWD-
  11. Hikvision DS-2CD2055FWD-I 5MP Mini Bullet Network Camera
    The Hikvision DS-2CD2055FWD-I is a 5MP mini bullet camera that is available in either a 2.8mm, 4mm or 6mm fixed lens. This camera comes fitted with infra-red LEDs that are effective up to 30m and IP67 rated weatherproof housing. The DS-2CD2055FWD-I also comes with a built in bracket that has 3-axis adjustability so there is a lot of flexibility if you need to cover a wide area. The image is improved using back light compensation (BLC) and 3D digital noise reduction technology (3D DNR). The DS-2CD2055FWD-I also utilises smart features such as motion detection, line crossing detection and intrusion detection to improve security even further. Fitted with Hikvision's H.265+ video compression, the on board SD card slot can be used without worry of using up the memory so quickly. This camera can be powered by 12VDC power supply or PoE, it can be accessed remotely through a browser or by using the Hik-connect app.
    Hikvision Mini Bullet banner for easy IP 3.0 range
  12. Geovision GV-VD5711 5MP Vandal Proof Dome Camera
    £708.00 Incl VAT Excl VAT. £590.00
    The Geovision GV-VD5711 is a 5MP dome camera with a motorised 2.8mm~12mm lens and intelligent IR LEDs, fitted externally, effective up to 30m. Fitted with IP67 rated weatherproof housing and IK10+ vandal resistant housing, this camera is a sturdy choice for outdoor applications. The GV-VD5711 has a 3-axis mechanism for precise set up ensuring any area of interest can be easily covered. This camera also supports two way audio for the connection of an external microphone and speaker. With a range of image enhancers such as wide dynamic range, back light compensation, 3D noise reduction and image configuration such as contrast, brightness and saturation, the GV-VD5711 can provide excellent video quality day or night. Security is further improved with the use of motion detection, tampering alarm and privacy mask. This camera supports on board storage and H.265 compression meaning storage and bandwidth worries are a thing of the past. It can be powered by a 12VDC power supply or by PoE and remote access is possible through internet explorer or the GV-Eye app.
    GV-VD4711 packing list
    Vandal Resistant Dome Quick Start GuideGeovision BrochureGeovision Mount Guide Learn More
  13. Vivotek IB8382-F3 5MP Bullet Camera
    £302.17 Incl VAT Excl VAT. £251.81
    The IB8382-F3 is a 5MP bullet camera with a fixed lens that supports remote focus. This camera is perfect for many outdoor applications with smart IR LEDs that can see up to 30 meters and housing that protects against the weather and vandals. Using features such as wide dynamic range and digital noise reduction, the IB8382-F3 can provide brilliant images in all light intensities. IB8382-F3 Banner
    Quick Installation Guide User Manual Learn More
  14. Vivotek IB8382-T 5MP Bullet Camera
    £508.70 Incl VAT Excl VAT. £423.92
    The IB8382-T is a 5MP bullet camera with a vari-focal lens that supports remote focus. This camera is perfect for many outdoor applications with smart IR LEDs that can see up to 30 meters and housing that protects against the weather and vandals. Using features such as wide dynamic range and digital noise reduction, the IB8382-T can provide brilliant images in all light intensities. IB8382-T banner
  15. Geovision GV-EFD5101 5MP H.264 Fixed Dome Camera
    Geovision GV-EFD5101 5MP Indoor Vari-Focal Dome Camera
    £308.40 Incl VAT Excl VAT. £257.00
    The Geovision GV-EFD5101 is an internal 5MP dome camera fitted with a vari focal 3mm~9mm lens (92°~32°). It also houses built in IR LEDs that are effective up to 30m. The GV-EFD5101 supports two-way audio and a range of image enhancing features including backlight compensation, wide dynamic range, defog and low lux enhancement. It also supports smart features to improve security such as tampering alarm, focus change and camera shift. This camera supports H.264 compression and can be powered by either a 12VDC power supply or a PoE injector. Remote access is possible through a web browser or through the GV-Eye app.
    GV-EFD2101 packing list
  16. Geovision GV-BX5700 5MP Box Camera
    £472.80 Incl VAT Excl VAT. £394.00
    The Geovision GV-BX5700 is a 5MP box camera with the choice of a vari-focal lens (GV-BX5700-3V - 3.6~10mm = 90°~40°) or a fixed lens (GV-BX4700-8F - 2.95mm = 120°) and two-way audio. It uses a range of image enhancers such as backlight compensation, wide dynamic range, defog, denoise, low lux enhancement and more. The GV-BX5700 supports a range of features to improve security such as tampering alarm, focus change and camera shift. This camera also supports on board storage with a micro SD card slot and H.264 compression. The camera can be powered by a 12VDC power supply or PoE and remote access is possible through the GV-Eye app or through a web browser.
    GV-BX2700
    Learn More
  17. Geovision GV-FER12203 12MP Fisheye Camera
    £1,086.00 Incl VAT Excl VAT. £905.00
    The Geovision GV-FER12203 is a 12MP fisheye camera fitted with a 1.83mm providing a 180° field of view. This camera is IP67 rated weatherproof and IK10 rated vandal resistant making it a great choice for external and internal applications. The GV-FER12203 features two-way audio and a range of image enhancers to improve security further such as wide dynamic range, defog and denoise. It also supports tampering alarm and triple streams from H.265, H.264 and MJPEG. Multiple fisheye views are also supported. This camera features an on-board micro SD card slot and can be powered by either a 12VDC power supply or a PoE injector. Remote access is possible through the GV-Eye app or a web browser.
    GV-FER5700 packing list
    Geovision Quick Start GuideGeovision ManualGeovision Brochure
    Learn More
  18. Geovision GV-FER5700 5MP Fisheye Camera
    £452.40 Incl VAT Excl VAT. £377.00
    The Geovision GV-FER5700 is a 5MP fisheye camera fitted with a 1.45mm providing a 180° field of view. This camera is IP67 rated weatherproof and IK10 rated vandal resistant making it a great choice for external and internal applications. The GV-FER5700 features two-way audio and a range of image enhancers to improve security further such as wide dynamic range, defog and denoise. It also supports tampering alarm and triple streams from H.265, H.264 and MJPEG. Multiple fisheye views are also supported. This camera features an on-board micro SD card slot and can be powered by either a 12VDC power supply or a PoE injector. Remote access is possible through the GV-Eye app or a web browser.
    Learn More
  19. Geovision GV-VD5700 Dome Camera
    Geovision GV-VD5700 5MP Vari-Focal Dome Camera
    £368.40 Incl VAT Excl VAT. £307.00
    The Geovision GV-VD5700 is a 5MP vari focal 2.8mm~12mm dome camera with IR LEDs effective up to 30m. It is suitable for external applications with the use of IK10 vandal resistant housing and IP67 rated weatherproof housing. It is highly adjustable with pan (0° ~ 360°), tilt (90° ~ 180°) and rotate (0° ~ 355°) mechanisms. The GV-VD5700 supports two way audio and uses a range of image enhancers to improve security further: backlight compensation, wide dynamic range, defog, low lux enhancement and denoise. This camera also uses some smart features for further support such as tampering alarm, focus change and camera shift. There is also a built-in micro SD card slot and with the use of H.265 compression, bandwidth and storage concerns are greatly reduced. The GV-VD5700 can be powered by a power supply or by a PoE injector. Remote access is possible through the GV-Eye app or by a web browser.
    GV-VD3700 packing list
  20. ACTi A82 5MP Outdoor Zoom Dome with Adaptive IR, WDR & 2.8x Zoom Lens
    £834.36 Incl VAT Excl VAT. £695.30
    The A82 is a 5 megapixel dome camera that offers 1080p HD resolution, it features a 2.8x zoom lens with extreme WDR that helps it perform incredibly well in very low light situations, day or night. It also includes adaptive IR LED's, weatherproofing (IP66) and vandal proofing (IK10) and it is also fully compatible with ACTi software.
    To download ACTi's latest firmware you will have to go to the ACTi Download Centre and then search the model you have to get the right firmware for your model (check the date before downloading to make sure it is the latest firmware available).
    use-IP Ltd have been an ACTi Partner since August 2008. There is currently a 14-day lead-time to fetch this product from manufacturer's stock. Please feel free to contact us for further information.
    ACTi Quick Installation Guide ACTi A82 Manual/Installation Guide ACTi Firmware Manual ACTi Selection Guide Learn More
  21. ACTi A42 5MP Zoom Bullet with Adaptive IR, WDR & 2.8x Zoom Lens
    £724.80 Incl VAT Excl VAT. £604.00
    The A42 is a 5 megapixel bullet camera that offers 1080p HD resolution, it features a 2.8x zoom lens with extreme WDR that helps it perform incredibly well in very low light situations, day or night. It also includes adaptive IR LED's, weatherproofing (IP66) and vandal proofing (IK10) and it is also fully compatible with ACTi software.
    ACTi Quick Installation Guide ACTi A42 Manual/Installation Guide ACTi Firmware Manual ACTi Selection Guide Learn More
  22. Samsung SNV-8080 5MP Vandal-Resistant Network Dome Camera
    £788.84 Incl VAT Excl VAT. £657.37
    In Stock
    The SNV-8080 features 5 megapixel high definition images. Its’ high level of functionalities includes 60dB Digital Wide Dynamic Range, delivering 5MP @ 20fps, and 2.6x motorized varifocal lens which provides perfect simple focus control. With IP66/IK10 ratings and a minimum operating temperature down to -40⁰ with a PoE heater, it can work effectively in more demanding environments that are prone to severe or varying weather conditions, as well as tampering or physical attacks.
    "This product may not be immediately available from UK stock, in which case it will take 7 days to fetch it from their European warehouse"
    Samsung Product Comparison Chart
    User Manual
    Accessory Chart
    Learn More
  23. Vivotek FD8182-T Fixed Dome Network Camera
    £439.70 Incl VAT Excl VAT. £366.42
    The FD8182-T is an indoor dome camera from Vivotek capable of 5MP recording at 15 fps. This camera gives you the best image possible with the use of 2D Noise Reduction technology and resolution optimisation. This camera is easy to control with the use of remote focus and P-iris that also helps control the camera remotely. FD8182-T Features
    Quick Installation Guide User Manual V Pro Flyer Learn More
  24. Vivotek FD8382-TV Fixed Dome Network Camera
    Vivotek FD8382-TV 5MP Fixed Dome Network Camera
    The Vivotek FD8382-TV is a 5MP fixed dome camera which offers 30fps at 1080p resolution and can be controlled remotely with P-iris control and built-in stepping in motors.The FD8382-TV uses Smart Stream technology and 3D DNR to optimize resolution and the use of bandwidth. This camera can be mounted in harsh outdoor conditions as it is armed with IP-66 rated weather-proof housing and IK-10 rated vandal proof housing. 8382-tv
  25. Vivotek FE8182 Recessed Fisheye Network Camera
    £446.58 Incl VAT Excl VAT. £372.15
    The FE8182 is a recessed-mount fisheye camera with great 5MP image quality and many smart features all squeezed into a 60mm diameter case. The fisheye lens provides 180° panoramic view and coverage of large areas. 3D Noise Reduction technology and Wide Dynamic Range enhancement gives visibility in intense light and dark situations. Vivotek FE8182 Recessed Fisheye Network Camera
    Quick Installation Guide User Manual Vivotek Fisheye Brochure Learn More
  26. Vivotek FD8382-VF2 Fixed Dome Network Camera
    £346.70 Incl VAT Excl VAT. £288.92
    The FD8382-VF2 is an outdoor dome camera with a fixed lens. This camera offers 15fps at 5MP resolution while meeting the needs of outdoor applications. Smart Stream technology allows the optimization of a specific desired area while 3D Noise Reduction technology keeps the picture as clear and detailed as possible. The IK-10 vandal proof and IP66 weatherproof housing makes this camera perfect for outdoor applications without the worry of damage to the camera. FD8382-VF2
    Quick Installation Guide User Manual V Pro Line Brochure Learn More
  27. ACTi E921M 5MP Outdoor Mini Fisheye Dome Camera with Basic WDR, M12 Connector and Fixed 1.19mm Lens
    £418.56 Incl VAT Excl VAT. £348.80
    ACTi E921 Hardware Manual ACTi Firmware Manual ACTi Selection Guide Learn More
  28. ACTi E925 5MP Outdoor Mini Fisheye Dome with D/N, Adaptive IR, Basic WDR, Fixed Lens
    £474.00 Incl VAT Excl VAT. £395.00
  29. ACTi E815 5MP Outdoor Zoom Dome with D/N, Adaptive IR, Basic WDR, 4.3x Zoom Lens
    £566.41 Incl VAT Excl VAT. £472.01
  30. ACTi B82 5MP Outdoor Zoom Dome with D/N, Adaptive IR, Basic WDR, 2.4x Zoom Lens
    £705.01 Incl VAT Excl VAT. £587.51
  31. ACTi E924M 5MP Outdoor Mini Dome with D/N, Adaptive IR, Basic WDR, Fixed Lens
    £463.44 Incl VAT Excl VAT. £386.20
  32. ACTi E924 5MP Outdoor Mini Dome with D/N, Adaptive IR, Basic WDR, Fixed Lens
    ACTi E924 5MP Outdoor Mini Dome D/N, Adaptive IR, Basic WDR, Fixed Lens
    ACTi Firmware Manual April 2016
  33. ACTi E616 5MP Indoor Zoom Dome with D/N, Adaptive IR, Basic WDR, 4.3x Zoom Lens
    £514.92 Incl VAT Excl VAT. £429.10
  34. ACTi Q111 5MP Indoor Fisheye Covert with Basic WDR, Fixed Lens
    £489.60 Incl VAT Excl VAT. £408.00
    ACTi Q111 2MP Indoor Fisheye Covert with Basic WDR, Fixed Lens
  35. ACTi Q110 5MP Indoor Covert with Basic WDR, Fixed Lens
    £507.60 Incl VAT Excl VAT. £423.00
  36. ACTi E413 5MP Zoom Bullet with D/N, Adaptive IR, Basic WDR, 10x Zoom Lens
    £596.51 Incl VAT Excl VAT. £497.09
    ACTi E413 10MP Bullet with D/N, Adaptive IR, Basic WDR, Vari-focal Lens
    ACTi Selection Guide ACTi Bullet Camera Hardware Manual 2015 Learn More
  37. ACTi B46 5MP Zoom Bullet with D/N, Adaptive IR, Basic WDR, 10x Zoom Lens
    £824.40 Incl VAT Excl VAT. £687.00
    Learn More
  38. ACTi E920M 5MP Outdoor Mini Dome with Basic WDR, M12 connector, Fixed lens
    £444.00 Incl VAT Excl VAT. £370.00
    Learn More
  39. ACTi E213 5MP Zoom Box with D/N, Basic WDR, 10x Zoom Lens
    £459.48 Incl VAT Excl VAT. £382.90
    Learn More
  40. ACTi E15 5MP Fisheye Cube Camera with Basic WDR, Fixed Lens
    £273.34 Incl VAT Excl VAT. £227.78
    Learn More
  41. Axis M3037-PVE Outdoor Network Dome Camera 0548-001
    £852.65 Incl VAT Excl VAT. £710.54
    In Stock
    The Axis M3037-PVE is an outdoor ready fixed focus mini dome camera that provides excellent image quality in daylight as well as night time, the camera offers full duplex audio with echo cancellation and noise reduction as well as supporting Session Initiation Protocol (SIP) for easy integration with IP phone systems.
    Included Accessories: - Installation guide - Windows decoder 1-user license - Installation and management software CD - Drill hole template - Resitorx L-key - Terminal block connector
    Axis M3037-PVE User Manual Axis M3037-PVE Installation Guide Axis Assigning IP Address User Manual Axis Product Comparison Table February 2015 Axis Product Comparison Table FREE 30-day trial of Axis Camera Station software Articles about Axis Network Cameras Learn More
  42. Samsung SNF-8010VM 5 Megapixel Fisheye Camera
    Samsung SNF-8010VM 5 Megapixel Outdoor Fisheye Camera
    £596.40 Incl VAT Excl VAT. £497.00
    Introducing the new 5 megapixel 360° fisheye camera. This new camera features 5MP @ 20fps which captures smoother video at a higher framerate with true day and night function. Built-in on-camera dewarping allows instant access to single PTZ, quad view, & panorama views. Bi-directional audio allows greater situational awareness. The micro-SDXC memory card slot creates a cost effective edge recording solution. Alarm triggers include intelligent motion detection, audio detection, tampering detection, alarm input, & network disconnection. Rated to IP66/IK10 (SNF-8010VM), it can work effectively in more demanding environments that are prone to severe or varying weather conditions as well as tampering or physical attack.
    Accessory Chart
    Learn More
  43. ACTi E73A 5MP Outdoor Dome Camera
    ACTi E73A 5MP Outdoor Dome Camera with D/N, IR, Basic WDR and a Fixed 2.93mm Lens
    £372.36 Incl VAT Excl VAT. £310.30
    ACTi E73A 5 megapixel outdoor dome camera with D/N, IR, Basic WDR and a fixed 2.93mm lens. This camera has 3-axis lens adjustment, allowing you full control over how the camera is mounted and the view adjustment; the third axis of adjustment "Rotate:" (aka horizon adjustment) will allow you to bring the view back to level regardless of the pan & tilt adjustments.
    ACTi E73 Hardware Manual
  44. ACTI E13 Cube Camera
    ACTI E13A 5MP Indoor Cube Camera with Basic WDR and a Fixed 2.8mm Lens
    £231.83 Incl VAT Excl VAT. £193.19
    ACTi E13A 5 megapixel fixed 2.8mm lens cube camera with basic WDR. use-IP Ltd have been an ACTi Partner since August 2008. There is currently a 14-day lead-time to fetch this product from manufacturer's stock. Please feel free to contact us for further information.
    ACTi E13 Hardware ManualACTi Firmware Manual ACTi Selection Guide
    Learn More
  45. Vivotek FE8180 5MP Fisheye Network Camera
    £301.21 Incl VAT Excl VAT. £251.01
    The FE8180 provides 360° surround view while being discrete at only 90mm diameter. This Fisheye camera has a 5MP sensor and can output 30fps at 1080p full HD resolution.
    Vivotek FE8180 User Manual
    Vivotek FE8180 Installation GuideProduct BrochureSurveillance Handbook Learn More
  46. Vivotek FE8181 5 Megapixel Fisheye Network Camera
    £816.97 Incl VAT Excl VAT. £680.81
    Vivotek FE8181 5 Megapixel Fisheye Network Camer The FE8181 is a 5MP fisheye camera from Vivotek with an ouput of 30 fps at 1080p full HD. The fisheye lens gives an 180° Panoramic View and 360° Surround View. This camera benefits from built-in IR illuminators, meaning it can see up to 10m in the dark.
    Please note that this product may be subject to a 14-day lead-time to fetch it from the manufacturer.
    Vivotek FE8181 User Manual Vivotek FE8181 Installation GuideSurveillance Handbook Learn More
  47. ACTi E921 5MP Outdoor Mini Fisheye Dome Camera with Basic WDR and Fixed 1.19mm Lens
    ACTi E921 5MP Outdoor Mini Fisheye Dome Camera with Basic WDR and Fixed 1.19mm Lens.
    Learn More
  48. ACTi E920 5MP Outdoor Mini Dome Camera with Basic WDR and Fixed 1.9mm Lens
    £423.85 Incl VAT Excl VAT. £353.21
    ACTi E920 5MP Outdoor Mini Dome Camera with Basic WDR and Fixed 1.9mm Lens.
    ACTi E920 Hardware Manual ACTi Firmware Manual ACTi Selection Guide
    Learn More
  49. ACTi B54 5MP Indoor Fisheye Dome Camera with D/N, Basic WDR and Fixed 1.19mm Lens
    £500.40 Incl VAT Excl VAT. £417.00
    ACTi B54 5MP Indoor Fisheye Dome Camera with D/N, Basic WDR and Fixed 1.19mm Lens.
    ACTi B54 Hardware Manual ACTi Firmware Manual ACTi Selection Guide
    Learn More
  50. ACTi I71 5MP Outdoor Hemispheric Dome Camera with D/N, Advanced WDR, SLLS, ePTZ and Fisheye Lens
    £921.31 Incl VAT Excl VAT. £767.76
    ACTi I71 5MP Outdoor Hemispheric Dome Camera with D/N, Advanced WDR, SLLS, ePTZ and Fisheye Lens.
    Learn More
Grid  List
