Wisenet Dome Cameras
Sidebar
Grid  List
  1. Wisenet XNV-6022RM Vandal-Resistant Vibration-Resistant Flat Dome Camera
    £422.62 Incl VAT Excl VAT. £352.18
    The XNV-6022RM is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. This camera has the added benefit of built-in infra-red LED's allowing it to capture images in the dark up to 15m. It also includes a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. The XNV-6022RM is vibration resistant and has a M12 connector, making it suitable for use in situations where vibrations may occur such as in transport environments. This camera is fitted with a 3.6mm lens which can capture a wide angle to cover 94.8° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
    User Manual Quick Installation Guide Learn More
  2. Wisenet XNV-6012M 2MP Vandal-Resistant Vibration-Resistant Flat Dome Camera
    £402.60 Incl VAT Excl VAT. £335.50
    The XNV-6012M is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. The key difference between the XNV-6012M and the XNV-6012 is that the XNV-6012M is vibration resistant and has a M12 connector, making it suitable for use in situations where vibrations may occur such as in transport environments. This camera benefits from a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. The XNV-6012M is fitted with a 2.4mm lens which can capture a wide angle to cover 135.4° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
  3. Wisenet XNV-6012 2MP Vandal-Resistant Flat Dome Camera
    £378.60 Incl VAT Excl VAT. £315.50
    The XNV-6012 is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. This camera benefits from a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. The XNV-6012 is fitted with a 2.4mm lens which can capture a wide angle to cover 135° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
Grid  List
