Wisenet X Series
Sidebar
Wisenet X Series
Grid  List
  1. Wisenet XNF-8010RVM 4MP Outdoor Fisheye Camera
    £549.60 Incl VAT Excl VAT. £458.00
    The Wisenet XNF-8010RVM is a 4MP fisheye camera with built-in infra-red LED's to allow for up to 15m of night time viewing. Thanks to its IP66 weatherproof-rated and IK10 vandal resistance-rated housing, this camera is suitable for use both indoors and outdoors and in situations where it may be subject to tampering. It has a built-in SD / SDHC / SDXC memory card slot and bi-directional audio and can be used with a wide range of accessories meaning its potential uses are varied. The XNF-8010RVM can be used with a wide range of intelligent video analytics including Tampering, Loitering, Enter/Exit, Audio detection, People counting, Heat-mapping and Queue Management.
    XRN-1610S banner
    This product is a special order item so is therefore not immediately available from UK stock and may take 7-10 days to fetch it from their European warehouse. It is also non-returnable.
    User Manual Learn More
  2. Wisenet XNV-6022RM Vandal-Resistant Vibration-Resistant Flat Dome Camera
    £422.62 Incl VAT Excl VAT. £352.18
    The XNV-6022RM is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. This camera has the added benefit of built-in infra-red LED's allowing it to capture images in the dark up to 15m. It also includes a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. The XNV-6022RM is vibration resistant and has a M12 connector, making it suitable for use in situations where vibrations may occur such as in transport environments. This camera is fitted with a 3.6mm lens which can capture a wide angle to cover 94.8° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
    User Manual Quick Installation Guide Learn More
  3. Wisenet XNV-6022R Vandal-Resistant IR Flat Dome Camera
    £422.40 Incl VAT Excl VAT. £352.00
    The XNV-6022R is part of a new range of Wisenet dome cameras that are designed for environments with limited space such as in lifts, entrance lobbies, stair wells and small shops, where people are looking for a discreet but comprehensive solution. The XNV-6022R has the added benefit of built-in infra-red LED's allowing it to capture images in the dark up to 15m. It also includes a range of innovative features including an audio analysis function which is capable of recognising sounds such as gunshots, explosions, screams and broken glass. Other useful features include defocus detection, virtual line, appear/disappear, loitering and camera tampering. This camera is fitted with a 3.6mm lens which can capture a wide angle to cover 94.8° horizontally. It also utilises H.265 compression and WiseStream II, a compression technology which dynamically controls encoding, balancing quality and compression according to movement in the image. Both of which mean that bandwidth efficiency is improved by up to 99% compared to when using H.264 compression. XRN-1610S banner
  4. Wisenet XNF-8010R 6MP Sensor Fisheye Camera
    Wisenet XNF-8010R 4MP Sensor Fisheye Camera
    £576.00 Incl VAT Excl VAT. £480.00
    The Wisenet XNF-8010R is a 4MP Indoor fisheye camera with built-in infra-red LED's to allow for up to 15m of night time viewing. It has a built-in SD / SDHC / SDXC memory card slot and bi-directional audio and can be used with a wide range of accessories meaning its potential uses are varied. This camera can be used with a wide range of intelligent video analytics including Tampering, Loitering, Enter/Exit, Audio detection, People counting, Heat-mapping and Queue Management.
    XRN-1610S banner
    This product may not be immediately available from UK stock, in which case it may take 7-10 days to fetch it from their European warehouse.
Grid  List
