rayTEC Infra-Red Illuminators
Sidebar
Grid  List
  1. rayTEC VAR2-i4-1 Medium Range Infra-Red Illuminator
    £264.18 Incl VAT Excl VAT. £220.15
    Built to Order
    The rayTEC VAR2-i4-1 is an illuminator from the VARIO2 range which is designed to deliver light that can improve any video surveillance system at night. This illuminator features interchangeable lenses with hot-spot reduction technology to deliver excellent illumination at distances up to 144m. 10° x 10°, 35° x 10° and 60° x 25° lenses are all included.
    raytec vario2 banner
    rayTEC Bracket GuiderayTEC VARIO2 Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure
    Learn More
  2. rayTEC VAR2-IPPoE-i4-1 Medium Range Infra-Red Network Illuminator
    £314.16 Incl VAT Excl VAT. £261.80
    Built to Order
    The rayTEC VAR2-IPPoE-i4-1 is designed to improve video surveillance at night with semi covert 850nm IR LEDs that can reach distances of 144m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE+ input for easy integration with existing network structures. The VAR2-IPPOE-i4-1 provides the ultimate solution for smart, situation-dependent lighting and is perfect for use with IP cameras. The illuminator can be programmed to automatically deliver the exact amount of light where and when it is needed.
    raytec vario2 ip poe banner
    rayTEC Bracket GuiderayTEC VARIO2 IP Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure Learn More
  3. rayTEC VAR2-PoE-i4-1 Medium Range Infra-Red PoE Illuminator
    £251.33 Incl VAT Excl VAT. £209.44
    Built to Order
    The rayTEC VAR2-PoE-i4-1 is designed to improve video surveillance at night with semi covert 850nm IR LEDs that can reach distances of 144m. This illuminator comes with 10°x 10°, 35° x 10° and 60°x 25° angles included and has a PoE+ input for easy integration with existing network structures.
    raytec vario2 poe banner
    rayTEC Bracket GuiderayTEC VARIO2 Installation GuiderayTEC Distance and Angle CalculatorrayTEC Product OverviewrayTEC VARIO2 Brochure Learn More
Grid  List
